Question about Samsung AS18A6RB Air Conditioner
E101 Can I just buy a new out door fan for my samsung mini-split system? Can it be a different brand out door fax like Mitsubishi?
  • 41 Answers
Out door "fan" can be replaced with any of same size but if u need to replace the unit then its all too tech and its tech details needs to be as same as the one that was installed. Outdoor unit doesnt only have a fan fir cooling but alongwith it condensor, compressor etc etc
Posted on Apr 14, 2014
4 Suggested Answers
baraquielnar
  • 247 Answers
SOURCE: my samsung mini split comes
replace your thermistor possible damage it is attach on the main pcb board then observe after replacement.
Posted on Mar 05, 2011
heatman101
  • 43501 Answers
SOURCE: I ordered a different remote
The remote should come ready to work if you ordered the correct one and they GAVE you the correct one...
Click here for the complete manual including installation....check page e-22 for the troubleshooting of the remote
Also make sure the remote sensor on the right side is not covered with dust or dirt...
If nothing else works then you have a bad board or sensor...a dealer should be called to replace either of them...
heatman101
Posted on Aug 24, 2011
hvac1960
  • 2133 Answers
SOURCE: AIR conditioner samsung aqv12a error message "E101
ErrorCode = 101
Explanation and Checking points = Indoor unit communication error - checkwiring
Posted on Oct 27, 2011
Have a Silverstorm split aircondtioner lost remote cant get cooling in summer periods.
split air cons come in both configurations and are mostly in the last few years with inverter systems
you can get cooling only or cooling and heating systems
some brands only have the cooling only on the smaller units ( 8000 btu units)
Sep 09, 2016 | Heating & Cooling
Ice hitting outside fan
It sounds like your system might be low on coolant. Check the pressure of the main line and check it against the specs. You may have a leak in the system.
Mar 02, 2015 | Rheem 12,000 BTU Mitsubishi 13 SEER R-410A...
Indoor unit fan blows, then stops etc. every 1-2 minutes
At least it is cooling properly. U might just want to call Mitsubishi and ask them if it is operating normally based on your observations.
Apr 30, 2017 | Mitsubishi 18000 Btu Mr.slim Ductless Mini...
Samsung Vivance mini split flashes E101 and E416, I looked up explanation, but do not understand what it means and how to solve issue
Check and replace room sensor. Once it gets rectified, automatically E416 will go off which means not running of blower motor
Nov 14, 2013 | Samsung AQV12VBCN Vivace Mirror Finish...
Mitsubishi
I've read and heard from local techs that the Mitsubishi (along with lots of other mini split brands), are known for the indoor coil leaking freon. Even after a fee years of working great! Have them serviced. They are probably low on refrigerant. Try checking the trouble codes on the remote.
Aug 26, 2017 | Heating & Cooling
I have a Mitsubishi heat pump that runs well but the outdoor unit does not defrost what could be the problem.
Why does my heat pump ice up in Winter?
Heat pumps naturally ice-up in the winter. It is normal for the entire coil to be covered in a white frost and even light ice, during cold weather conditions. However, it is bad for the entire unit to be encased in ice. This indicates ductless heat pump problems which should be addressed quickly to save energy and avoid serious damage to your ductless unit. These systems should periodically go into a defrost cycle. This keeps the unit running efficiently. If the coils are blocked by ice, proper heat transfer between the coil and the outside air will not occur.
How does the defrost mode work?
When the mini split heat pump goes into defrost, the reversing valve inside of the outdoor unit is energized, switching the system from heat to the air conditioning mode. The outdoor coil becomes the hot, the indoor coil becomes cold, and both - the outdoor and indoor fans shut off. This allows the outdoor coil to melt accumulated ice. When the built-in micro-computer analyzes that all ice have been melted, the heat pump heating system goes back to heating mode.
sanyo-mini-split-defrost.pngA cloud of water vapor may be seen rising over the outdoor unit and a "whoosh" sound can be heard as the refrigerant reverses direction. The entire process usually takes up to 10 minutes (depending on conditions).
How often does the system goes into defrost mode?
Ductless mini-split heat pumps have different ways of determining when to go into defrost. The built-in microcomputer determines outdoor temperature, refrigerant pressures, and several other factors. In colder temperatures the system will go into defrost more often than in warmer.
If a ductless mini split heat pump is severely iced-up in the winter it is possible that it isn't defrosting (though there could be many other causes). Let the manufacturer certified technician check your system
Oct 29, 2011 | Mitsubishi Mr. Slim MXZ30TN Air...
I am wanting to buy a ductless mini split from ac-world.com and was wondering which is a better quality brand AM versus Celiera?
They are both equal in regard to quality. If you want the best your going to have to go with Mitsubishi.
May 01, 2011 | Heating & Cooling
Mitsubishi Mr Slim mini split outdoor unit fan.
Check the capacitor. Rating must be within 90% of rated microfarads. If it is a dual capacitor test between C and FAN. Set your meter to read microfarads (uF).
Aug 13, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Broken Fan
send fan cover size i will try2 send u
Feb 07, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Samsung AS18A6RB Air Conditioner Logo
273 people viewed this question
Top Samsung Heating & Cooling Experts
billconfused
Ezewudo Onyekachi
Ezewudo Onyekachi
Are you a Samsung Heating and Cooling Expert? Answer questions, earn points and help others
