Question about Fisher Washing Machines
Water is dripping into washing machine when not on
The water seal is damaged open it and replaceit
Posted on Jun 18, 2009
gittos73
  • 244 Answers
SOURCE: water in my washing machine
u will need to replace the water solenoid that is letting the water in it is a fault that does occur with all solenoids,theses are were the water pipes connect to
Posted on Sep 10, 2007
SOURCE: Hoover automatic 830 washing machine - leaking from under bowl
I had a Hoover 830, many years ago, it went for 15 yrs. solid. :)
Now I have a Fisher & Paykel IW 812 Intuative Washer
they are heaps nice too ... maybe time to get one of them?
maybe?
Posted on Jan 09, 2008
jbjaxiis
  • 95 Answers
SOURCE: Whirlpool washing machine, extra large
it sounds is if you have a possible crack in the water supply area. if the hoses are good, tight and dry, inspect the housing base they screw into.
Posted on Aug 16, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
mgprice
  • 744 Answers
SOURCE: whirlpool washing - clothes are still dripping wet at end of wash
Hello, sounds like you have a problem with your clutch assembly, tilt the machine back and access it from underneath..if you see oil at the base next to the motor this means your transmission is going bad and the oil has got into the clutch assembly..If this is the case you may as well go buy a new washer now since it is really expensive to replace the clutch and transmission. If however you don't see any evidence of oil underneath your going to need to replace the clutch assembly. If you have mechanical experiance by all means try yourself...if no experiance get a tech in to do it :) thanks for using fixya! Mike
Posted on Sep 16, 2009
My washing machine is filling up with water when off ,,i'v looked inside soap dispenser drawer I can see drips of water coming in.
you have a faulty water valve turn the cold water off at the main see if the water is still dripping in if it is it will be the hot water valve replace faulty valve they are fairly cheap to buy best to replace both piece of mind you can buy them on line and are easy to replace euro spares will have them if you still need help let me know.
Nov 23, 2012 | Indesit W 123 Front Load Washer
Water leaks into my smartdrive 058 machine throught the wash cycle and when the machine is switched off.
you need a new water valve for the unit. The solenoid is getting stuck in the open position (at least partially) and allowing water to continue to come through even after the water valve is no longer energized. This can be caused by normal wear and tear or sediment from your pipes getting stuck in the valve. This is especially true if you have well water or have recently had any plumbing work done in your house like a new hot water heater or something like that installed.
Nov 16, 2012 | Fisher and Paykel Washing Machines
Washing machine drips water from top of tub.
THE WATER INLET FILTER IS MISSING , SO IT ALLOWS SOME FRAGMENTOF DIRTS INTO THE SYSTEM......U HAVE 2 LOSSE WATER INLET VALVE AND CLEAN
Feb 24, 2012 | Fisher and Paykel Washing Machines
Water leaking (dripping) into the drum when machine is off. Drip is coming from where water dispenses into the machine to fill the drum.
Hi just read your posting.The fault with your machine is a faulty water valve.1st turn off the cold tap to the machine and leave for a couple of hrs.If the dripping stops you have a faulty cold valve.If the dripping does not stop then turn off the hot tap and that should stop the leak.Either way to fix this fault a water valve must be replaced.Or you can stop the drip by just turning the taps off after the washing has finished.Hope this helps and please reply for further help if needed.
Jun 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
LG Top Loader washing machine leaking when not in use
Remove the top of the washing machine cover to access thehot and cold water solenoids. Disconnect power to the washer and wioe clean around the the manifold. See where leak is coming from . it could befrom the solenoid valves threads.
Nov 25, 2017 | LG WFT1071TP Top Load Washer
Water keeps dripping after machine is turned off.
turn hot water tap off if it still drips replace cold water inlet valve if it stops replace hot water valve
Aug 14, 2009 | Maytag PAV2300 Top Load Washer
Leak
Your inlet water valve where the fill hoses attach is stuck open.
Mar 18, 2009 | Washing Machines
Whirlpool washing machine, extra large capacity Plus. Water drips from the top back of the washing tub into the spun-dry clothes after doing a load. Dripping water source is higher and slightly to the...
Aug 16, 2008 | Washing Machines
Water in my washing machine
Sep 10, 2007 | Maytag PAV2300 Top Load Washer
Washing Machines Logo
191 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
