Hi! The Nokia BH 108 headset does not have the A2DP function (advanced audio distribution profile). However, if you are using NOKIA (symbian) non-windows phone, you can play music since the phone bypass the said restriction. You may want to try other bluetooth headsets that has A2DP function so you can enjoy the musics from your headset. Thanks.
hi i have a c105 i purchase a china stereo bluetooth headset through the internet now i paired its ok i can only make and received calls only i cant listen to music through my phone and memory card please help thanks. sanjay
on the bh-108, press and hold the power button till its completly off, then press and old power again till it turns on but dont leave the button even when its on, after about 10 seconds you should see blinking light of 3 different colours, that is pairing mode.Open your phone settings, connectivity, bluetooth and click on add new device, search and you will find bh-108, click on it, password is 0000 saved. click it again and click connect or just press the answer button on the bh-108 and it will auto send a connection request to the nokia, press yes thats all.
Try searching for the nokia 6500 from the bh-108 phone if that does not work then try searching for the bh-108 phone from the nokia 6500 phone. On some phones this happens. Hope this helps! Thanks
I also experienced the same problem. After trial and error I realized that the bluetooth device needs to be reset to fix this issue.You may reset the bluetooth device by deleting the pairings from the headset or reseting the headset. Switch off the headset, and press and hold the multifunction key for over 8 seconds. Start pairing the device again. It should work fine now with default passkey 0000
press and hold the bottom on the bh-207 for about 8 sec you will notace the light remains on, now search for new BT devices whe the phone see it it will ask for passkey enter "0000" and the bh-207 will paiir
