Question about Air Tools & Compressors
Coleman compressor tube getting real hot why?
    Problem Solver:
  • 11 Answers
Compressing gas generates a lot of heat. Is this a change in behavior, or a new unit that it is just being noticed on?
It is not uncommon for the tube from the compressor head into the tank to get too hot to touch on typical compressors. Not sure what model you have but unless this is new behavior that hasn't been noticed in the past, I'm not sure you have a problem.
Brian
Posted on Apr 14, 2014
How hot should the exhaust vent get on a coleman 7995 c 856 furnace?
Have been looking at this cannot find a answer that gives a temp You may have to try coleman direct on this . you can check and see if flue is not blocked . You can also google flue temps it tells you a bit more .
Feb 17, 2018 | Coleman Heating & Cooling
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
6.5hp 80 gallon tank when it gets hot it shouts off
need a little more info. Does it shut off because it tripped the breaker? overload? does it boug down and stop? does it stop when trying to restart? is the compressor get hot enough to change the color of the discharge tube?
Dec 17, 2011 | Coleman 6.5hp - 80 Gallon Vertical ASME...
How to add freon to a coleman mach model# 8633-876 serial # 089817583 do you suggest r12,or r22 freon type. is this a easy procedure or does it take a ac person? the problem is it not cooling to full...
It's R-22 and you need to be licensed to handle it, if you're not a A/C service technician or fimiliar with charging an A/C system, then it is best to have a Coleman Service Technician to charge it for you.
Aug 29, 2010 | Coleman Mach 15 Air Conditioner
My coleman mah 3 roof top will not blowon fan side
Sounds like you have either a bad fan motor or a bad fan motor capacitor. When you turn the unit on with the fan not working, the compressor (the humming noise) runs and gets real hot real quick resulting in the compressor cutting off ( the nothing after) on it's inside high temp switch. This is what the compressor is designed to do so that when this happens, it does not burn the compressor out. Replace you fan capacitor, give the compressor an hour to cool, then try it. In most cases and if I'm correct, the unit will run just like you want it to. Good luck.
Please rate solution
Sep 09, 2009 | Coleman Mach III Air Conditioner
Coleman powermate 27gal 5hp air supply line and regulater gets very hot and blowes off hose
Is a shroud of any sort been took of ? is there oil in pump assembly ? Is there a fan on this model? At what pressure does the compressor stop pumping (should be less than 135psi aroud120psi) are you using it over it's duty capacity ei:sandblasting....?
Jun 04, 2009 | Coleman Powermate 27 Gallon Air Compressor
Coleman Powermate Model Number BV6548049, pressure switch leak.
Usually, a leak at the pressure switch unloader valve is caused by the checkvalve in the tank. The unloader valve at the pressure switch bleeds out the air from discharge tube after compressor reaches set pressure. This only takes a few seconds. If air continues to leak then air is leaking back into the discharge tube past the tank checkvalve. Follow the air discharge line from the compressor to the brass valve at the tank. The brass valve is the checkvalve that holds the pressure in the tank. There are usually two connections at this valve. One is the unloader tube to the pressure switch. Simple test for leaking checkvalve, with pressure in tank unplug or switch off the compressor and remove the small unloader line at the checkvalve(brass valve) and look/listen for leak. If leaking, remove the checkvalve and examine seat/check for debris keeping the valve slightly open. If it cannot be cleaned, order generic replacement from www.grainger.com. It will cost less than the factory checkvalve. Just pay attention to the thread sizes for easy fit. Good Luck on your repair and email if you have questions.
Mar 25, 2009 | Coleman Powermate 60 Gallon Air Compressor
Black Max air compressor (old coleman model)
Needs 30W Non-detergent oil, and if there is a sightglass, fill to half-way up that glass. Otherwise, try mastertool repair or need a manual websites.
Dec 22, 2008 | Air Tools & Compressors
Coleman outdoor air cond. unit comes on but no blowing of hot air out of the house. Everything else seems to work. O
If the compressor is running, you have a freon problem. If the compressor is not running, you have an electrical problem, unless the compressor itself is bad.
Jul 26, 2008 | Coleman Heating & Cooling
Compressor lines
If the large line returning to the compressor is frosting you don't have enough air circulation. Check air filters on inside unit.
May 12, 2008 | Coleman Mach 15 Air Conditioner
Air Tools & Compressors Logo
42 people viewed this question
Top Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Are you an Air Tool and Compressor Expert? Answer questions, earn points and help others
