Question about Philips Health & Beauty
Peugeot 206 sw wont turn off - Philips Health & Beauty
bunnydawg
  • 5158 Answers
SOURCE: wipers on a peugeot 206 52 plate wont stop
i can't find a manual for that car... but it is likely the wiper relay and is likely located in the fuse panel near the battery in the engine compartment.
Posted on Mar 23, 2009
ginko
  • 19396 Answers
SOURCE: fuse box diagram peugeot 206
Check the website below:
Peugeot 206 Fuses.
Posted on Mar 28, 2009
  • 215 Answers
SOURCE: my peugeot 206 diesel keeps cutting out, now it
In my opinion cut off problem occurs if engine is not getting sufficient fuel and/or air. Clean the air filter, turbo filter and fuel filter. Check the continuity of diesel flow from filter to hdi pump. If you haven't found any problem there then the possibily the hdi pump and injectors section needs to be checked. If the car has done more than 100000 miles then clean inlet and outlet manifolds including check of turbo and EGR valve. Do everything whatever possible before you take your car to garage. If there is no luck then let your car diagnosed and check any error code recorded by ecu.
Posted on Oct 13, 2009
  • 279 Answers
SOURCE: how to turn off the airbag on peugeot 206 1.6
there should be a key switch inside the car somewhere you need to turn it to the off position with the ignition key
(it will probably be some where on the dash, in the glove box or center console)
Posted on Dec 08, 2009
SOURCE: peugeot 206 cc fan belt change
hi ive a peugeot 206cc 02 reg, the STOP light keeps flashing ive checked the normal oil and water but alls ok so whats the problem still runs fine and temp stays where it should??? any tips??
Posted on Dec 28, 2009
Why won't my peugeot 206sw start an it has locked gears
Try turning steering wheel some each way while trying to turn key, pressure from steering may not be allowing it to unlock to let key turn. Other cars sometimes do that, if the locking wheel is gear you are talking about.
Jul 08, 2016 | 2004 Peugeot 206 SW
My peugeot 206 sports 2.0 hatchback 05 turns over but wont start
run the fault codes
check cam shaft is turning( broken timing belt)
check immobilizer is operational
check for ignition control module problem
Nov 17, 2015 | Peugeot Cars & Trucks
How do i fix peugeot 206 sw hdi xt reversing lights not working ?
Replace the range/park/ neutral safety switch. Check wiring also....
Jan 01, 2015 | Peugeot Cars & Trucks
All my indicators stopped working peugeot 206
there is a body control module that runs the instrument cluster2_12_2013_5_15_16_pm.png
Feb 12, 2013 | 2004 Peugeot 206 SW
Back door on peugeot 206 estate car wont open how do i fix
Peugeot 206 hdi 2006 all doors been opening fine and the back passengers door has been sticking sometimes but we could here like a whistling noise from back rear door behind passenger seat. we cantopen it now please can someone help
Feb 23, 2012 | 2005 Peugeot 206 1.4
Cam belt change on peaugeot 206 sw
I have a pug 206 sw estate, i need a rear axel non abs any help?
Jun 09, 2009 | 2005 Peugeot 405
Health & Beauty Logo
22 people viewed this question
Top Philips Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Philips Health and Beauty Expert? Answer questions, earn points and help others
