Question about Briggs & Stratton Garden
Engine floods when left overnight. Gas drips from exhaust manifold
Editor925
  • 285 Answers
SOURCE: engine floods,gas dripping out of carburetor,any
Obviously fuel is flowing but not being ignited. Check spark plug and replace with a new one, then check for spark using a spark testing tool if still having problems. You need three things to get it to fire: fuel flow, spark, and compression... Hopefully the motor still has good compression, but check for spark problems first.
Posted on Mar 17, 2009
  • 174 Answers
SOURCE: gas tank leaks, raw gas out the exhaust
Get the leak fixed
Posted on Jul 19, 2009
  • 37 Answers
SOURCE: when i kick my 85 yamaha yz 125 gas and oil come
Sounds like you have blown the exhaust gasket. Not a difficult repair .. just undo the exhaust manifold bolts and remove the exhaust. Purchase a new gasket and reassemble with the correct torque settings.
Posted on Sep 26, 2009
SOURCE: stihl ms-250 won,t start , and gas leaking from
I had same problem and symptoms. I was overchoking it. Started fine when I quit choking it. Do as suggested above. Do not use full choke.
Posted on Apr 02, 2010
jgwhomeequip
  • 1902 Answers
SOURCE: 16 HP briggs and stratton poulan severe flooding
The carb is not closing down properly. You will need to either rebuild the carb or just replace it. Basically the float is staying open after you shut the machine down. Please rate
Posted on Jun 04, 2010
Where is the EGR valve located on a 1997 Geo Metro 1.3 automatic? Where it has been mentioned is not where mine is, tho, theirs was a stick
I will post a picture so you can ID the valve. It is on the top of the engine bolted to the intake.
Dec 23, 2016 | Geo Cars & Trucks
91 honda accord engine flooded of gas overnight
Be more explicit.
How the spark plugs looks like? Are them black?
Nov 25, 2013 | Cars & Trucks
Smoke coming from the left side of the engine
this may be due to an oil leak getting onto the manifold or the manifold is cracked and exhaust gas is building up in the engine.
if smoke is intence and black this indicates oil.
if it is mid and grey blue this indicates exhaust gas
get checked by a mechanic
i hope this was useful.
Jan 24, 2011 | 2006 Chevrolet Blazer
I have a 99 olds alero. I can drive awhile park the car try to start it and it won't crank. Newer battery and alternator. Mechanic is thinking manifold sensor. plz help
IF CAR TURN OVER NOT CRANKING AFTER A SHORT DRIVE WHEN ENGINE HOT.DIRTY CLOGGED FUEL INJECTORS FLOODING ENGINE OUT.CLEAN FUEL INJECTORS.FILL GAS TANK UP.PUT A CAN OF SEAFOAM IN FUEL TANK.DRIVE CAR AROUND TO HELP FLUSH OUT CARBON ON THE INJECTORS SEATS TO STOP GAS DRIPPING CAUSING FLOODING.IF CAR WONT TURN OVER.BAD BATTERY CABLES OR STARTER.SCAN IT FOR THEFT SECURITY PROBLEMS. IF STARTER TURNS OVER NO CRANK ENGINE FLOODING DUE TO DIRTY FUEL INJECTORS.
Sep 26, 2010 | 1999 Oldsmobile Alero
Starting engine
If this is the V8, you might have a leaky fuel pressure regulator that is seeping fuel into the vacuum control line that attaches to it. If this happens then this extra fuel gets into the intake manifold and causes the engine to be partially flooded when an attempt is made to restart it. If the vehicle sits long enough or sits overnight this extra fuel will evaporate away and the engine will start normally. When the problem is occuring It usually will misfire for a bit or even stall once and often there will be a puff of black smoke out of the exhaust when it does restart. The regulator is located on the left hand side of the engine above the intake manifold. It's about 1-1/2" in diameter and about that long with a small vacuum line attached to the end/top of it. If you remove the vacuum line and can detect even a trace of fuel in it [liquid or even vapor] then that is most likely your problem.
Jul 15, 2010 | 1999 Chevrolet K1500
How is the manifold removed on 2005 lincoln ls? Where is the bolt that holding it down?
Exhaust Manifold - Removal & Installation3.0L Engine
  1. Before servicing the vehicle, please familiarize yourself with safety procedures.
  2. Remove or disconnect the following:
    Negative battery cable Heat shields Lower splash shields Exhaust front pipes Secondary air tubes Exhaust Gas Recirculation (EGR) tube Exhaust manifold
To install:
Fig. Right exhaust manifold torque sequence-3.0L engine
Fig. Left exhaust manifold torque sequence-3.0L engine
  1. Install the exhaust manifolds. Tighten the fasteners in sequence as follows:
    1. Step 1: 15 ft. lbs. (20 Nm)
    2. Step 2: 15 ft. lbs. (20 Nm)
  2. Install or connect the following:
    Exhaust Gas Recirculation (EGR) tube Secondary air tubes Exhaust front pipes Lower splash shields Heat shields Negative battery cable
  3. Start the engine and check for leaks.
continue...
Jun 21, 2010 | 2002 Lincoln LS
When i kick my 85 yamaha yz 125 gas and oil come dripping out of my engine where the exhaust and engine meet ? Helpppp
Sep 26, 2009 | 2003 Yamaha YZ 125
1986 Chevrolet Celebrity - Surging Eratic Acceleration
Sounds like you have a vacuum leak somewhere causing the engine to flood.Check all hoses coming fron intake manifold.
May 10, 2009 | 1986 Chevrolet Chevy
Replaced intake manifold now flooding/smoke
Have you tried unhooking battery for several minutes. This should allow the computer to re-boot.
Oct 31, 2008 | 1997 Ford Thunderbird LX
Garden Logo
16 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
