Question about Liquid EPDM Rubber- 5 Gallon Rubber Pail
Water leakage in my Roof !
I am facing the water leakage since last two weeks and does not know the solution for this problem. Can anyone here give me the solution for this? Already some has given me the opinion of using EPDM Coatings. What do you say?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 5 Answers
Roofing is an important part of your home and if it gets damaged due to water leakage then roof repairing becomes necessary. An expert in roofing repair has got the equipment and knowledge to find and repair even the most complex issues. These specialists are the right persons who can tell whether your terrace needs a repair or a complete replacement. For more information visit: http://southshoreroofingma.com/residential-roofing/
Posted on Jul 11, 2017
    Problem Solver:
  • 9 Answers
Hi ~ I'm not a roofer but am handy around the home, anything but electrical ! First it depends on what type of roofing material you have, this will determine what product to use to fix the leak. Another point to consider is how big is the leak and where it is located, the point at which the water is coming in from outside. To be sure of this you can usually find the entry point by looking at the roof up in the attic.
There are generally two types of patching material available, one is solvent based, and the other is latex (water) based. Cleanup for a solvent based product would be a solvent, like paint thinner, or lacquer thinner. A latex based product would only need water to clean up, if you did it while the product is still wet. You mentioned a rubber liquid but do you have a rubber roof ? Many motorhomes have a rubber roof to allow for flexing from motion and expansion for hot and cold weather. If you have a conventional roofing product, shingles, shakes or any type of vinyl composite, I would go with a solvent based patching product. Much more durable over time in my opinion. Hope this is helpful info. Cheers, Gary
Posted on Apr 14, 2014
Rain water leakage in my RV Roof Top
Many RV's suffer from this problem. It is important to have your RV inspected and resealed on a regular basis (read 'at least every couple years') by a technician who really knows what they are doing. Even then, RV's are prone to leaks due to their lightweight builds and many quality issues with manufacturers. The best thing you can do is to store your RV under a roof or high quality cover when not being used or during long term parking to reduce UV and weather exposure.
Apr 09, 2014 | Liquid EPDM Rubber- 5 Gallon Rubber Pail
I am facing the RV Roof leaks and does not know the solution?
Hi, There is a product called "White Lightning" that is a paint on application for Aluminium roofs on RV's. There is also a product that is a rubber paint on application for RV's as well...don't know the name. If your roof is anything but rubber, I'd recommend a SOLVENT based product, much more durable in my opinion. I had a 34' motorhome with a leak along the canopy rail and I used a solvent based building caulking product used when putting down plywood flooring in homes to stop any squeaking, and it was great, acts as a glue as well. Can't recall the name, PCL Professional, something like that. You need a caulking gun to apply it, comes in a large tube. Hope this helps you stay dry !!! Cheers, Gary
Apr 07, 2014 | Blinglights Trailer RV Camper Mobile Home...
96 tahoe water leakage from roof area
To repair properly, should have w/s removed and necc repairs performed
Apr 06, 2014 | 1996 Chevrolet Tahoe
I'm looking for a company to instal a roof hatch in my loft. Can anyone recommend anyone in the Minneapolis area?
You could try Nystrom; they are based in Minneapolis and seem to have a good selection. check out their link -
http://www.nystrom.com/roof-hatches
Jan 15, 2013 | Building Materials
97 900 s convertible - after it rains for sometime, water leaks in driver and passenger sides. Opening the roof creates a flood. Where are the drain holes and how does one clean them?
Did you solve this problem? I have exactly the same issue with my convertible 97 900 particularly in this bad weather anyone in the front seats can expect to get soaked ! I would be grateful for any advice
Nov 26, 2009 | 1997 Saab 900
Does anyone know when the water pump usally needs changing on ford focus 1.4 2003
Water pumps generally do not need routine replacement. A good sign is leakage og coolant. Any detrimental wear such as a bearing will cause leakage of the seal.If it is a precautionary thought, Change it around 75,ooo miles. FGood luck, Ned
Aug 26, 2009 | 2003 Ford Focus
Water leakage into cabin of Mercedes 2002 C240
Hi, You need to check/ clean your sunroof drains. The best way to clean them is to use compressed air if you have access.
Feb 09, 2009 | 2002 Mercedes-Benz C-Class
Liquid EPDM Rubber- 5 Gallon Rubber Pail Logo
230 people viewed this question
Top Liquid Rubber Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Liquid Rubber Vehicle Part and Accessory Expert? Answer questions, earn points and help others
