Question about Hisense Televison & Video
Tv channels blockeds
Can't install the channels
    Top Expert:
  • Hisense Master
  • 73,710 Answers
Check and replace its main system control memory IC. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Posted on Apr 14, 2014
How to remove the description on the tv
Maybe your initial setup procedure let you select this and you have to go back to eliminate it. I get a bloick like that while channeling through live TV but the block goes away.
Nov 24, 2013 | Hisense TA42P40M 42 in. Plasma Television
Tip
Toshiba 42HP95 Channel Block Reset
Toshiba 42HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 42HP95 Plasma TV channel block?
Have you forgotten your channel block PIN, passcode or password?
If you forget your channel block passcode, you can view the locked channels without entering your password:
  • When your PIN is requested, simply press RECALL four times withing five seconds.
  • The channel block passcode will be reset and you can enter a new PIN if desired.
I hope that helps.
________________________________________
Download Toshiba 42HP95 Plasma TV Manual
on Jul 03, 2010 | Televison & Video
Tip
Toshiba 50HP95 Channel Block Reset
Toshiba 50HP95 Plasma TV Channel Block Reset
Would you like to bypass, defeat or reset your Toshiba 50HP95 Plasma TV channel block?
I hope that helps.
Download Toshiba 50HP95 Plasma TV Manual
How to reset a password
Set up blocking schemes to block specific channels, ratings, and external viewing sources.
A password is required to gain access to this menu.
Setting up Your Password
For USA
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
Movie Rating
TV Rating-Children
TV Rating-General
Downloadable Rating
Input Block
For Canada
LOCK Move Enter
Lock System : Off
Set Password
Block Channel
TV Rating-English
TV Rating-French
Downloadable Rating
Input Block
Close
Enter Password
Select LOCK.
1MENU
ENTER
Input the password.
2 Enter the password as requested.
The TV is set up with the initial password
"0-0-0-0".
Hope this helps
John
Sep 17, 2011 | LG 42LG50 42 in. LCD HDTV
Hooked up the tv to my existing cable and it will only receive 15 channels. All my other tv's receive many more like 100 +. I did the auto detect when I hooked up the tv and 15 is all it detected.
This is a fairly common issue, either the TV has the upper channels blocked or the signal in that room is just not as strong so a quick scan is passing them over. I will give you the steps to remedy both issues. If the channels show up weak or snowy or not at all after trying these steps you may need to install a booster where you current line splitter is but try these steps first as the TV can easily compensate for a slightly low signal.
Enter the TV Menu, Select TV, Select Channels, Select Master List. Look for channels with X beside them, if they have X they are blocked, simply move down the menu selecting each one to remove the X.
Now that you have verified or corrected your master list select Turn on Additional Scan from the scan menu and run a new scan. The additional scan will take a lot longer but will take more time on each channel and should find them even if the signal is a little low.
Hope this helps FixYa,
Chris
Jan 04, 2011 | Vizio M220VA 22 in. LCD HDTV
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 42HP95 Television
Tip
I hope that helps.
on Jul 03, 2010 | Toshiba 50HP95 50 in. Plasma Television
I have a toshiba standard tv 27A33. it has one
This television uses a feature called a V-Chip which allows parental control and consequently blocks channels of your choice. This set is approximately 7 years old and the owners manual is no longer available on line. You can over ride any blocked channel by entering the menu, select parental controls and enter the "secret" code. How one channel got blocked is a mystery. I suspect someone was exploring it's features when they accidentally blocked a channel. Normally the system control works flawlessly and if you have no other symptoms you need to reset that channel. That info is in the owners manual that came with your set.
Mar 30, 2010 | Toshiba 27A33 27" TV
V-chip block on Jensen JE2269 Digital LCD_TV
If it helps any, I had the same TV with the same Weather Channel issue, also on a boat. It took months of constant contact but they ended up replacing my TV with a different model and after several months with the new one I have had no problems. This started in 2007 (I was the 11-12-07 post) and it took jumping through a few hoops to get the replacement. Good luck.
Oct 19, 2007 | Televison & Video
How to block a TV station with my control
well there should be a parental control on there
Apr 10, 2007 | JVC AV-20FD24 20 in. TV/DVD Combo
Televison & Video Logo
Top Hisense Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Electro Med Services...
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
