Question about JVC Car Audio & Video
Head unit wiring
I have a ford escort 1.6 si and i cant wire my JVC-G111 head unit because some one who had the car befor me cut all the wires behind it so i dont no what wire is for what job so can you help please,thanks
    Novelist:
  • 150 Answers
Sensible thing to do if you really want to use the factory wiring is to go to the local scrap yard and find a vehicle similar to yours and go cut the wiring harness off one of theirs and reconnect yours all nice and good- then just get the wiring adapter for your vehicle at your local stereo shop and wire away-hope that helps
Posted on Jun 19, 2009
Hi im putting in a JVC cd/radio in a 1997 ford escort TD,Ive removed factory fitted Ford radio cassette,leaving 5 wires connected to a yellow plug,I have 3 wires coming out of JVC marked yellow memory back...
hi...well i know this might not be of any help, but you can buy a connector that plugs straight into the ford plug, and then you plug the jvc plug/s into that, not cutting wires no messing up the original connector just incase you want to sell the car with original system in it... http://productfinder.autoleads.co.uk/productinfo.aspx?&m=FORD&f=ESCORT&id=463&pID=6889
thats the link for it...if you tell me what colours are on the ford plug i could tell you what goes where...thanks
Feb 04, 2011 | 1995 Ford Escort
I recently put a new head unit in my 2002 ford escort zx2.. now dash lights (speedometer and what not), reverse lights, and my shifter lights wont work at all.? any ideas
Probably cut or pulled something out of place when you installed the new head unit. I would pull it out and do a visual inspection to see if there are any damaged wires or if something came unplugged.
Jan 16, 2011 | 2002 Ford ZX2
1999 ford escort I changed the plugs, but broke a plug cap. Bought a generic replacement spark plug wire that had to be modified to fit into the head. I cannot get the firing order correct. The car...
Remove the plugs from the head. Insert into the coil wires. Make sure they are properly earthed on the engine. Crank the motor and check for spark at each of the plugs.
Refer to the diagram. Cylinders are connected as shown on the diagram in blue. 1 goes to cylinder 1(sparkplug furthest from coil pack), 2 to 2, 3 to 3 and 4 to 4(closets to coil pack).
To test the coil pack use a digital volt meter. Measure resistance between coil towers for coil 1(marked 1 in red on diagram) Value should be between 12000 and 14500 ohm. Do the same for coil towers 2.
Measure resistance between I and C1. If the measurement is more than 5 ohm the coil is defective. Do the same for I to C2.
Measuring voltage at I(Ignition start/run) to ground should be 10V.
I is connected to the 15A engine fuse. The radio interference capacitor is connected between this line and earth at the coil. Disconnect it to see if it cures the problem.
C1 and C2 connect to the powertrain control module.
Bear in mind that aftermarket coil wires may cause problems with misfiring, so see if you cant find an OEM coil wire to replace the broken one before replacing anything else.
Nov 15, 2010 | 1989 Ford Escort
Wiring color code for a 1997 ford escort si for the heater fan motor reostat/diode unit that controls the fan speed
electric window switch replaced but loating the correct fuse details/wiring details required for replaced tailgate .
Jun 04, 2010 | 1997 Ford Escort
Im trying to wire an amp remote wire huh
the blue or blue with white wire. 1 is for the amp and the other is for a motorized antenna try either 1, you can not short any thing by hooking up the wrong one
Apr 25, 2010 | Car Audio & Video
'99 ford escort head light will dim when
The wiring harnesses in the plugs behind the bulbs are burned up seperate rear of headlight cover and inspect parts available at your ford dealer
Mar 31, 2010 | 1999 Ford Escort
Wiring diagram for jvc model no ks-fx460r
http://books.jvc.com/booklist.asp?Model=+ks-fx460r this should take you to the down loadable manual for that head unit.
Jan 12, 2010 | Car Audio & Video
Powered drivers seat
When dealing with electrical wiring black is either a ground wire or a hot wire. My guess they are ground wires. Use a multimeter or volt meter and check for 12 volts.
May 28, 2009 | 1997 Ford Escort
Hi , I just brought a KD-G646 head unit and it wont play cd's at all. The radio works fine, but the usb only works if the unit is turned down. Could i have something wired wrong or is the unit faulty. It...
well, the USB problem i cant help you with, but if the cd isnt loading, theres probably something wrong with the loading mechanism, which usually means that the unit is faulty. it would be more cost efficient to buy a new head unit than to pay someone for the parts and labor to repair the one you have.
Aug 18, 2008 | JVC Car Audio & Video
Car Audio & Video Logo
71 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
