Question about Dedicated Micros Digital Sprite 2 RS Video Recorder
Lost signal to the monitor / tv from the DVR
What type of cord should be used for this connection
  • computur virus removal and other tech support
    Hi Angie Tanner, I want to help you with your problem, but I need more information from you. Can you please tell me what monitor you are using
Lost signal from dvr to vizio tv and need to know what type of cord is used for this connection
That would have to be either a HDMI cable similar to usb but not totally rectangle or the old 3 lead RCA to RCA cables which are red and white for audio and yellow for video.
Apr 14, 2014 | Dedicated Micros Televison & Video
Connecting surround sound to tv
You need cords for this, make sure you have all of your correct cords in the socket, and if you are 100% positive this is so, contact your seller and tell him your case.
Nov 29, 2007 | Philips 43P8341 43" Rear Projection...
I have a Denon avr-3808ci. I have a Dish Network DVR and a Sony KDS-60A2020 tv. If I connect the HDMI cable on the DVR directly to the tv, I get picture and sound through the tv. If I connect the HDMI...
You are correct. I feel your pain. This will not work.
HDMI is a pure digital signal and the providers require the content coming over the Dish DVR to be COPY PROTECTED. So it will not work unless the HDMI cable goes directly from the DVR to the TV. This is to stop people from being able to make their own recordings of Dish shows, or making copies of your DVR recordings. If you really want to run things through your reciver, you're going to have to use the "component" or "composite" video feeds, not the HDMI. Sorry.
Sep 18, 2011 | Denon AVR 3808Ci Receiver
I would like to connect the audio from my Comcast DVR via digital optical thru the TV/SAT IN optical on the receiver at the same time I have a composite connection via the TV RCA composite jacks. ( This...
I'm a little confused by your use of 'composite' with audio, as in "Does anyone know what would happen if I ran both composite audio and optical audio both to their respective TV/SAT IN input jacks on the STRDE935 ?". What is composite audio?
The manual claims on page 48 that you can't record digital audio out to the analog REC OUT jacks.
http://www.retrevo.com/s/Sony-STR-DE935-Receivers-review-manual/id/387dj981/t/1-2/
I say 'claims' because the engineers or manual writers clearly are not as creative as you are in trying to wring as much utility out if this unit as possible.
I can't find an answer but I would offer this - if you are recording anything though any AVR, as soon as you choose to monitor the audio the digital input is usually disabled.
And I would be curous to hear more about what you're doing and how you finally achieve it.
Dec 25, 2010 | Sony STR-DE935
Vizio 32 inch hdtv, Motorola DVR box...Whenever I turn the tv off, the cable connection is lost and I have to unplug/replug the DVR box when I want to watch the cable again. It's not the box, because I...
Here a way,u could test,if it the cable signal,tv Main tuner board have problem or the DVR box again.U have analog antena?Or go and a buy a digital antena.Reset ur tv to free air signal and use it for few hours,turn it off/on and see if u losing signal,require unplug,replug to get signal back.Two problems solved ur tv board or cable signal good or not?Than U know it the DVR box and have connecting problems.
Mar 19, 2010 | Vizio VW32L 32 in. LCD HDTV
Is it possible to use HW173D monitor with DVR and security camera
Unless your DVR offers a VGA output connector, you won't be able to use your monitor simply by plugging in a cable. The monitor VGA input requires separate signals for each color (red, green and blue) and synchronizing signals (vertical and horizontal). If the DVR has only composite video out, you'll need a video to VGA adapter. These are available from many online sources. They aren't cheap since they are active electronic devices, but many are in the $50 to $75 range. Here is one typical result from a Google search for "video to vga converter". You might also check eBay or local sources such as craigslist to see if anybody has bargains.
Feb 10, 2010 | Hanns.G Corporation HW173D Monitor
Connecting HD cable box to DVR too HDTV
When I hooked up my HD cable box using an HDMI cable, I had to go into the cable screen menus and select HDMI output. You may have to do something similar when using an S-video cable. Your DVD recorder doesn't seem to have an HDMI input, so you'll have to use the S-video or (worst case) composite video (red, white, yellow cords). Your cable box may also be scrambling the signal so that you can't record. That may be why you can record by bypassing the cable box.
Jun 22, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
DVR/TV connection
With the RGB you have to run seperate audio ,I think you have ran the seperate cables for the sound but they are in the wrong place.try changing the RW from the DVR to the TV and you should get sound from them.The unfortunate truth about the HDMI is that the HDMI format has a problem effectivly communicating between components.I am a Directv certified High Definition technition and %50 of the TV's that I connect the HDMI to will not receive the signal.One trick that I have found that works is to make sure you have a picture on the RGB then connect the HDMI.Once you have these connected ,turn your TV off and unplug the power cord from the DVR for 30 sec then plug the DVR in and wait 5 minutes for it to power up then turn your TV on and switch to your HDMI input.This method sometimes works to "Jumpstart" the HDMI input on the TV .There is no guarantee that this will work but is sounds like for now this is your only option,GOOD LUCK.
Dec 29, 2007 | Televison & Video
Televison & Video Logo
42 people viewed this question
Top Dedicated Micros Televison & Video Experts
Electro Med Services...
Are you a Dedicated Micros Televison and Video Expert? Answer questions, earn points and help others
