Question about Stealth Cam, LLC Stealthcam Stcu735ir Skout 7 Triad-Equipped 36 Ir Scouting Camera - Stcu735ir
STC-U735IR & Manual - Stealth Cam, LLC Stealthcam Stcu735ir Skout 7 Triad-Equipped 36 Ir Scouting Camera - Stcu735ir
Stc sim card puk code pleas
talk your stc customer care by other stc sim
May 03, 2015 | Cell Phones
Stc modam nck code
Please I need NCK code for STC TCT dongle imei no 356237034619476
Feb 02, 2013 | Computers & Internet
How to unlock stc usb modem
i have one touch x230l stc usb modem
imei:867597004338031
please give me the nck code
May 20, 2012 | Computers & Internet
Truck cummings 9800 valve settings
On the Celect,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you hand tighten screw until injector plunger bottoms out.Back screw out 2 flats,ie turn corner of lock nut to align with the rivet in the rocker lever(pushtube side),then back out screw two "corners" then tighten the jam nut down.Adjust the Injector first,then the valves.
What is the CPL because it makes a different on injector setting.
CPLs 821,833,903,904,& 806 are 105 INLBS
CPLs 910,827,1185,1188,1210,1211,1256,&1280 are 90 INLBS
CPLs 1374,1380,1395,1405,& 1507 are 125 INLBS
On the STC,you adjust valves & inj on same cyl.The mark A is now 1-6,B is 2-5, & C is 3-4.Valves are Int 0.014 & Exhaust is 0.027.The injector you torque to specs to bottom injector plunger.Then tighten the jam nut down.Adjust the Injector first,then the valves.
On STC it would be greatly advised to run injector flush through the fuel system for an hour to clean carbon off injector tips to prevent plugging spray holes causing a missfire.Cummins sells it in a metal can & you sill need a return & suction line to hook up to engine(one at fuel inlet & one on fuel return) and run it out of the can.
Firing order is 1,5,3,6,2,4
Oct 19, 2011 | OTC 7471A CUMMINS DIESEL ENGINE BARRING...
I have afaq shamel dsl (STC) and somebody is using my wireless network. I want to prevent this person from using my network by changing my wireless network password. How can I do this....
open your browser to 192.168.1.1
the user name is "Afaq_shamel"
the password is "Stccpe_2007" (depending on your model, 2007 could be 2008, 2009 etc.) note that username/password are case sensitive!
once logged in, on the left select basic > LAN
under WLAN at the bottom enable "Security" field and set your password then click submit
of course you could always call STC (907) for further assistance
good luck
Jun 10, 2011 | Computers & Internet
Need nck code for stc modem
i want need to open my stc modem
that modem imei:356237030720393
model name-x080s-2esgsa1-2
May 24, 2011 | Computers & Internet
Manual for Stc hd-400 NEEDED
Search online. Most documentation can be found using Google.
Feb 20, 2010 | Advanced Electronic Support Stealth Cam...
Stealth Cam, LLC Stealthcam Stcu735ir Skout 7 Triad-Equipped 36 Ir Scouting Camera - Stcu735ir Logo
54 people viewed this question
Top Stealth Cam, LLC Video Cameras Experts
Are you a Stealth Cam, LLC Video Camera Expert? Answer questions, earn points and help others
