Question about Homelite Garden
Washer not producing maxium pressure - Homelite Garden
Pressure washer has no pressure at all
check for blocked jet at the end of the wand
this is the same as letting the trigger go and the pressure relief regulator is not engaging the pump to produce pressure
water just circulates around the pump
Jun 30, 2015 | Briggs & Stratton Garden
Pressure washer brute
I had one to the same thing and the pump went out on the waser and you can buy a new pressure washer cheaper than the pum itself
Sep 21, 2013 | Garden
Will not produce pressurized water
check the pressure regulator valve. It may be set wrong or stuck open. If that is not the problem then a valve may be stuck in the pump.
May 17, 2013 | Briggs & Stratton Briggs Stratton 1800...
Burned through the hose, repairs?
With the high pressure that these units produce, I would recommend replacing the hose instead of repair just for a simple matter of safety.
Feb 12, 2013 | Craftsman 2700 PSI Briggs Stratton...
Honda 5HP pressure washer. When you press handle to get pressured water, motor does not rev up to give you high pressure.
Most small pressure washers do not have an automatic throttle control to increase engine speed on demand (activated by trigger on wand). You must set the governor/throttle to about max. to get the rated pressure. A honda motor produces 5 hp when it is turning about 3600 rpm. To increase the life of the pump, use about 80 % of capacity of the pump and increase only for stubborn debris.
Jun 17, 2011 | Honda Garden
I have 5.5hp briggs&stratton pressure washer Simoniz S2350. Would you know the PSI for this item?
Every 5.5 HP pressure washer runs between 2,200 and 2,500 PSI with most set by the manufacturer at 2,400 PSI with 3,600 RPM of engine speed.
Due to the power required to produce more than 2,500 PSI a 5.5 HP engine would lose engine speed as it can not produce enough power for the higher PSI output. It is a matter of hydraulics vs input power.
Any gas pressure washer will produce lower pressure with lower engine RPM. Looking at S2350 as your model number yours may be set to 2,350 PSI by Simoniz.
Thanks for using FixYa.
Kelly
May 16, 2010 | Garden
How to repair chemical pickup pump
Make sure that you have adjusted the nozzle on the end of the washer so that it produces low pressure as this is the only way it will ****.
Apr 12, 2010 | Karcher K2.26 Electric Power Washer
Karcher k3.48 pressure washer appears to be seized up?
if the machine is blowing fuses then it could be the motor! if not then maby the start cupasitor has failed
Jun 01, 2009 | Karcher PSI Electric Pressure Washer
Pressure washer won`t pressure up
Have you tried adding 30 wheight pump oil,under 1 qrt usually
Mar 18, 2009 | Garden
Garden Logo
35 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
