Question about Giant Bicycle Inc. Cypress DX
Rear axle size - Giant Bicycle Inc. Cypress DX
Axle bolt size dyna fxd
Hi Anonymous, I can only find nut size, sorry
front axle: 1/2-20x3/4
rear axle: 5/8-18x15/16
Good luck
Apr 11, 2014 | 2003 Harley Davidson FXD Dyna Super Glide
What size are rear axle nuts on vlx 600
Hi, Anonymous the answer to this question is way above my pay grade for this situation, I would call or visit my local dealer or reputable shop's service/parts department and inquire about any possible quick fix, answers, or parts inquiry.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Rear axle nut size
Axle nut sizes on 2001 Honda Shadow
http://www.vt600vlx.com/VLX%20VT600%2097%20and%20up%20Service%20Manual.pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda
Oct 08, 2013 | Honda Motorcycles
Whats the rear axle size on a 2009 low rider
Hi Anonymous, check with your local parts department. Good luck.
Mar 04, 2013 | Harley Davidson FXDL Dyna Low Rider...
What is the size of a king ranch f150 2002 ford rear axle housing and it is a double cabin
There are 3 different sizes of axles available.(8.8")(9.75")(10.25") Most 2wd are 8.8" but you can get them in a 9.75". Most 4wd are 9.75" although it is possible to get it in a 8.8". And usually the 10.25" is reserved for 7700 series trucks. This is only a rough guideline as vehicles could be ordered with different options or the axle may have been swapped out. If it has 7 bolt rims then it is definitely a 10.25" and if it has 5 bolt rims its either an 8.8" or a 9.75". The easiest way to tell would be to check the axle tag. It should be bolted right on the rear axle housing. This will give you all of the information of the axle(size/ratio). If not you can give your local Ford dealer a call with the VIN# and if their friendly they will tell you.
Jun 01, 2011 | Ford F-150 Cars & Trucks
Where is the rear motor mount located on a 93 grand voyager
If your problem is rumbling drive axles , stop buying after market rebuilt axles. Forget the lifetime warranty. Buy only new Chrysler or Chrysler rebuilt axles for your car . After replacing my motor mounts and a dozen axles the manufacturer axles were the only ones that worked. I recall a motor mount at each end of the motor and one in the front (same vehicle). Checking my manual they do not show a rear mount on any of the motor sizes.
Sep 22, 2010 | 1993 Plymouth Voyager
Where could I find the size of the axle of the
A call to the local harly shop would be sufficient but I think they've all went to 1" by now. The best way to tell is to measure the axle in your bike. Take the rear axle nut off and tap the axle out the other side just far enough to measure the diameter with a caliper. Once done, tap the axle back in and retorque the nut to 50 Foot pounds.
May 25, 2010 | 2008 Harley Davidson VRSCDX Night Rod...
2008 Honda CBR 1000 RR Fireblade what size of nut on rear wheel
Hi, Phonesuk the answer to that question is on your 6" pocket ruler, for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere $10 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Size of Rear Axle nut on 2008 1krr
Rear Axle nut size
CBR1000RR 2008 2014 Service Manual Download Manuals Technical
Honda CBR1000RR Fireblade Owner Manual
Jan 25, 2010 | 2008 Honda CBR 1000 RR Fireblade
83 cj7 rear axle
You could weld the keyway and file it back to size or replace axle. To upgrade, check with some of the big axle manufacturers like strange engineering etc. They could likely help or point you in the right direction. Anything you do will be $$ though.
Feb 22, 2009 | 1984 Jeep CJ7
Bird Rear-end Size
Hi meduck4,heres what you need brother as I cant see your diff, 3 ways to tell what you have:
#1 The first is the driver's door tag; there will be a one-letter or one-numeral axle code listed there. You can then compare it to the chart below: CODE Rear Axle Ratio Conventional Locking 8 M 2.73 Y Z 3.08 F R 3.45 5 E 3.27 6 W 3.73
#2 The second is the axle tag, attached to the lower lefthand bolt on the rear axle itself. The bottom left line will give you the gear ratio, and the type of rear end (S for limited slip non-locking, and L for locking).
#3 The 7.5" rear axle height is shorter than the width and the shape appears "oval".
The 8.8" rear axle
dimensions are equal and the shape appears "round".
This will tell you what you have my friend,good luck
Nov 13, 2008 | 1985 Ford Thunderbird
Giant Bicycle Inc. Cypress DX Logo
Top Giant Bicycle Inc. Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Giant Bicycle Inc. Cycling Expert? Answer questions, earn points and help others
