Question about Panasonic DMR-E55 DVD Recorder
Can not get disk drive to open
Disk drive will not open. Have power
  • 3,267 Answers
Use a paper clip, straightened out. There is a small pin-head sized hole at the right side of the tray. Insert one end and push gently but firmly when you hit the end but its movable. That is the release/unlock lever. By pushing in it releases the lock such that the tray can be manually pulled out to remove the damaged disc. If its a broken CD/DVD if all pieces don't come out you may have to remove the cover. After check if the motor runs. If OK then try another DVD. If motor is unable to spin the disk, then the motor will have to be replaced.............................................sodeep
Posted on Jun 26, 2009
It is common problem with this DVD. It won't start, just perform endless SELF CHECK, and when trying to read the disc, power just drops down, and game starting over and over...
In my case, and i believe that is the same thing in all those Panasonics, problem was increased resistance of R 003, located around STRG 6353. Voltage developed at this resistor, serves as overload information for security purposes. i just added another 1.5 Ohm resistor in parallel with existing 0,47 Ohm (R003). After that, recorder works fine.
Oscar Wild
Posted on Jul 04, 2009
  • 6,784 Answers
Hi, the load motor has failed. it is possibly jammed or burned out at this point. you will need to send this unit in for this repair.
Posted on Jun 19, 2009
Different hard drive
Turn the computer off.
Disconnect the power-cord.
Open the side-panel on the computer's case, to reveal the insides.
Disconnect both the "data" and "power" cables from the disk-drive.
Remove the disk drive.
Take the disk drive to a computer store, and tell them that you want to replace it with one that is the same PHYSICAL size -- you may get one that stores many more GB of data.
Insert the disk drive.
Reconnect the cables.
Close the cover.
Reconnect the power cable.
Turn it on.
Reinstall Windows.
Jun 16, 2014 | Dell Vostro Computers & Internet
Wd3200h1u00 cant mount
If the hard drive cannot mount, there is not a valid volume on it. With the drive physically connected and powered, open Applications/Utilities/Disk Utility (or if the hard drive in question is supposed to be your OS volume, boot up to Disk 1 of the OS install set and open Disk Utility from the File or Apple menu (I don't recall which one at the moment). If the disk icon shows up in the list of available disks, click on it. Any volumes on the disk should appear. If not, the disk is unformatted or the volume information is corrupted. If the icon doesn't show up at all, the disk is either not properly connected and powered or is defective.
Jun 20, 2013 | Computers & Internet
What if disk drive does not open during system says reboot and selesct proper booot device
Sounds like you may have a CD/DVD in the drive that is stuck and/or not inserted properly. There should be a small, pin-size opening on the front plate of the CD drive. Find a large paper clip, bend out one end of it then insert into the pin-hole. Push it until the drive pops open.
If you need further help, reach me via phone at https://www.6ya.com/expert/brandon_bf4b4a06876c89a0
Aug 10, 2012 | Toshiba Satellite P755-s5320
My laptop crashed while the external drive was hooked up by usb. Had to shut both down. Now the hard drive will not show up on any computer as it did before and cannot be opened to be viewed. I need the...
The external storage device has several major components:
* USB cable
* external power-supply
* disk-drive inside the enclosure
* USB-to-disk-drive adapter inside the enclosure.
Try a different USB cable.
Try a different USB port on your computer.
Try a USB port on a different computer.
Take a multi-meter, and measure the output voltage/amperage of the power-supply,
and compare with the specifications on the label of the power-supply.
Open the enclosure, and remove the disk-drive, and attach it as a "slave" drive in a desktop computer, to see if bypassing the USB-to-disk-drive adapter bypasses the problem.
Look at the label on the disk-drive, for manufacturer, product-number, serial-number, and manufacture date. Access the manufacturer's web-site, and use "check warranty status" to see if the warranty still is valid. If so, the drive can be replaced, at minimal cost to you.
Buy a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Search online for a professional "data recovery service". For a significant fee, they can repair your disk-drive, just long-enough to copy your files to a new disk-drive.
Nov 05, 2010 | Iomega (33654) Limited Edition 500 GB USB...
I pluged in usb to computer and nothing happens. it should automatically open hard drive. i looked for it under control panel -> admin tools ->comp mgt ->storage -> disc mgt. ...
* USB cable
Nov 04, 2010 | Hitachi 200GB External USB Drive 200 GB...
I have pluged in the usb plug and plug the maxtor to the electrical plug but nothimg happens. How do I get it going?
Take a multi-meter, and test the voltage and amperage outputs from the power-supply, to confirm that the readings match the specifications on the label on the power-supply.
If the power-readings are correct, then when you connect the power to the external enclosure, you should either hear the disk-drive start to spin, or feel the vibrations as the disk-drive spins.
If you don't, then the disk-drive inside the enclosure has "died".
If the device is still under warranty, MAXTOR will replace the disk-drive, for minimal costs to you.
If the warranty has ended, then open the enclosure, remove the disk-drive, purchase a new, compatible, disk-drive, install it into the enclosure, and thus "revive" your external storage device.
Nov 04, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
I have an ibook g4 mac and a 160 gb simpletech hard drive. there are two lights showing in the hard drive- red and blue. how do i get the hard drive to register with my computer, and how do i save my music...
* USB cable
Nov 04, 2010 | SimpleTech 160GB USB 2.0 / FireWire...
My Hp SimpleSave 1TB just quit working on windows 7. When I plug it in my computer realizes I have a drive in the usb but it doesnt open or anything.
* USB cable
Nov 04, 2010 | HP SimpleSave 1 TB USB 20 Hard Drive
My toshiba satellite pro was set to hibernate, and when i went to turn it back on the power light comes on, and the cd drive light comes on, but that's it. the cd won't even open so i can't use my recovery...
Try this first to get it out of hibernation mode. Unplug the power supply, remove the battery. go hava cup of coffee. Come back, reinstall the battery and power cord. Attempt to restart the computer.
If this fails go to....
Look at the cd drive. Next to the button that normally opens the cd drive is a pinhole. Power up the computer. Using a straightened paper clip, push the paper clip into the pinhole. you should be able to get the cd drive to open.
If you can not get the computer out of sleep mode you should now be able to get the cd drive open and use the recovery disk.
Oct 27, 2009 | Acer Aspire M1201 Athlon X2 320 Gb PC...
My fujitsu laptop recently had a new hard drive installed in it ,but i want to transfer the data i have on the old hard drive that was removed from laptop to my new hard drive. I bought the all in one...
The Coolmax adapter is an USB hard drive adapter that can connect various types hard drives to your computer. This is used for testing and and transferring data to and from hard drives connected to the computer via the computer's USB port.
This Coolmax USB hard disk adapter can connect a 2.5-, 3.5- and 5.25-inch IDE or SATA hard disk to a PC. The black adapter box connects the hard disk, while the secondary power plug/adapter powers the drive. In the case of smaller notebook or SATA disks, the power cable is plugged directly into the adapter (as opposed to straight into the IDE hard disk).
The red USB cable, meanwhile, can be used to power hard disks directly from the host PC's bus via another USB port.
Connect the hard drive to the adapter as detailed above, power up your computer and plug the Coolmax USB cable into the conputer's USB port. The computer will detect and see this as an external drive, most likely as a E drive (the next drive letter that is available). Click on this drive and open to open the folder/s where your data is stored then select the folder/s and/or data and copy them, then open the hard drive on the computer and paste the folder/s and/or files onto the new hard drive.
Sep 29, 2009 | Fujitsu Siemens Computers & Internet
Panasonic DMR-E55 DVD Recorder Logo
374 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
