Question about Lexmark X644e All-In-One Laser Printer
Lexmarx x644e dark copy
Copy completely dark
    Champion:
  • 312 Answers
Check the transfer roller, cartridge
Posted on Apr 14, 2014
Check toner cartridge
The error 200.16 on a Lexmark X644E indicates that the main drive motor is not working due to high mechanical load due to paper jam or bind. The recommended actions are:
- Make sure paper path is clear.
- Check motor to system card connections.
- Replace transport motor.
I suggest you contact our Technical Support Hotline on 1-800-539-6275.
Jul 26, 2012 | Lexmark X644e Laser Printer
No Nvram printer en impresora lexmark x644e
2 options:
1 - Turn off the machine and unplug the power cord leave it unplugged for 10 minutes turn it back on.
"probably not going to resolve it" - T
2- you will need to replace the system board / formatter. this is the board where you plug in the usb/ phone line/ network cable.
"This should definitely take care of it based on my experience with this machine."
Oct 19, 2010 | Lexmark X644e Laser Printer
How to send hard copy to email
Perhaps the printer's User's Guide will be able to guide you. To download, click on this link: http://bit.ly/bwZb5e. Scroll to Email, Page 33, for instructions on how to email scanned documents to one or more recepients. Hope this helps.
Jul 15, 2010 | Lexmark X644e Laser Printer
Copying very dark lines down page.
hi just clean complet scanner mirrors and charge and transfer crona wires if solved ok if not solve just replace the drumcleaning blade.
thanks
May 14, 2010 | Toshiba 1370 Black and White Copier
How do I access the menu/control panel?
MFP and scanner settings can be changed several ways: through the MFP control panel, the software application in use,
the print driver, MarkVision™ Professional, or the Web pages. Settings changed from the application or print driver apply
only to the job being sent to the MFP.
Changes made to print, fax, copy, and e-mail settings from an application override changes made from the control panel.
If a setting cannot be changed from the application, use the MFP control panel, MarkVision Professional, or the Web pages.
Changing a setting from the MFP control panel, MarkVision Professional, or the Web pages makes that setting the user
default.
Menus (A key is shown on the button.) Touch to access the menus. These menus are only
available when the MFP is in the Ready state.
The Menus button is on a gray bar called the navigation
bar. The bar contains other buttons described as follows.
Understanding the copy screens and options
Copy From:
Opens a screen where you can enter the size of the documents you are going to copy.
Touching any of the paper size icons on the follow-on screen will make that your selection and return you to the
Copy Options Screen.
When Original Size is set to Mixed Sizes, you can scan different size original documents (letter and legal size
pages). They will be scaled automatically to fit the selected output media size.
Copy To: Opens a screen where you can enter the size and type of paper on which your copies will be printed.
If the size settings for Copy From and Copy To are different, the MFP will automatically adjust the Scale setting to
accommodate the difference.
If you have a special type or size of paper that you'd like to copy onto that is not normally in the MFP paper trays,
you can select MP Feeder, and manually send the type of paper you want through the MP feeder.
When using Auto Match, the MFP will match the size of the original document as specified in the Copy From box.
If a matching paper size is not loaded in one of the paper trays, the MFP will scale the copy to fit loaded media.
Scale: Creates an image from your copy that is proportionally scaled anywhere between 25% and 400%. Scale can also be
set for you automatically.
When you want to copy from one size of paper to another, such as legal size to letter size, setting your Copy From
and Copy To paper sizes will automatically change the scale to keep all the original document information on your
copy.
Touching the arrow to the left lowers the value by 1%; touching the arrow to the right increases the value by 1%.
Holding your finger on an arrow makes a continuous increment.
Holding your finger on an arrow for two seconds causes the pace of the change to accelerate.
************************Darkness: Adjusts how light or dark your copies will turn out in relation to the original document.****************** here is the link to the full pdf manual for your unit: http://www.lexmark.com/publications/pdfs/2007/x644e/en/ug.pdf#xml=http://support.lexmark.com/lexmark/index?page=answeropen&segment=SUPPORT&userlocale=EN_US&locale=en&type=open&searchid=1270220491739&answerid=16777216&iqaction=6&url=http%3A%2F%2Fwww.lexmark.com%2Fpublications%2Fpdfs%2F2007%2Fx644e%2Fen%2Fug.pdf&productCode=&highlightinfo=106955230,537,548
Apr 02, 2010 | Lexmark X 646e MFP - multifunction ( B/W )...
Lexmark Printer x644e, Geting Blue Screen of Death
allen_logan
To be able to properly address your BSOD I will need some info from the BSOD. The link below will show you the info that I need.
http://www.fixya.com/support/r4443711-blue_screen_death_bsod_important_info
Thanks
Issken
Feb 02, 2010 | Lexmark X644e All-In-One Laser Printer
My lexmarx printer has weird writing on the LCD screen i dont recognize it... how to reset the printer to factory defaults
How to Change the Display Language on a Lexmark X7310/X7350 ID: ENUS24252
  1. From the control panel, press Copy Mode.
  2. Press pattlnk_892006_1633-menu.gif.
  3. Press pattlnk_892006_1633-up.gif or pattlnk_892006_1634-down.gif repeatedly until pattlnk_892006_1636-across.gif appears next to 9.
  4. Press pattlnk_892006_1637-correct.gif. The right arrow symbol ( pattlnk_892006_1637-across.gif ) appears next to 1.
  5. Press pattlnk_892006_1638-correct.gif.
  6. Press pattlnk_892006_1638-up.gif or pattlnk_892006_1638-down.gif repeatedly until the language you require appears on the display.
  7. Press pattlnk_892006_1638-correct.gif to save the setting.
Jul 08, 2009 | Lexmark X7350 All-In-One Printer
Lexmarx X5150
see on this site. I had the same problem before 15 minutes and it helps :)
http://blog.forret.com/2006/02/lexmark-printers-with-hardware-error-0502/
Feb 15, 2009 | Lexmark X5150 All-In-One InkJet Printer
Lexmark x644e LCD Display Inverted(Upside Down). Restored factory defaults but that did not help.
You will likely need to replaced the LCD panel
Lexmark p/n: 40x0494
You can order it here at www.fastprinters.com
40x0494
Dec 08, 2008 | Lexmark X644e All-In-One Laser Printer
first thing i would do is update firmware
http://support.lexmark.com/static/229-1-0-530.html
Dec 18, 2007 | Lexmark X644e All-In-One Laser Printer
Lexmark X644e All-In-One Laser Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
