Question about Whirlpool Dishwashers
Whirlpool dishwasher stuck in cycle
Stuck in cycle
2 Suggested Answers
  • 867 Answers
SOURCE: whirlpool dishwasher
So i assume it fills with water then just sits there? this would be a wash motor problem,
It could be a blockage in the wash motor or an electrical issue.
Some of the whirlpool models have a start capacitor on the motor which can fail and would stop the motor from starting.
If you remove the lower front kick panel and look at the motor and if you see a white tube attached to the motor with 2 wires it is the capacitor which could be faulty.
If there is no capacitor then it is most likely an internal motor failure which would require a new motor.
Posted on Mar 07, 2012
Testimonial: "this doesn't solve my problem entirely.....but it gives me direction. As the dishwasher cost about 400 bucks and the motor alone would cost about 200, perhaps plus labor or LOTS of time on my part, I may be leaning toward just getting a new one. Thanks Very much"
Mod DP1040XTXQ6 clean light does not come on
If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control board
God bless you use the VOM..
Apr 05, 2013 | Whirlpool DP1040XTX Portable Dishwasher
Dishwasher stuck in wash cycle
see this causes and fix it. God bless you
.Float Switch
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer /electronic control 10_17_2012_1_06_02_pm.jpg
Oct 16, 2012 | Whirlpool Dishwashers
Need reset sequence for dishwasher
see this causes, use the common sense.God bless you
Dishwasher Stuck in a Cycle If your Dishwasher is stuck in a cycle check the following
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. Check the tutorial and the video for checking this part.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace the timer / electronic control.
Sep 19, 2012 | Whirlpool DU1055XTS Built-in Dishwasher
My Whirlpool dishwasher is stuck on the clean cycle?
If it continues to run without any alarms or flashing light, I would assume the heater is packed up. It is looking for the water to reach the correct wash temperature.
Try to run on the cold water cycles and see if there is any difference.
Mar 21, 2011 | Whirlpool Gold 24 in. Built-In Dishwasher...
Whirlpool dishwasher stuck on prewash cycle
the eprom memory is brocken,the main board must be changed.
Feb 14, 2010 | Whirlpool 24 in. ADG7952 Built-in...
Whirlpool Dishwasher Stuck in Cycle
Hello FishNYC22, we're sorry to hear about your Dishwasher. Unfortunately we are not able to provide technical assistance. If you would like for us to schedule service for you then please email us your name, phone number, address, the model and serial number and the website you were contacted on (Fixya.com) to Whirlpool_Digital@Whirlpool.com.
May 09, 2017 | Whirlpool DU806CWDB Dishwasher
Control panel on my whirlpool dishwaher not functioning properly
The console (control panel) is defective. The buttons may be getting stuck and/or are corroded.
Feb 20, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Whirlpool d/w is stuck on wash cycle
Is it filling and emptying at the same time???? If not could be a heat problem. How long do you leave it running for?
Jan 03, 2008 | Whirlpool 24 in. DU1050SS Built-in...
Dishwashers Logo
16 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Mike
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
