Question about Emerson IC172 Clock Radio
Docking station sip478 - Emerson IC172 Clock Radio
How can i update dell dock?
A docking station is an extension or addition of ports for a laptop computer. Once the portable computer is docked, you can access the docking station's ports, such as PS/2 or USB 2.0 ports, through your computer. Some docking stations have monitors that you can connect your computer to, placing your video on an external screen so you can turn off your computer's monitor and conserve some of your computer's energy. All Dell docking stations will have the same general troubleshooting steps.
Plug your laptop's power adapter into the docking station and dock your laptop onto/into the docking station. If there is no power going to your laptop from the docking station but it works when the power adapter is plugged into the wall, the docking station is bad and needs to be replaced. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power goes on but your computer doesn't recognizes accessories such as a USB mouse--plugged into the docking station, try a different port on the station. If it works in a different port, the previous USB port is burned out. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized, you might have a corrupted docking profile. Undock the computer and dock it again once it has fully started up to reset the docking profile. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If you have an external monitor and it is not working, completely close the lid on the laptop so the image will move to the external monitor. Plug your power adapter into the docking station and dock your laptop onto/into the docking station. If power is going through the docking station but no accessories are being recognized and resetting the docking profile fails, update all drivers through Dell's support website and then re-dock the computer. Some of the software that runs the hardware may have become corrupted. Hope this helps
b>
Jan 16, 2013 | Dell Inspiron 1545 Notebook
Sony dock not working after iOS 6 update? Just says not an apple compatible product?? Any idea of an update or a fix on the way?
My wife had this problem with iPhone 4S after updating to ios6 on a Sony xdr-ds12ip docking station. Sound would play on iPhone off the docking station, but once it was docked no sound would come through the docking station speakers (docking station radio works fine, as did the iPhone before the iOS update). Fixed it by powering down both the iPhone and the docking station at the mains, gave it 2-3 minutes and then powered on the docking station and then the phone. Placed the iPhone in the docking station and voila the sound comes out of the speakers now.
Sep 29, 2012 | Audio Players & Recorders
How to turn off the alarm on a sylvania imode sip478
If this is for turning the alarm completely then I also had the same problem. The directions in the manual are not clear but all you have to do is quickly press either Alarm 1 or Alarm 2 (depending on which one you are turning off) twice and the alarm will be deactivated.
Aug 21, 2012 | Curtis iMode Digital AM/FM Stereo Radio...
Docking station for MX1000 Laser mouse not working
That docking station has a lithium-ion battery in it that supposedly never needs replacing. I'm wondering if the battery did go out on it and needs to be replaced. If there is now way to get inside of the docking station then you will need to get another mouse, cause you can't just get the docking station.
May 27, 2010 | Logitech MX1000 Laser Cordless...
Docking station
typically if it's a complete docking station, it uses your laptop power supply and provides power to your laptop and itself at the same time.
http://www.dell.com/downloads/global/products/latit/en/laptop_latitude_efamily_docking_accessories_brochure.pdf'
according to that brochure the dock is the E series.. and doesnt come with a manual
Dec 11, 2009 | Dell D/Dock Expansion Station Docking...
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
How does a USB docking station work w/ a regular docking station
the older pc probably needs a usb 2.0 port to run docking station. the manual on the docking station should tell you. you may need to install a usb 2.0 pci card in your older computer for it to work.
Mar 18, 2009 | Dell Inspiron 5160 Notebook
D630 docked , ext mouse & kybd not responding
If the docking station has power:
Make sure power is off for both the laptop and the docking station. Plug your keyboard and mouse into the docking station. Dock the D630 to the docking station and then power on docking station. This should then turn on your D630. Your D630 should detect the keyboard and mouse.
If the docking station has no power:
Verify that the power cord, AC adaptor, etc. is plugged in. If the items listed seem to be in order,
there may be a problem with the power going into the docking station. (AC adaptor?)
support.dell.com will have the specific details for your D630 and your docking station, et al.
Please let me know if you have success in this.
Binary Bob
Nov 27, 2008 | Dell Latitude D600 Notebook
Fix video?
If your video was working fine before then it might be a corrupted file driver of your docking station. No need to worry with your computer because it is not your computer causes the problem. It is your docking station.
You may try reinstalling your docking station software using the cd that came with it.You need to connect your system to your docking station when reinstalling the software. if the issue persist after installing the software. Please check if your docking station still in warranty and check their part replacement policy.
Keep me posted.
thanks.
Oct 16, 2008 | Computers & Internet
No ethernet with docking station
It could be the connector on the bottom of your laptop that's creating the problem. Does any other ports work on the docking station when docked?
Jan 14, 2008 | IBM ThinkPad T43 Notebook
Emerson IC172 Clock Radio Logo
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
