Question about Samsung SGH Cell Phones
Battery Temperature too high or too low - SGH Samsung Cell Phones
I have a 2006 buick lucerne 3.8 v6 cxl.my coolinf fans dont come on .i need to know how to change the relay and the fuse.
Your vehicle cooling fan's are controlled by three relay's , couple of fuse's an the PCM - engine computer . The engine coolant temp. sensor is a input to the PCM , when engine temp get's to 212 the PCM will turn on the cooling fans in low speed . Checking to see what the actual temp is with a scan tool an a infrared thermometer at the thermostat housing ,an looking up the specification's in a service repair manual is how to diagnose . Not guessing an replacing parts . Plus learning how the cooling fan's work .
Relay Driven Dual Cooling Fan Diagnostics Reading factory service info as to how they work also would be a good idea .
Cooling Fan Control - Two Fan System
The engine cooling fan system consists of 2 puller type electrical cooling fans and 3 fan relays. The relays are arranged in a series parallel (S/P) configuration that allows the engine control module (ECM) to operate both fans together at low or high speeds. The cooling fans and fan relays receive battery positive voltage from the underhood fuse block. The ground path is provided at G104.
During low speed operation, the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. This energizes the low speed fan relay coil, closes the relay contacts, and supplies battery positive voltage from the low fan fuse through the cooling fan motor supply voltage circuit to the left cooling fan. The ground path for the left cooling fan is through the cooling fan S/P relay and the right cooling fan. The result is a series circuit with both fans running at low speed.
During high speed operation the ECM supplies the ground path for the low speed fan relay through the low speed cooling fan relay control circuit. After a 3 second delay, the ECM supplies a ground path for the high speed fan relay and the cooling fan S/P relay through the high speed cooling fan relay control circuit. This energizes the cooling fan S/P relay coil, closes the relay contacts, and provides a ground path for the left cooling fan. At the same time, the high speed fan relay coil is energized closing the relay contacts, and provides battery positive voltage from the high fan fuse on the cooling fan motor supply voltage circuit, to the right cooling fan. During high speed fan operation, both engine cooling fans have their own ground path. The result is a parallel circuit with both fans running at high speed.
The ECM commands the low speed cooling fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 94.5°C (202°F).
• A/C refrigerant pressure exceeds 1447 kPa (210 psi).
• After the vehicle is shut OFF, if the engine coolant temperature at key-off is greater than 101°C (214°F), the low speed fans will run for a minimum of 60 seconds. After 60 seconds, if the coolant temperature drops below 101°C (214°F), the fans will shut OFF. The fans will automatically shut OFF after 3 minutes, regardless of coolant temperature.
The ECM commands the high speed fans ON under the following conditions:
• Engine coolant temperature exceeds approximately 104.25°C (220°F).
• A/C refrigerant pressure exceeds approximately 1824 kPa (265 psi).
• When certain DTCs set
At idle and very low vehicle speeds the cooling fans are only allowed to increase in speed, if required. This ensures idle stability by preventing the fans from cycling between high and low speed.
Dec 10, 2017 | Buick Cars & Trucks
Tip
Detroit Diesel Fault Codes
Code Description DDEC V Circuit
11 P 187 4 Chain PTO. Short circuit in the power
11 P 187 7 control system PTO wrong answers
12 P 187 3 Chain PTO. Short circuit in the ground
13 P 111 4-level circuit antifreeze. Short circuit in the ground
13 P 111 6 second-level circuit antifreeze. Short circuit in the ground
14 P 52 3 circuit coolant temperature intercooler. Short circuit in the power
14 P 110 3 circuit temperature antifreeze. Short circuit in the power
14 P 175 3 Chain oil temperature. Short circuit in the power
15 P 52 4 circuit coolant temperature intercooler. Short circuit in the ground
15 P 110 4 circuit temperature antifreeze. Short circuit in the ground
15 P 175 4 Chain oil temperature. Short circuit in the ground
16 P 111 3-level circuit antifreeze. Short circuit in the power
16 P 111 5 second circuit level antifreeze. Short circuit in the power
17 P 51 3 Throttle position circuit failed high
17 P 72 3 Bypass position circuit failed high
17 P 3 354 Relative humidity sensor circuit failed high
18 P 51 4 Throttle position circuit failed low
18 P 72 4 Bypass position circuit failed low
18 P 354 4 Relative humidity sensor circuit failed low
21 P 91 3 TPS circuit failed high
22 P 91 4 TPS circuit failed low
23 s 65 3 Oxygen content circuit failed high
23 P 174 3 Chain fuel temperature. Short circuit in the power
24 s 65 4 Oxygen content circuit failed low
24 p 174 4 Chain fuel temperature. Short circuit in the ground
25 no codes
26 s 25 November Aux. shutdown # 1 active
26 S 61 11 Aux. shutdown # 2 active (Incorrect SID. subject to change)
27, p 105 3 circuit temperature in the reservoir. Short circuit in the power
27 p 171 3 Ambient air temp circuit failed high
27 p 172 3 Air temp, circuit failed high
28, p 105 to 4 Chain manifold temperature. Short circuit in the ground
28 p 171 4 Ambient air temp circuit failed low
28 p 172 4 Air temp, circuit failed low
29 p 404 4 TCO temperature circuit failed low
29 p 351 4 TCI Temperature circuit failed low
31 S 51 3 Aux. Output # 3 open circuit (high side) S3
31 S 51 4 Aux. Output # 3 short to ground (high side) S3
31 S 51 7 Aux. Output # 3 mech. system fail S3
31 s 52 3 Aux. Output # 4 open circuit (high side) T3
31 s 52 4 Aux. Output # 4 short to ground (high side) T3
31 s 52 7 Aux. Output # 4 mech. system fail T3
32 S 238 3 SEL short to battery B1
32 S 238 4 SEL open circuit B1
32 s 239 3 CEL short to battery B2
32 s 239 4 CEL open circuit B2
33 p 102 3 Boost pressure circuit failed high
34 p 102 4 Boost pressure circuit failed low
35 p 19 March Ext range oil pressure circuit failed high
35 p 100 3 Chain oil pressure. Short circuit in the power
36 P 19 April Ext range oil pressure circuit failed low
36 P 100 4 Chain oil pressure. Short circuit in the ground
37 P 18 March Ext range fuel pressure circuit failed high
37 P 94 3 Chain fuel pressure. Short circuit in the power
37 P 95 3 Fuel Filter Restriction circuit failed high
38 P 18 April Ext range fuel pressure circuit failed low
38 P 94 4 Chain fuel pressure. Short circuit in the ground
38 P 95 4 Fuel Filter Restriction circuit failed low
39 S 146 2 Mechanical error EGR valve
39 S 146 12 Mechanical error EGR valve
39 S 146 return valve 7 does not meet the exhaust
39 S 147 2 turbocharger control mechanism does not respond
39 s 147 12 turbocharger control mechanism does not respond
39 s 14 147 current returns exhaust gases enough
39 S 147 11 turbocharger control mechanism does not respond
39 S 147 7 turbocharger control mechanism does not respond
41 S 21 0 Too many SRS (missing TRS)
42 S 21 January Too few SRS (missing SRS)
43 p 111 1 Low coolant level
44 p 52 0 ntercooler coolant temp, high
44 p 105 0 temperature in the reservoir above the norm
44 p 110 0 antifreeze temperature above normal
44 p 172 0 Air inlet temp, high
44 p 175 0 Oil temperature above normal
45 p 19 January Ext range oil pressure low
45 p 100 1 Oil pressure below normal
46 p 168 1 Low voltage batteries
46 S 214 1 RTC Backup Battery Voltage Low
46 S 232 1 Sensor Supply Voltage Low A3 & W1
P 0 47 18 Ext range fuel pressure high
P 47 94 0 The fuel pressure above normal
47 p 0 102 Turbo boost press high
47 p 106 0 Air inlet pressure high or TCBV diff press high
47 p 164 0 Injection control pressure high
48 p 18 January Ext range fuel pressure low
48 p 94 1 fuel pressure below normal
48 p 106 1 Air inlet pressure low
48 p 164 1 Injection control pressure low
48 p 351 1 TCI Temperature below range
48 p 404 1 TCO Temperature below range
48 p 411 1 EGR Delta pressure low
48 p 412 1 EGR Temperature low
49 p 351 0 TCI Temperature above range
49 p 404 0 TCO Temperature above range
More Fault Codes here Detroit Disel DTC
on Dec 20, 2016 | Cars & Trucks
Tip
Battery Charge at high temperatures and low
a-collection-of-photoshop-business-card-tutorials-and-free-psd-files-300x156.jpg Nickel-metal-hydride is less forgiving than nickel-cadmium, if applied in high and low temperatures. Nickel-metal hydride may not be quick to load below 10 â° C (45 â° F) and can not be slow to load below 0 â° C (32 â° F). Some industrial chargers are designed to adjust the rate to the current temperatures. price sensitivity does not allow the processing temperature sensing charger consumers.
At higher temperatures, the charge acceptance of nickel-based BTP-58A1 batteries is drastically reduced. A HP 530 battery that provides up to 100% when applied at moderate temperature can only accept 70% if charged at 45 â° C (113 â° F) and 45% if charged at 60 â° C (140 â° F). This demonstrates the poor performance of some summer car charger.
Lead-acid is fairly tolerant to extreme temperatures, as we are familiar with our car batteries. Part of this tolerance is accredited to the slowness of the system lead-acid. Some brands Inspiron Mini 9 (all 8.9 series) battery can freeze and low loads, while others say the damage and provide reduced service and a short life.
To improve the performance of lead-acid battery to colder temperatures and avoid thermal runaway during periods of heat, the control voltage limit, at which the INSPIRON 9300 battery is charged, is important. Implementation of this measure can extend the battery life of up to 15%. General guidelines suggest a compensation of approximately 3 mV per cell per degree Celsius. The voltage regulation has a negative coefficient, meaning that the threshold voltage decreases with increasing temperature.
Heat kills DV2000 battery. The hotter the cells, the shorter the life. High temperatures can not always be avoided, especially during fast charging, but efforts must be made to keep this short time. While 45 â° C (113 â° F) is acceptable if kept short, at 50 â° C (122 â° F) and above, the battery starts to suffer. Note that the cells inside the packaging are always a few degrees warmer than the temperature of the body.
on Apr 21, 2010 | Computers & Internet
P 1492 obd fault code mahindra Maximo
Take your pick;
Chrysler/Dodge/Jeep:
Ambient/ Battery Temp sensor input voltage too high
Citroen/Peugeot:
APLSOL Solenoid Circuit Malfunction
Ford:
Infinity:
EVAP Canister Purge Control/Solenoid Valve (Circuit)
Mercedes:
Mitsubishi:
Battery temperature sensor high voltage
Nissan:
Purge Control/V S/V
Plymouth:
Battery Temperature Sensor Voltage Too High
Saab:
EVAP Tank Pressure Sens. Value too low when Depressurised and malfunctional fuel level sen
Subaru:
EGR SIGNAL LINE 1 CIRCUIT (LOW)
Sep 27, 2017 | Mahindra Cars & Trucks
Error code p1041 and p1047 02 chrysler sebring lxi 2.7L
Definition of Diagnostic Trouble Code P1041 Saab: Injector Cylinder 4 Shorting To Ground
There is no definition for DTC P1047
CodeDescription P1192 Inlet Air Temp. Circuit Low P1193 Inlet Air Temp. Circuit High P1195 1/1 O2 Sensor Slow During Catalyst Monitor P1196 2/1 O2 Sensor Slow During Catalyst Monitor P1197 1/2 O2 Sensor Slow During Catalyst Monitor P1198 Radiator Temperature Sensor Volts Too High P1199 Radiator Temperature Sensor Volts Too Low P1281 Engine Is Cold Too Long P1282 Fuel Pump Relay Control Circuit P1283 Idle Select Signal Invalid P1284 Fuel Injection Pump Battery Voltage Out Of Range P1285 Fuel Injection Pump Controller Always On P1286 Accelerator Pedal Position Sensor Supply Voltage Too High P1287 Fuel Injection Pump Controller Supply Voltage Low P1288 Intake Manifold Short Runner Solenoid Circuit P1289 Manifold Tune Valve Solenoid Circuit P1290 CNG Fuel Pressure Too High P1291 No Temp Rise Seen From Fuel Heaters P1292 CNG Pressure Sensor Voltage Too High P1293 CNG Pressure Sensor Voltage Too Low P1294 Target Idle Not Reached P1295 No 5 Volts To TP Sensor P1296 No 5 Volts To MAP Sensor P1297 No Change in MAP From Start To Run P1298 Lean Operation At wide Open Throttle P1299 Vacuum Leak Found (IAC Fully Seated) P1388 Auto Shutdown (ASD) Relay Control Circuit P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM P1390 Timing Belt Skipped One Tooth or More P1391 Intermittent Loss of CMP or CKP P1398 Mis-Fire Adapter Numerator at Limit P1399 Wait To Start Lamp Circuit P1403 No 5 Volts To EGR Sensor P1475 Aux. 5 Volt Output Too High P1476 Too Little Secondary Air P1477 Too Much Secondary Air P1478 Battery Temp Sensor Volts Out of Limit P1479 Transmission Fan Relay Circuit P1480 PCV Solenoid Valve P1482 Catalyst Temperature Sensor Circuit Shorted Low P1483 Catalyst Temperature Sensor Circuit Shorted High P1484 Catalytic Converter Overheat Detected P1485 Air Injection Solenoid Circuit P1486 Evap Leak Monitor Pinched Hose P1487 Hi Speed Rad Fan CTRL Relay Circuit P1488 Auxiliary 5 Volt Supply Output Too Low P1489 High Speed Fan CTRL Relay Circuit P1490 Low Speed Fan CTRL Relay Circuit P1491 Rad Fan Control Relay Circuit P1492 Battery Temperature Sensor Voltage Too High P1493 Battery Temperature Sensor Voltage Too Low P1494 Leak Detection Pump Switch or Mechanical Fault P1495 Leak Detection Pump Solenoid Circuit P1496 5 Volt Supply Output Too Low P1498 High speed Rad Fan Ground CTRL Rly Circuit P1594 Charging System Voltage Too High P1595 Speed Control Solenoid Circuits P1596 Speed Control Switch Always High P1597 Speed Control Switch Always Low P1598 A/C Pressure Sensor Volts Too High P1599 A/C Pressure Sensor Volts Too Low P1602 PCM Not Programmed P1680 Clutch Released Switch Circuit P1681 No I/P Cluster CCD/J1850 Messages Received P1682 Charging System Voltage Too Low P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit P1684 Battery Disconnected Within Last 50 Starts P1685 Skim Invalid Key P1686 No SKIM Bus Message Received P1687 No Cluster Bus Message P1688 Internal Fuel Injection Pump Controller Failure P1689 No Communication Between ECM & Injection Pump Module P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor P1691 Fuel Injection Pump Controller Calibration Failure P1693 DTC Detected In ECM Or PCM P1694 No CCD Messages Received From ECM P1695 No CCD/J185O Message From BCM P1696 PCM Failure EEPROM Write Denied P1697 PCM Failure SRI Mile Not Stored P1698 No CCD Messages Received From PCM P1719 Skip Shift Solenoid Circuit P1740 TCC Or OD Solenoid Performance P1756 Governor Pressure Not Equal To Target At 15?20 PSI P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI P1762 Governor Pressure Sensor Offset Improper Voltage P1763 Governor Pressure Sensor Voltage Too High P1764 Governor Pressure Sensor Voltage Too Low P1765 Trans 12 Volt Supply Relay Control Circuit P1899 Park/Neutral Position Switch Stuck In Park or In Gear
Read more at: http://www.obd-codes.com/trouble_codes/dodge/
Copyright © OBD-Codes.com
Jul 26, 2015 | Chrysler Cars & Trucks
How to look up codes for check engine light on harley davidson flhx
Type it into a search engine:
B0563 Battery Voltage High TSM/TSSM
B1004 Fuel Level Sending Unit Low Instruments
B1005 Fuel Level Sending Unit High/Open Instruments
B1006 Accessory Line Overvoltage Instruments
B1007 Ignition Line Overvoltage Instruments
B1008 Reset Switch Closed Instruments
B1131 Alarm Output Low TSM/TSSM
B1132 Alarm Output High TSM/TSSM
B1134 Starter Output High TSM/TSSM
B1135 Accelerometer Fault TSM/TSSM
B1151 Sidecar BAS Low TSM/TSSM
B1152 Sidecar BAS High TSM/TSSM
B1153 Sidecar BAS Out of Range TSM/TSSM
P0106 MAP Sensor Rate of Range Error Carb
P0107 Map Sensor Failed Open/Low Carb
P0107 Map Sensor Open/Low EFI
P0108 Map Sensor Failed High Carb
P0108 Map Sensor High EFI
P0112 IAT Sensor Voltage Low EFI
P0113 IAT Sensor Voltage Open/High EFI
P0117 ET Sensor Voltage Low EFI
P0118 ET Sensor Voltage Open/High EFI
P0122 TP Sensor Open/Low EFI
P0123 TP Sensor High EFI
P0261 Front Injector Open/Low EFI
P0262 Front Injector High EFI
P0263 Rear Injector Open/Low EFI
P0264 Rear Injector High EFI
P0373 CKP Sensor Intermittent Carb
P0373 CKP Sensor Intermittent EFI
P0374 CKP Sensor Not Detected Carb
P0374 CKP Sensor Synch Error EFI
P0501 VSS Low Carb
P0501 VSS Low EFI
P0502 VSS High/Open Carb
P0502 VSS High/Open EFI
P0505 Loss of Idle Sped Control EFI
P0562 Battery Voltage Low Carb
P0562 Battery Voltage Low EFI
P0563 Battery Voltage High Carb
P0563 Battery Voltage High EFI
P0602 Calibration Memory Error Carb
P0603 EEPROM Failure Carb
P0603 ECM EEPROM Error EFI
P0604 RAM Failure Carb
P0605 Program Memory Error Carb
P0605 ECM Flash Error EFI
P0607 Converter Error Carb
P1001 System Relay Coil Open/Low EFI
P1002 System relay Coil High/Shorted EFI
P1003 System relay Contacts Open EFI
P1004 System Relay Contacts Closed EFI
P1009 Incorrect Password Carb
P1009 Incorrect Password EFI
P1010 Missing Password Carb
P1010 Missing Password EFI
P1351 Front Ignition Open/Low Carb
P1351 Front Ignition Open/Low EFI
P1352 Front Ignition Coil High/Shorted Carb
P1352 Front Ignition Coil High/Shorted EFI
P1353 Front Cylinder No Combustion EFI
P1354 Rear Ignition Coil Open/Low Carb
P1354 Rear Ignition Coil Open/Low EFI
P1355 Rear Ignition Coil High/Shorted Carb
P1355 Rear Ignition Coil High/Shorted EFI
P1356 Rear Cylinder No Combustion EFI
P1357 Intermittent Secondary Front EFI
P1358 Intermittent Secondary Rear EFI
U1016 Loss of ICM/ECM Serial Data Instruments
U1016 Loss of ECM Serial Data, Vehicle Speed, Vehicle Inhibit Motion or Powertrain Security Status TSM/TSSM
U1064 Loss of TSM/TSSM Serial Data Carb
U1064 Loss of TSM/TSSM Serial Data EFI
U1064 Loss of TSM/TSSM Serial Data Instruments
U1097 Loss of Speedometer Serial data Carb
U1097 Loss of Speedometer Serial data EFI
U1097 Loss of Speedometer Serial data TSM/TSSM
U1255 Missing Message at Speedometer EFI
U1255 Serial Data Error/Missing Message EFI
U1255 Serial Data Error/Missing Message Instruments
U1255 Serial Data Error/Missing Message TSM/TSSM
U1300 Serial Data Low Carb
U1300 Serial Data Low EFI
U1300 Serial Data Low Instruments
U1300 Serial Data Low TSM/TSSM
U1301 Serial Data Open/High Carb
U1301 Serial Data Open/High EFI
U1301 Serial Data Open/High Instruments
U1301 Serial Data Open/High TSM/TSSM
AFR - Air Fuel Ratio
ATS - Air Temperature Sensor
BAS - Bank Angle Sensor
CCM - Cruise Control Module
CKP - Crank Position Sensor. The CKP generates an "AC signal" which is sent to the ECM where it is used to reference engine position (TDC) and speed.
DTC - Diagnostic Trouble Codes
ECM - Electronic Control Module. (The Computer) Computes the spark advance for proper ignition timing and fuel control based on sensor inputs
(from CKP, MAP & TP sensors) and controls the low-voltage circuits for the ignition coils and injectors.
The dwell time for the ignition coil is also calculated in the microprocessor and is dependent upon battery voltage. The programmed dwell feature gives adequate spark at all speeds.
ECT - Engine Coolant Temperature. Sensor also controls the cooling fan relay that provides 12 Vdc to the fans.
EFI - Electronic Fuel Injection
EFP - Electronic Fuel Pump
ET - Engine Temperature sensor
FI - Fuel Injectors
FPR - Fuel Pressure regulator
IAC - Idle Air Control actuator
IAT - Intake Air Temperature sensor
ISS - Ion Sensing System...detonation detection
MAP - manifold Absolute Pressure sensor. The MAP sensor monitors the intake manifold pressure (vacuum) and sends the information to the ECM.
The EMC then adjusts the spark and fuel-timing advance curves for optimum performance.
TP - Throttle Position Sensor
TSM/TSSM (Turn Signal/ Turn Signal Security Module)
VE - Volume Efficiency
VSS - Vehicle Speed Sensor. Used as an input for idle speed control
May 02, 2014 | 2011 Harley Davidson FLHX Street Glide
Saber que es codigo 15 codigo 20 y codigo 25 isuzu trooper mod 1988 gasolina 2.600 cc. inyectado
Revise estos codigos correspondientes al sistema OBD I...
13 Open Oxygen Sensor Circuit
14 Coolant Temperature Sensor (High Temp Indicated)
15 Coolant Temperature Sensor (Low Temp Indicated)
21 Throttle Position Sensor (Signal Voltage High)
22 Throttle Position Sensor (Signal Voltage Low)
23 Manifold Air Temperature (MAT) Low Temp Indicated
24 Vehicle Speed Sensor (VSS) Circuit
25 Manifold Air Temperature (MAT) High Temp Indicated
32 EGR system fault
33 MAP sensor circuit (signal voltage high, low vacuum)
34 MAP sensor circuit (signal voltage low, high vacuum)
44 Oxygen Sensor Circuit (Lean Exhaust Indicated)
45 Oxygen Sensor Circuit (Rich Exhaust Indicated)
51 PROM error (faulty or incorrect MEM-CAL).
Suerte.
Apr 18, 2011 | 1987 Isuzu Trooper
I NEED FREE USER MANUAL FOR SHARP SF-8100 COPIER
Sharp 8100 file of manual
http://files.mail.ru/N4G1OG
Please vote for me for my answer. Senks) Код ошибки Описание 0 Stepping motor 10 Mirror motor 40 Dark box switch 8 Mirror motor C1 Charge corona C2 Transfer corona C3 Discharge corona CH Interlock or thermal fuse CH possible DV unit not installed properly H1 Heater thermal fuse H2 Thermistor H3 High Temperature H4 Low Temperature H5 Lower thermofuse H6 Lower thermistor H7 High temperature in lower roller H8 Low temperature in lower roller L1 Forward Scan L2 End of Scan L3 Return of Scan L4 PT/main motor L5 Lens L6 Charge block switch P1 Copy lamp thermal fuse U1 Low battery U2 Data transfer U3 Dark box
Sep 14, 2009 | Sharp Office Equipment & Supplies
Error codes, oil pressure sensor and engine control moduale
Hello, It should actually be an oil sending unit, and is located on the back of the intake manifold to the left of the distributor. *The P0523 is Oil Pressure Sending Unit Voltage too high *P1693 Generic fault indicating a fault in the bus or PCM/ECM interface *P1682 - I can't find this code Anyways, I will post here all the error codes for future reference. Dodge Cummins Check Engine Error Codes Cycle Key on-off-on-off-on to read codes in odometer display P0002 ECM fuel calibration error P0016 Crankshaft/Camshaft Timing Misalignment/Out-of- Sync P0071 Ambient Temperature Sensor Performance / Rationality P0072 Ambient Temperature Sensor Low P0073 Ambient Temperature Sensor High P0088 Fuel Rail Pressure Too High P0106 Manifold Absolute Pressure Sensor Performance / Rationality P0107 Manifold Absolute Pressure Sensor Low P0108 Manifold Absolute Pressure Sensor High P0111 Intake Air / Charge Temperature Sensor Performance / Rationality P0112 Intake Air / Charge Temperature Sensor Low P0113 Intake Air / Charge Temperature Sensor High P0116 Engine Coolant Temperature Sensor Performance / Rationality P0117 Engine Coolant Temperature Sensor Low P0118 Engine Coolant Temperature Sensor High P0121 Accelerator Position Sensor (APPS) Signal Voltage Too Low P0122 Accelerator Position Sensor (APPS) LowAPPS Voltage Input Too Low P0123 Accelerator Position Sensor (APPS) Signal Voltage Too High P0128 Cooling System Error / Thermostat Rationality P0148 Fuel Delivery Error P0168 Fuel Temp Too High P0169 Water-in-Fuel Detected For Too Long P0192 Fuel Rail Pressure Sensor Low P0193 Fuel Rail Pressure Sensor High P0201 Fuel Injector 1 Circuit P0202 Fuel Injector 2 Circuit P0203 Fuel Injector 3 Circuit P0204 Fuel Injector 4 Circuit P0205 Fuel Injector 5 Circuit P0206 Fuel Injector 6 Circuit P0216 Fuel Injection pump Timing Malfunciton [new injector pump time] P0217 Coolant Temperature Too High P0219 Engine Overspeed P0230 Transfer pump circuit out of range P0234 Turbocharger Overboost Condition P0235 Turbocharger Boost Sensor A Circuit P0236 Turbocharger Boost Pressure Sensor Performance / Rationality P0237 Turbocharger Boost Pressure Sensor Low P0238 Turbocharger Boost Pressure Sensor High P0251 Fuel Injection Pump Mechanical Failure Fuel Valve Feedback Circuit P0252 Injection Pump Fuel Metering Control "A" Range/Performance P0253 Fuel Injection Pump Fuel Valve Open Circuit P0254 Fuel Injection Pump Fuel Valve Current Too High P0300 Multiple Cylinder Misfire P0301 Cylinder 1 Misfire P0302 Cylinder 2 Misfire P0303 Cylinder 3 Misfire P0304 Cylinder 4 Misfire P0305 Cylinder 5 Misfire P0306 Cylinder 6 Misfire P0335 Crankshaft Position Sensor Circuit P0336 Crankshaft Position Sensor Performance P0337 Crankshaft Position Sensor Circuit Low P0338 Crankshaft Position Sensor Circuit High P0340 Camshaft Position Sensor Circuit P0341 Camshaft Position Sensor Performance / Rationality P0370 Timing Reference High Resolution Signal "A" P0380 Intake Air Heater #1 Control circuit P0381 Wait-to-Start Lamp Inoperative P0382 Intake Air Heater #2 Control circuit P0460 Fuel Level Sensor A Circuit P0461 Fuel Level Sensor 1 Performance / Rationality P0462 Fuel Level Sensor 1 Low P0463 Fuel Level Sensor 1 High P0477 Exhaust Pressure Control Relay Low P0478 Exhaust Pressure Control Relay High P0480 Cooling Fan 1 Control Circuit/Open (Low Speed Fan Relay) P0483 Cooling Fan Speed P0500 Vehicle Speed Sensor 1 Circuit, or No Vehicle Speed Reference Signal 1 P0514 Battery Temperature Sensor Performance / Rationality P0516 Battery Temperature Sensor Low P0517 Battery Temperature Sensor High P0521 Oil Pressure Sensor Performance / Rationality P0522 Engine Oil Pressure Sensor/Switch Circuit Low Input P0523 Oil Pressure Sending Unit Voltage too high P0524 Oil Pressure Too Low P0532 A/C Pressure Sensor Low P0533 A/C Pressure Sensor High P0541 Intake Air Heater Relay 1 Low P0542 Intake Air Heater Relay 1 High P0562 Battery Voltage Low P0563 Battery Voltage High P0572 Brake Switch 1 Low P0573 Brake Switch 1 High P0576 Cruise Control Input Circuit Low P0580 Speed Control Multiplexed Switch 1 Low P0581 Speed Control Multiplexed Switch 1 High P0602 Control Module Programming Error/NotProgrammed P0604 Internal Control Module RAM Integrity Failure P0606 Internal ECM Processor P0607 ECU Internal Performance P0622 Generator Field Control Circuit P0628 Fuel Pump Relay Circuit Low, or Fuel Lift Pump Control Circuit Low P0629 Fuel Pump Relay Circuit High, or Fuel Lift Pump Control Circuit High P0630 VIN Not Programmed in PCM P0633 SKIM Key Not Programmed in PCM P0642 Sensor Reference Voltage 1 Circuit Low P0643 Sensor Reference Voltage 1 Circuit High P0646 A/C Clutch Relay Circuit Low P0647 A/C Clutch Relay Circuit High P0652 Sensor Reference Voltage 2 Circuit Low P0653 Sensor Reference Voltage 2 Circuit High P0698 Sensor Reference Voltage 3 Circuit Low P0699 Sensor Reference Voltage 3 Circuit High P0700 Transmission Control System (MIL Request) P0743 Torque Converter Clutch Circuit Electrical P0753 Shift Solenoid "A" Electrical P0837 Four Wheel Drive (4WD) Switch Performance / Rationality P0838 Four Wheel Drive (4WD) Switch Circuit Low P0839 Four Wheel Drive (4WD) Switch Circuit High P1488 Auxiliary 5 volt supply output is too low P1492 Ambient/batt temp sensor volts too high P1493 Ambient/batt temp sensor volts too low P1596 Speed Control Switch always high P1597 Speed Control Switch always low P1652 J1850 Communication Bus P1687 No Cluster BUS Message or No Messages from the Mechanical Instrument Cluster P1688 Internal Fuel Injection Pump Controller Failure P1689 No Communication Between ECM & Injection Pump Module P1690 Fuel injection pump CKP Sensor Does Not Agree With ECM CKP Sensor P1691 Fuel Injection Pump Controller Calibration Failure P1693 Generic fault indicating a fault in the bus or PCM/ECM interface P1757 Governor pressure is above 3 PSI when 0 PSI is requested P1762 Governor Press Sensor Offset Volts Too Low or Too High P1765 Transmission 12 volt supply relay control circuit P2121 Pedal Position Sensor 1 Performance / Rationality P2122 Pedal Position Sensor 1 Low P2123 Pedal Position Sensor 1 High P2127 Pedal Validation Switch 2 Low P2128 Pedal Validation Switch 2 High P2146 Fuel Injector Group 1 Supply Voltage Circuit P2149 Fuel Injector Group 2 Supply Voltage Circuit P2266 Water in Fuel Sensor Circuit Low P2269 Water in Fuel Condition P2502 Charging System Output Voltage P2503 Charging System Output Low P2504 Charging System Output High P2509 ECM/PCM Power Input Signal Intermittent P2607 Intake Air Heater Relay 2 Low P2608 Intake Air Heater Relay 2 High P2609 Intake Air Heater System Performance Hope this will help you. Cheers! Ryan
Jun 11, 2009 | 1999 Dodge Ram
Cell Phones Logo
26 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
