Question about Baby Gear
How to remove front wheel on babzee stroller - Baby Gear
  • 173 Answers
SOURCE: GRACO STROLLER FRONT WHEEL BROKEN
Please contact Schwinn®/InSTEP at 1-800-242-6110 as Schwinn/InSTEP can repair it or send out replacement parts.
Posted on Jan 23, 2008
SOURCE: graco quatro wheel removal
i have the graco quattro tour sport, i put it together & noticed the swivel lock was missing! I have to take the wheel back tonight but i had already put it on the pram! after reading 'Adorough's' comment i had good look at the wheel to figure out how to get it off. 1) fold the pram up and stand it so the front wheels are up. 2) if you look round the back of the front wheel you should see a round 'pin' which is set back, you well need a pen or something pointy to press the pin in & pull the wheel! That worked for me.
Sarah
Posted on Apr 07, 2008
you can get the wheel here
http://www.amazon.com/Graco-Quattro-Deluxe-Stroller-Renaissance/dp/B000CEXO0C
Posted on Jun 18, 2008
  • 20 Answers
SOURCE: problem with front wheel of jane 3-wheeler stroller
The front wheel swivel has become a problem with some strollers that are a little longer than the standard three wheel stroller. This has been happening with the new Phil & Ted's Vibe as well.
This can be approached in a few different ways. The easiest is to take the wheel off completely and properly lube the connection pieces. You can use a standard axle grease, or WD40 if you have some in your home. When the tire is properly lubed, re-attach it. This should take care of the problem.
If that does not work, the wheel's inner tube might be/have been over-inflated. When this occurrs, a part of the tube bubbles and causes the wheel to wobble while being pushed. Deflate the tire slightly and see if this helps. If the tube has been over-inflated for some time, it may be necessairy to completely replace the tube - you can do this at most bike shops that sell replacement tubes.
If this does not stop the tire from wobbling, please feel free to contact us anytime.
strollerinfo@gmail.com
StrollerInfo
www.StrollerInfo.com
Posted on Oct 02, 2008
Contact Graco directly...the will send out a free replacement wheel. The whole unit comes together and snaps on.
Posted on Feb 08, 2009
Instructions on how to fold
Kindly follow the steps to below to fold the stroller:
  • Use the ball of your foot to push down on the brake lever, located near the rear wheels of the stroller. Gently push on the stroller to confirm that the brakes are set. Grip the front edge of the stroller's canopy, if present; pull the canopy back towards the rear of the stroller.
  • Push the tabs securing the ends of the harness straps to the harness buckle. Pull the straps aside and remove the child from the stroller.
  • Kneel down next to the stroller's front wheels. Locate the locking mechanism set in between both pairs of front wheels. Use the locking mechanism to disable the swivel feature on the front wheels.
  • Pull the stroller's seat back down to the lowest position; some models may feature locking mechanisms located on the sides of the stroller or built into the handlebar. Lift any latches securing the sides of the stroller in place.
  • Push the handles of the stroller downward. Push the rear section towards the front of the stroller until the device is fully folded. Clip the storage latch located on the side of the stroller to the side of the handlebar.
Apr 24, 2016 | Baby Gear
How can I fold?
Kindly follow the steps below on how to fold the stroller:
Apr 16, 2016 | Baby Gear
How do I let the stroller down?
    Kindly follow the steps below to fold the stroller:
Sep 09, 2014 | Evenflo Aura Traditions Travel System...
I need a detailed instruction on how to fold a combi stroller
1. Lock both front swivel wheels. Not locking the swivel wheels before folding the stroller can damage the wheels 2. Empty the basket. 3. Fold the canopy by lifting the canopy levers. 4. Remove your player from the canopy. 5. Lift and hold the folding levers up on both sides of the handle. 6. Tilt the stroller onto its back wheels and roll it forward and then pull it back quickly and the front guardrail will fold inward. 7. Turn handle inward with an underhand hold to latch and lock.
Jun 02, 2011 | Combi Cosmo DX Stroller
How can i take off the front tire on stroller?cant take off the front tire. Its a graco brand.
Hi, Graco strollers all vary. Some wheels can and cannot be removed. Quickest thing to check is the undercarriage of the wheel. Front wheel ----------------- Place your buggy in front of you Then push it onto it's rear wheels The front wheels should now be up in the air Check underneath where the wheel attaches itself to the chassis Some wheels just have a simple lever you push and the wheel releases Others there's a round rod with a **** running through the middle similar to a peg if you have a pair of long nose pliers you can squeeze them together and pull the wheel towards you Others just cannot be removed peg just won't release itself or the wheel is bolted onto the chassis I hope this information proves useful. Liz.
Mar 12, 2011 | Baby Gear
How do I fold my jogger (The Twinner II-16). I bought it used without a manual. Can manuals be located on the internet? Thanks
There are 4 pins that need to be pulled. 1st Flip the stroller over and remove the 2 back wheels...sqeeze the metal piece by the wheel and pull the wheel straight out. Pull the 1st 2 pins, they are between the back wheels and the front wheel, on either side. The bars these were holding in place will swing up. Then pull the 2 front pins (by the front wheel) and flip the front tire up. The front wheel also comes off but isn't neccesary.
Sep 15, 2010 | Baby Jogger City Twinner Stroller
Removing front wheels
Best position for use it for the beach is folding front wheels, turning chair towards you and pull stroller instead of pushing it.
Check video at min 6:30
Jul 23, 2010 | Bugaboo Cameleon Stroller
The front wheels on my Maclaren XLR keep locking up
When you click the wheel release (to make them go onto swivel mode) press a little harder as it sounds like you haven't fully engaged the release mechanism.
I hope this helps.
Oct 07, 2009 | Maclaren Vogue Umbrella Stroller
I don't know how to remove the front wheel in order to install the new spare one
Remove captive washer (chrome button to you) by force, remove and replace with new washer if broke.
May 30, 2009 | Maclaren Triumph Umbrella - Navy Stroller
Stroller pulls to the left
It's a wheel alignment issue - I had the same issue & my husband fixed it. Try removing the front wheel & reattaching it. If that doesn't solve the problem, keep adjusting the front wheel slightly until the stroller no longer veers.
Jan 10, 2008 | Zooper Cool Zone Buddy Stroller
Baby Gear Logo
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
