Vulcan gas Central heating model number 5300072,error code 11
3 Suggested Answers
  • 1833 Answers
SOURCE: hi, i have a problem
Combustion pressure fault, usually meansthe fan is not working, sometimes they just need a clean because they getrather heavy when covered in dust and wont spin. Could also be a blockage ofdust from fan to heater, try a vacuum in there.
Ignition failures are usually one of three things
  1. The hot surface igniter has burnt out
  2. the flame failure safety mechanism has burnt out
  3. the unit has overheated and blown a single use over temperature cutout switch ( much like a fuse)
These things should only be servicedby a good service agent, if they malfunction and don't work correctly theconsequences can be deadly, including filling your house up with carbonmonoxide as you sleep, or starting a fire within your wall cavity.
Posted on Jun 27, 2011
SOURCE: My father has to replaxce
Usually these numbers on most other untits are stamped on a metal plate which is located
or attached to the gas valve, which would also give the BTU Input/Output. Probably the
Model Number as well
Posted on Sep 01, 2011
Why doesn't gas central heater work?
some of the newer gas furnaces do not have a pilot that stays on but auto ignite when the call for heat . the best advice , is to call a professional , in your area and have them check your furnace .
Jan 30, 2016 | Vulcan Heating & Cooling
My father has to replaxce an 11 year old Vulcan Wall Furnace. He wants a Braemar Wall Furnace. He must tell Braemar what model his Vulcan is - there aren't any model badges. Can he determine if his...
Sep 01, 2011 | Heating & Cooling
THE Indoor tankless heater will turn on(with hot water on), light the priority light for 5 seconds, then the light will go off and the control reads a C2 11 error code. can you email me the 11 page...
Before calling service technician, best way to approach this problem is to contact Rheem with your specific model and serial number.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Error codes are starting place for troubleshooting.
C2 11 is gas and ignition related.
The same symptoms on your tankless unit can have different cause and solution than another tankless unit.
The burner might need to be cleaned.
Undersized gas meter, or low gas pressure should be checked.
Air in gas line.
Short circuit in gas solenoid.
Bad igniter.
Igniter wiring harness.
Tankless is not grounded.
Vent exceeds allowable height or length limit
All gas water heaters require periodic maintenance.
The manual is a good place to start for advisories and troubleshooting and required maintenance.
Tankless water filter should be cleaned monthly, and heat exchanger de-limed yearly.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
May 19, 2011 | Rheem Paloma PTG-74PVN / RTG-74PVN...
I had a vulcan central heating unit that was made in 1990. Could you please tell me what the model number is on a 1990 vulcan central heating unit. Thanks, Rob
Hi Rob, The number you have listed AUW230A may be the model number. You say its a central heat so, If it is a package unit, the model, serial, and all of the ratings would be on the unit near the elect box on a package unit.I do know by the # you gave me it is a Vulcan 3000 watt thermostatically controlled Immersion heater. Here is a link I can give you, they deal with this heater for parts Ect. that maybe of help to you, it is www.grainger.com. There are many model # and I believe this is it, AUW230A. I hope this helps Rob, Sincerely,
Shastalaker7
Nov 17, 2009 | Vulcan AUW230A Heater
We have a Vulcan Ultra high efficiency gas ducted heating
Gas ducted central heater won't switch on all of a sudden
Nov 04, 2009 | Vulcan AUW230A Heater
F 11 error code on whirlpool duet washer.
Serial Communication Error
Communication between the Central Control Unit (CCU) and the Motor Control Unit (MCU) cannot be sent correctly.
  • Check Wire Harness connectors to the MCU, the motor, and Central Control Unit (CCU)
  • Check the Drive system for any worn or failed components
  • Check MCU
  • Check CCU
  • Check Motor
this is for error code f 11
thanks.
May 02, 2009 | Whirlpool GHW9400 Front Load Washer
F 11 error code on Whirlpool Duet - Serial Communication Error ?
Your F11 Code is stateing these things but if it is intermittent probabbly a loose connection.
  • Check MCU
  • Check CCU
  • Check Motor
Jan 20, 2009 | Whirlpool GHW9300 Duet Washer
Vulcan CX ducted heating
sounds like the thermocouple (that sensors the heat) may be faulty.
you will need a licensed gas fitter for repairs
Feb 19, 2008 | Heating & Cooling
Heating & Cooling Logo
61 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
