Whirlpool stylemaster 4214289 rev
The agitator in my washer isn't spinning very well, and sometimes it doesn't spin at all. How can I fix this issue?
jsrock516
  • 5911 Answers
SOURCE: Will not Spin or Agitate. Whirlpool washer came
If the washer will fill and drain, but won't agitate or spin, you may have a broken motor coupling. The noise of the motor engaging, lack of agitation and ability to still drain are the usual symptoms. This is a common fail item with this model washer through normal wear and tear. Newer versions of the coupler are more resilient and resist breaking. The following link explains how to replace one:
http://www.fixya.com/support/r385250-replacing_motor_coupling_kenmore_top
The motor coupling is located between the drive motor and the transmission and takes the place of a drive belt. They do wear out and can break. The replacement part number is included in the link I provided and is an improved upgraded coupling that is more resilient. It should last longer. If you have questions, or require additional assistance, please let me know. I hope this helps you.
A replacement coupler can be purchased on line at appliancepartspros.com for about $11. Just use the part number in the link and "Search by Part Number" for your search criteria.
Now...a washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
Take note of your symptoms:
1. Washer fills, may or may not agitate, will not advance to the rinse cycle, and will NOT drain - lid switch.
2. Washer fills, does NOT agitate or spin, but WILL drain - motor coupling.
If you still have questions, please let me know. If the suggestions I have listed do not match your washer symptoms, please post back and elaborate more on what the washer is/is not doing. That way I can provide you with better assistance. I hope this information is helpful to you.
PS The age of the washer is determined by the Serial Number on the appliance. If you post back with the number I can tell you the year it was manufactured.
Posted on Jul 10, 2009
  • 13 Answers
SOURCE: Whirlpool washer stylemaster 4213532 won't spin,
check the connection of the plug if have power.check the motor should be 6ohms reading of motor windings
Posted on Mar 06, 2010
SOURCE: My Whirlpool stylemaster 907675 Washer wont spin..
Hi, stylemaster washing machine won't spin on the top half. The bottom part spins perfect. the top doesn't seem connected. What
should I do ?
TIA
RJ
Posted on May 24, 2010
SOURCE: Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken
I have exactly the same problem as Jonthan, what's the solution?
Posted on Jul 20, 2010
SOURCE: Whirlpool washing machine agitator problem
Simply buy the "doggies" and install it them
Posted on Feb 22, 2011
Whirlpool washer Stylemaster #4216273 REV A allows water to go out of the machine but will not go into a spin.
the motor has an issue prob brushes need replaced or timing of the pump out is too long
check out the filters or get a tech...
Dec 10, 2014 | Whirlpool Washing Machines
Whirlpool stylemaster 4214289 REV A Leaks water only when using warm and hot selections.
http://www.whirlpool.co.uk/app.cnt/whr/en_GB/pageid/pgsrvifuhome001/ifu/home
Oct 20, 2013 | Washing Machines
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Whirlpool washer stylemaster 4213532 won't spin, replaced actuator, still won't spin. Pumps water and agitates.
Mar 06, 2010 | Washing Machines
My Whirlpool stylemaster 907675 Washer wont spin.. The lid switch is fine.. Washes fine and all other cycles work.. just wont spin.
should I do ?
TIA
RJ
Jan 08, 2010 | Washing Machines
Will not drain or go into spin cycle
Definetly the lid switch has been knocked out of place or has gone bad.
Aug 26, 2009 | Whirlpool Washing Machines
Dec 24, 2008 | Washing Machines
Washing Machines Logo
54 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
