Thank you,,,,problem fixed,,,shes puring like a kitten
Tip
Feeding a kitten
Bringing a kitten home is very exciting. You have a new friend at home and it looks so adorable. First thing you must know is that kittens grow fast and they grow a lot! Its' weight can double or even triple during this time. That's why they need much more calories than adult cats and should be fed more times per day(4-6 times). If you find a kitten that's less than four weeks old, feed it kitten milk replacer, not cow's milk, as it doesn't have the all the required nutrition. After four weeks of mother's milk, kittens make their transfer to kitten food, and it's time for you to feed it right. During this time, emphasis should be on high quality protein (meat, poultry or fish), vitamins, and minerals. Fat and carbs should be given in the same amount as for adult cats.My suggestion is to buy high quality products specifically for kittens in pet stores like Petco and online at websites like pet food direct (these products have everything the kitten needs). What should you not feed a kitten? Under no circumstances should you feed a kitten dog food, chocolate, cooked bones, or cow's milk. Cats should receive kitten food pretty much from the 4th-5thweek until they are one year old.
on Aug 06, 2012 | Cats
Gameboy advance catz instructions
In beginning, your kitten won't let you to pick it up. You may have to use CARRY quite few times before actually picking up your kitten. When you do "CARRY" on your kitten, it will gain some stats. But it's only very low number, usually FRIEND / LOOKS / MOOD will gain from it.
Jul 18, 2013 | Video Game Consoles & Games
Is Silica gel litter safe for kittens?
I would avoid using Silica gel litter in a kittens litter box and wait until they are slightly older. Young kittens are prone to tasting cat litter (simply out of curiosity). Silica crystals can be harmful if ingested and for this reason alone should not be used.
Aug 14, 2012 | Cats
I have a kitten that has climbed into the dash board. How does my husband remove the dash? (That's what I get for trying to be a good person..LOL)
Which side is the kitten on, if it's on the passenger side you can remove just the glove box to gain access, if it's on the drivers side you can remove the bottom kicker panel to gain access from the bottom of the dash so you don't have to remove the whole dash. If the kitten made it's way behind the radio, you can remove just the trim around the radio and then remove the radio to gain access behind the radio.
Thank you for using fixya and please keep being a good person LOL.
Jun 11, 2010 | 2005 Ford Freestar
My compaq laptop was working just fine this morning. When I left for work I went into my room and found my kitten sleeping on it. A bunch of windows were up and I closed them down, but when I tried typing...
This is NOT as uncommon as one may think, what happens when that happens is the combined heat from the ON PC and the Kitten heat, usually Overheats the PC, and causes it to fault... sometimes permanently... What you can try is remove battery & power leave it say overnight, then replace batteries and power supply, cross fingers, and power on...NOW, if you are lucky, it may be OK, but if as I suspect it may be heat damaged beyond repair sorry... You are going to have to get that Kitten to get a job to pay for it all, and tell the kitten NOT to sleep on any powered on laptops.. this really is unacceptable Kitten behavior..lol PS: Sometimes it is just the RAM that fries...?? maybe replace a stick of RAM? But be careful not to spend good money after bad.
Mar 06, 2010 | Computers & Internet
Accidentally donated a kitten
there is no way you can grt another one tho
Jan 13, 2009 | Crave Entertainment Purr Pals for DS
Expected more speed
Try clearing out the crank case ventilation..which is a pipe from the rocker cover to a swirl pot on top of the engine..it can get clogged with sludge, it worked on my mates vauxhall..
Dec 05, 2008 | 1991 Honda CRX
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
