Question about Sony VAIO PCG-V505CP Notebook
Power can't turn on?
My sony vaio notebook pcg-v505ecp has the problem with the power.when it turns on, first the battery alarm and ac alarm icon change rapidly. then after several times. the battery won't be recharged anymore and can't turn on anymore even using ac power. i try using my battery in my friend laptop the same model. it's ok. is't the jack ac problem? i 'm not quite sure. try to go to tech and said that mother board faulty. but i can still turn on my note book using my friends full battery?
    Sergeant:
  • 321 Answers
Its not motherboard problem its ram problem
Posted on Jun 18, 2009
New hard drive not recognized in the bios PCG 6B1L
Try this hard drive one some other pc and make sure if it works fine otherwise it may be exceeding the capacity supported by your motherboard.
Oct 28, 2013 | Sony VAIO V505ECP (PCGV505ECP12) PC...
Drivers for pcg-6b1l
You can download the device drivers from the Sony WEB site.
Select your model notebook and the Windows drivers you require. Please click on this link to the Sony support WEB site :-
http://esupport.sony.com/US/perl/select-system.pl?PRODTYPE=1,24,72&DIRECTOR=DRIVER
Feb 06, 2013 | Sony VAIO V505ECP (PCGV505ECP12) PC...
My sony vaio pcg-k33 shuts off by itself when i turn it on. i think its the video card cause the fan turns on and stays on when i turn the latop on. so maybe its over heating. Please help
Turn the computer off.
Disconnect the AC power.
Remove the battery.
Buy a can of compressed-air, and give your computer a "blow-job", because a layer of dust inside your computer is blocking your heat-radiators, and thus is causing your computer to overheat.
May 07, 2010 | Sony VAIO PCG-K33 Notebook
My sony vgn-tx17p won't boot. Te power light turns on and nothing shows up on te screen. Please help
  1. turn off the computer
  2. disconnect the ac adapter and remove the battery
  3. reseat the RAM/memory.
  4. without the battery or ac adapter, press and hold down the power button for 7-10secs
  5. reconnect the battery and ac adapter
  6. try turning it on
Feb 26, 2010 | Sony VAIO PCG-TR3AP1 Notebook
Would any 16volt ac adapter be ok to charge my PCG-VX89 vaio notebook?
you can use any laptop AC adapter DC output-16V and 4A (current). if its jack size natch your laptop DC jack.
if the adapter DC current less than 4A (over 2.5A at least) you should only make the battery charging without laptop turn on!!!
please take a rating let me know how much helped you thanks!
May 21, 2009 | Sony VAIO V505DC PC Notebook
Sony vaio pcg-grt170 when I push the power button, the green light and 2 yellow lights blink one time but the computer will not turn on. I tried taking the battery out, checked the power cord.
Perform these steps and the issue will be resolved if the issue is with the Static charges on the Mother board.
I recommend you use Power Drain procedure by following these steps:
1. Disconnect the AC Adapter.
2. Remove the Battery.
3. Hold the Power button down for 30 seconds to 1 minute.
4. Reconnect the AC adapter and do NOT connect the battery now.
5. Turn on the Notebook power.
Feb 18, 2009 | Sony VAIO GRT170 Notebook
Won't stay on
IS THIS WITH BOTH AC CORD AND BATTERY
you probably need a power supply
before you run out and buy one start and press f8 then start in safemode see if the same thing happens
also make sure your AC adapter is connecting with internal connection the internal connection can become loose or bent from constant plugging and unplugging
Jan 22, 2009 | Sony VAIO PCG-K35 Notebook
Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Sony VAIO PCG-V505CP Notebook Logo
327 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
