Question about Fender Mustang II 40 Watt Electric Guitar Amp
Fender Mustang II power goes off when the output is maximum
IN this Mustang II, The power goes off when the sound(volume) is increased . I ve checked for burnt n shorts but its clean,I suspect the output I.C TDA7294 is faulty,shall i replace the I.C check some thing else. Can anyone help me with it .
  • 3 Answers
SOURCE: Fender bass guitar shorting out
it sounds to me that you need to fix the input on the bass (where you plug in), sometimes just tightening the nut will do it, or buying a new one and replacing.
Posted on Jul 22, 2009
  • 5603 Answers
SOURCE: SPEAKER OUTPUT CHANNEL FAULTY, TWO MIKE CHANNELS DOWN
These are a real pain to open. You have to remove the front panel to remove a shield to remove the back amplifier power supply area. The power supply is a switching type and has lethal voltages present. Working on this should be done using an isolation transformer. With your symptoms, it is likely one side of the power amp MAY be blown, but do check that the wiring hasn't fallen off and the jack itself. Two pairs of wires come from the power amp to the front panel jacks. document location of ALL the cables you disconnect as they CAN be confusing to restore.
Posted on Jul 26, 2009
  • 506 Answers
SOURCE: Fender Hot Rod Deluxe. Turns on, sounds very good
More than likely a bad solder joint. Where is the next question. How confident are you with voltage measurments? The rails in tube amps are high and can kill you so if you are not inclined to do so please don't. The reason I suspect a solder joint is that it is a failure over time, cold solder joints expand and contract with heat. When they heat up they break connection. Not saying 100% that is your problem but it is very likley.
Posted on Dec 14, 2009
Testimonial: "Hey thanks for responding!...I am not savy at this so I will take it to an expert before those tuibes blow on my face. Thanks again!"
  • 5603 Answers
SOURCE: My fender hotrod deluxe still produces some sound
There are FOUR controls that affect the volume of signals going through plus the tone controlling ones.
and your
You used the word "volume". Based on the schematic, and assuming you are talking about the control labeled "Volume" and not reverb, master or drive, I can give some hints.
OFTEN the resistance element in pots MAY have a bit of overtravel which can act like your unit, but USUALLY not as far upscale as yours appears..
If the control you are refering to is not the "Volume" but one of the others, then there are other things to look at.
The action you describe would be one of probablly an inverse signal leaking through and when you go up to 1.5 you are actually cancelling the leakage.
I SUSPECT you may have a cracked circuit board in the vicinity of the input jacks that is leaking the inverse phase of the input past the input triode tube stage.
Board cracks OFTEN occur near input jacks because people trip over cords... (save yourself by running cord through a handle before plugging in the plug)
This should be easy to find. Connect an audio generator to the input and use a scope to find the problem. Without a scope, use a capacitor to "ground out" suspected signal paths.
On the schematic they show a resistor (10 ohms) from ground near the input to the pot bracket. I have personally SEEN capacitive coupling to pot brackets feeding into the amps from this source sending in stray signals.
If this is connected to other equipment, a ground loop could cause problem, so test with nothing but the guitar connected.
Posted on Apr 30, 2010
  • 94 Answers
SOURCE: Mi fender rot rod deluxe has almost no power, the
CHECK VOLUME CONTROL BUTTON.
Posted on Oct 25, 2010
Im running my pc through amp but tweeters start to pop at hight volume .. is there a fault with amp or pc ??
It sounds like you are over driving the speakers. Recommend reducing PC audio output, as it is amplified for the computer speakers. Use the amplifier for volume - not the PC.
Mar 18, 2015 | Audio Players & Recorders
Samson G-Track recording volume issue
Try using a computer with a dedicated sound card, not an onboard sound chip. A condenser mike can't provide very much power on its own, and requires power from the attached receiver/amplifier.
Jun 04, 2008 | Samson G-TRACK USB RECORDING MICROPHONE...
How do you increas monitor sound?
Check the settings for audio volume control on the monitor side. Also, check the individual settings for the audio for applications and system sounds on the OS side. Or call ViewSonic technical support for assistance.
Jun 15, 2014 | ViewSonic Computers & Internet
Mustang 3 amp, no sound
first check with fender, fender.com go to amps they should have a ---Ask program-- there.
Nov 12, 2013 | Fender Mustang 3 Modeling Amplifier 100...
ON my fender mustang II as I switch channels with my footswitch there' s a lag before the sound comes up
Possibly you are holding the switch down???... it MAY activate on the release of the switch. Try quick tap on switch.
I tried to find schematic to analyze this but could not find one.
Apr 06, 2011 | Fender Mustang II Guitar Combo Amplifier...
Fender ultra deluxe amp volume max out a number 7 volume control. will not get any louder
It is likely that the amp is flat topped at the 7 setting. When the amp is producing the maximum voltage output it is capable of, that is ALL you can get out of it... The numbers on the dial mean NOTHING and are only relative. If you have high output guitars you might find the maximum might only be 3 on the dial for example...
If you need it louder, get a bigger amp and speakers. You should ALSO get a sound meter and follow OSHA guidelines for sound exposure... I know several musicians that now are nearly deaf because of being exposed to high sound levels... their music careers are now gone as they can no longer hear well enough. You need to protect your hearing for the long term. Great musicians don't need loud, but quality and inovation in their music.
Jan 07, 2011 | Music
How to increase max vol further on, of my laptop gateway mx6956 as it is horribly low
Hello, You can increase the volume of your laptop by, first check the speaker and headphone icon whether it is set to 100%.You can see it in the system tray or by the right hand side at the bottom of your screen or at the control panel,click on SOUND and increase the volume. Note the software you are using like window media center, VLC player, real player and the likes should also be increase to maximum, then if your computer has an external control for the volume, make sure you increase it to the maximum. HOPE THIS HELPS
Nov 23, 2010 | Gateway MX6956 Notebook
I have a fender guitar amplifier, and I can't get any low volume out of it. At level 1 on the dial the volume is sooo loud - no gradual increase at all. It's impossible to play softly. What's going on?
It sounds like (pun intended) the volume pot just needs to be replaced. A good pot is worth about $5 and then you just need to solder it in. That tends to be the tricky part if you can't solder. It takes longer to heat up the iron than it does to do the job. I'd assume this happened either after it had sat for quite a while or after a move.
What can happen is the wiper or the resist inside the pot breaksor even the wire to the pot breaks and there goes your volume control. Depending on what model of amp you have you don't want to run it like this for too long. You can't fix the pot but you do need to replace it. I would assume it sounds like it is either full on or doesn't change the volume at all.
This is one of those maintenance things you should check for from time to time. you may notice that the pots get noisy or inconsistent for a while and then they do this kind of thing.
The attenuator will kill the volume but that doesn't actually fix the problem you have. When the amp is running properly you should be able to get quite a low volume. If you need to run it harder so that it gets into the distortion range then a attenuator will drop the volume down to a practice at home non eviction volume ;-]
May 03, 2010 | Music
Why do the volume numbers on old receivers start
This type of calibartion is known as a logarithmic scale.
The numbers refer to decibels below the maximum output of the amplifier section of the reciever, or decibels of attenuation (making smaller/quieter).
Without going through logarithim theorey, the logarithim (base 10) of 1 is 0. So if 1 is the maximum output of the amp, as you turn the knob down from maximum you are adding more and more attentuation to the output (relative to maximum) and so the loudness of what you hear goes down, even though the number on the scale is going up !
Most peolpe associate decibels with sound levels, but anything can be measured in decibels, so long as there is soemthing to reference it against.
Nov 04, 2009 | Pioneer VSX-D409
1974 FENDER TWIN REVERB HAS NRE TUBES NEW FILTER CAPS AND WAS REPAIRED BY RETIRED AUTHORIZED FENDER TECH. PROBLEM AMP HAS VETY LOW OUTPUT UNTIL YOU CRANK IT TO 8-10 THEN IT SOUNDS HORRIBLE DISTORTED AND...
This sounds like a power supply problem. The high voltage for the tubes is not right. Either you are missing an amplification stage because this or one of the coupling caps is faulty. I'd have to see the unit itself to give you any more details.
Dan
Jul 22, 2008 | Audio Players & Recorders
Fender Mustang II 40 Watt Electric Guitar Amp Logo
32 people viewed this question
Top Fender Audio Players & Recorders Experts
Henry  Thomas
Henry Thomas
Vito Vacirca Jr.
Rick Moore
Rick Moore
Are you a Fender Audio Player and Recorder Expert? Answer questions, earn points and help others
