Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
My opener beeps every 15 seconds. How can I stop this?
Thank you
    President:
  • 3,197 Answers
What is the model of your opener. Do you have an autocloser?
Posted on Jun 18, 2009
What are the lyrics to God is good to me by luther barnes
Looking back, over my life
I can see, how far I've come
I have had, some cloudy days
But oh the Lord has brought me, from a mighty long way
I've been up, and I've been down
But you never left me, you were always around
You stood by me, yes you did, through thick and thin
And I can truly say, that you've been my closest friend
Lord I know you've been so good to me
You've been so good
You've been so good
And I just want a thank you
I thank you
Oh I thank you Lord because you've been so good
You've been so good, so good
Let me say this right here
When I was down , I couldn't see my way
You stepped in and you made a way
That ain't all you done
When I was lost, I couldn't see the light
But Lord You stepped in, yes you did Lord, and you made my pathway bright
You've been so good
I know --you've been good to me
You've been so good
Right now Lord, I just want a thank you
I thank you
Oh I thank you Lord, Oh Lord I want a
thank you, Let me thank you I want a
thank you Lord
Yes I do Lord, Let me, thank you Let me
thank you
thank you Lord
Cause you've been so good, so good
So good
Chorus continues
So good, so good
Mar 31, 2017 | The Computers & Internet
Tip
Thank you, Thank You, THANK YOU!!!!!!!! You Helped me so much, If i knew who you...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Jul 18, 2008 | T-Mobile MDA
What is the procedure to stop the beeping when wash is done. Not only does it beep it keeps on beeping every 30 sec.?
My one beeped every 30 seconds to tell me that the cycle was finished.It should stop itself after about 15 minutes,or just turn the machine off.
Jun 08, 2014 | Bosch Classixx WFL 2066 Front Load Washer
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
I have a 6 y.o. whirlpool fridge wbm 46 model that's started to make a loud buzzing/whirring noise every 15 minutes or so ( only lasts a few seconds each time). It's started doing that noise in the last...
Hi
The sound from your refrigerator can be caused due to various reasons,please check this link bellow to troubleshoot your problem:-
http://www.repairclinic.com/Refrigerator-Troubleshooting?red=Refrigerator-Repair-Help#itsnoisy
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 02, 2011 | Whirlpool Refrigerators
My Kidde Sillouette won't stop nuissance beeps. I originally set it off by opening oven door and the manual is no help...
If the detector is within 15-20' ' of you oven, it's going to alarm every time you open the oven door, when the range is on. Cleaning and moving the detector is your only solution. Not sure your detector has one, but if it has a reset button, press it for 5 seconds and release it. That should stop the chirping.
Mar 06, 2011 | Kidde Silhouette AC Hardwire Smoke Alarm...
Every 15 seconds the refrigerator beeps and i noticed the refrig light was out. I replaced the bulb which is now working but it still beeps every 15 seconds. tThe temperature in both the frig and freezer...
I don't know if you have an ice maker but when my ice dispenser is full my fridge beeps because the ice can no longer go into the tray because it is full so I have to empty the tray. and the beep stops it also beeps when the water filter needs changing. I hope this helps
Feb 23, 2011 | Refrigerators
Gives beeping noise at regular intervals
On my Danby this was a reminder that you had nuked something and had left it in there. If it stops when you open the door then this is all it is. It should beep about once every 15 or 30 seconds.
Other than that I don't know of any other regular timed beep that my Danby made.
Jan 23, 2011 | Danby DMW1153 Microwave Oven
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
202 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
