Question about Powerware Computers & Internet
Lg rt44na13rb schema - Powerware Computers & Internet
Cerco schema Asus serie A2000 modello A2H. Grazie
Schema di ASUS serie A2000 sono non disponible. Che si desidera? Cosa e lei problema con suo computer?
Mar 09, 2015 | ASUS Computers & Internet
I need schema for panasonic tx21p22x
I've it with me, but can't send to you by this window. It is in PDF format.
Feb 20, 2013 | Televison & Video
Search diagram schema
infocus will not give out scematics. besides, they have other companies make their circuit boards, so they wouldn't have them anyway.
Jan 11, 2010 | InFocus ScreenPlay 5700 Multimedia...
Schema diagram samsung syncmaster 551v
Hi and welcome to FixYa,
Initially, pls try here.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 10, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Schema
In AD, the schema is the list of "properties", or attributes of each item an AD "object".
There are different object types - user, computer, group, and so on. Some properties exist for all objects - "name", "create date", etc. Other properties only make sense for certain objects - a user has a "phone number", but a computer object does not.
So the schema is a list that says what "object types" are defined, what "properties or attributes" are defined, and which properties are valid for which objects.
Jul 20, 2008 | Microsoft Windows Server Standard 2003 for...
Schema classes and attributes
Every directory object you create is an instance of an object class contained in the schema. Each object class contains a list of associated attributes that determine the information the object can contain. Classes and attributes are defined independently, so that a single attribute can be associated with multiple classes. All schema classes and attributes are defined by the classSchema and attributeSchema objects, respectively.
Classes
ClassSchema objects are used to define classes in the schema. A classSchema object provides the template for building directory objects of that class. Examples of classSchema include User and Server. A classSchema object contains, among other things, the following information:
Class type (structural, abstract, or auxiliary)
Common name and Lightweight Directory Access Protocol (LDAP) display name
Lists of the "must contain" and "may contain" attributes for instances of the object
Relative distinguished name attribute
A list of possible parent classes
Class types
Three different types of classes exist in the schema:Class type Purpose
Structural
Used to instantiate objects (users, servers and so on) in the directory.
Abstract
Provides templates for deriving structural classes
Auxiliary
Contains predefined lists of attributes that can be included in structural and abstract classes
Attributes
AttributeSchema objects are used to define attributes in the schema. An attributeSchema object determines the allowable contents and syntax for instances of that attribute in the directory. Examples of attributeSchema include User-Principal-Name and Telex-Number. An attributeSchema object contains, among other things, the following information:•
Common name and LDAP display name
Syntax rules
Data constraints (single versus multivalued, minimum, and maximum values)
Whether and how the attribute is indexed
Jul 17, 2008 | Microsoft Windows Server Standard 2003 for...
Monitor LG FLATRON E700SH
Sir,
I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query.
Thank's
Feb 21, 2008 | LG Flatron Ez T910BU 19" CRT Monitor
Schema de montage de disque dur sur la PStwo
Bonjour,
Je M'appele Josh
Englais
Merci - Josh
Jan 21, 2008 | Sony PlayStation 2 (PS2) Console
Computers & Internet Logo
Top Powerware Computers & Internet Experts
Vassilis Chamaidis
Level 1 Expert
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
