Question about Moultrie D55IR Digital Camera
I can ring out get calls i,,,cant anwser txts or sent txts
Samsung gt s3770b
Paul_fall528
first you say you can make and receive calls, the you say you have no control . , perhaps if there is someone close to you they can show you what it does properly .
Dec 19, 2015 | Symbol Cell Phones
How do I increase ring time before phone transfers to voicemail
Which phone are you using - please be specific.
Generally Go To Settings > Call Settings > Additional Settings / Call Forwarding Settings > Voice Calls > Change the always forward Settings, here it will ask you for Number of Rings Before Forwarding. Change that as per your convenience.
Sep 19, 2014 | Samsung Cell Phones
My phone is not ringing when I get incoming calls, beeping when I get txts, and it won't go on loud speaker. The volume is high. Its set to normal profile, with ringing volume high. Please advise.
Some how your phone was reset or had the tone turned off. Just follow the below guide and your audio should come back on. I would do a soft reset (turn off the handset, remove the battery then reinsert) before performing the instructions.
Tone settings
To select a ringing tone for voice calls, select Tones >
Ringing tone.
To select a ringing tone for video calls, select Tones > Video
call tone.
To set the ringing type, select Tones > Ringing type. You
can also set the device to sound a ringing tone that is a
combination of the spoken name of the caller and the
selected ringing tone, when someone from your contacts list
calls you. Select Tones > Say caller's name.
To set the volume level of the ringing tone, select Tones >
Ringing volume.
To set the various alert tones, select Tones > Message alert
tone, E-mail alert tone, Calendar alarm tone, or Clock
alarm tone.
To set the device to vibrate when you receive a call, select
Tones > Vibrating alert.
To set the volume level of the device keypad tones, select
Tones > Keypad tones.
I have included a link to download your user manual if needed, it comes as a PDF file so you need to have adobe PDF down loader
http://nds1.nokia.com/phones/files/guides/Nokia_E63-1_UG_en.pdf
Apr 23, 2011 | Nokia E63 Cell Phone
The phone wiil not send txts will recieve ok txts and calls . Comes up error retry or cancel
Try this menu > settings > about phone > system updates > update profile and let it do its thing. Wait a few minutes and try and send a text again.
Apr 03, 2011 | Samsung Cell Phones
Low ringing volume during first few seconds of incoming call...how can i solve this
ur mobile incoming call setting u assigned low type.
u change the mobile setting
setting>>profile>>edit >> incoming call >> choose ur type incoming ring type,
( or )
ur speaker problem change it immediately
Sep 08, 2010 | Samsung Omnia II I8000 Smartphone
Cant recieve or sent txt's or calls ?????????
Restart your cell with factory settings and your problem will be get solved. :)
Dec 13, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
I cant receive txts from a certain number
that contact is probably blocked, if you go to messages>settings>text messages>block number and see if any of your contacts are there.
Oct 09, 2009 | Samsung SGH-G600 Cellular Phone
Turn answer phone off on Samsung tocco lite mobile
Goto Settings-->Call Settings-->All Calls-->Answering mode.
and check the required options.
Sep 30, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
Moultrie D55IR Digital Camera Logo
12 people viewed this question
Top Moultrie Cameras Experts
Steve
AZBen
AZBen
Are you a Moultrie Camera Expert? Answer questions, earn points and help others
