Question about Sharper Image Play N Roll Piano
Sharper Image Keyboard Midi Out - Sharper Image Play N Roll Piano
Keyboard conection
Most are a 3 - 5 pin midi, you need midi cables and a midi interface, they do make a
midi - usb cable for connecting keyboard to a computer,
hope this helps?
Mar 04, 2015 | Music
While using korg m50 editor using usb data cable there is no sound from my lap.the sound is only from my head phone connected to my keyboard directly?
Are you connecting to the laptop and using it as a midi controller? You can record midi notes from the keyboard and send them to your laptop via USB using any midi sequencer program (reason, logic, etc). Create a midi track, select the input of that track as your keyboard, then hit record to play some midi notes. To hear what you record, you have to set the output of the midi track to whatever midi sounds or instrunents you have installed on your laptop.
If you are trying to record the actual audio sound the keyboard makes, use an audio program such as cubase, sonar, audacity, pro-tools, and either mic the keyboard, or connect one of the other audio outputs (1/4" TRS) to an audio input on your DAW, and record an audio track that way (as opposed to a midi track).
Apr 13, 2012 | Korg M50 61-Key Music Workstation Keyboard...
I bought a usb to midi device for my Casio CTK-491, but none of my VST's or DAW's receive midi information from the keyboard, The programs see that there is a midi input and output but the computer...
what program are you running and did you set up your keyboard with the software so it can recognize it. Depending on what software it is your using as soon as I know I can tell you how to get it working. I use my midi keyboard with everything from reason, Ableton live, pro tools logic logic express vdj traktor basically every software!
May 29, 2011 | Casio Ctk491 Midi Keyboard
What kind of USB cable do I need for my CTK-491 Keyboard, and where can I find it?
You will need MIDI cable - widely available from good musical instrument (keyboard) stores and on the internet
For more information about using MIDI on your keyboard see the appropriate section in teh user's manual here http://support.casio.com/pdf/008/ctk_491_01_e.pdf
Feb 10, 2011 | Casio Ctk491 Midi Keyboard
Have a casio px 320 and trying to use it in GarageBand on my Mac OS X. Connecting USB cable from USB output on Casio to USB input on Mac doesn't work. Any help?
use the audio output to send the keyboards internal patch sounds, or use a usb midi adapter to use the keyboard to trigger the garageband midi sounds, if the keyboard has a midi output, that is. the usb output requires software drivers to use, and IS NOT mac compatible. You may have to select a midi source in garage band preferences or settings if you are using midi.
Nov 14, 2010 | Casio Privia Keyboard Case
Fruity loops old version with casio keyboard
You haven't said whether or not you are using a demo ,version of FL. If you purchased they have Lifetime Free Updates here:http://flstudio.image-line.com/documents/lifetimefreeupdates.html If you didn't purchase, try downloading the newest demo version here:http://flstudio.image-line.com/documents/download.html Some features of demo programs become disabled after a certain time period. I don't know if midi device recognition is one of them for this program. Try hooking your keyboard up first, making sure that you have the correct drivers for the keyboard, your USB adapter etc. Then start FL and see if the program lists your keyboard in the midi device list.
Mar 03, 2010 | Casio Ctk 496 Electronic Keyboard with 61...
Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Jan 21, 2010 | Casio Privia Keyboard Case
Roland RD-700SX as MIDI keyboard
Theres a good article at recordingreview.com. If you join which is free you have access to a lot of great information. You can download Midiox to troubleshoot your midi connections etc. Make sure that your transmit channel on your keyboard matches up with the receive channel in your program. Hope this helps.
Jul 16, 2009 | Music
Can't get Casio CTK 601 / 611 to function as MIDI Contrller
I'm not at home right now where all my manuals are so I'll try to explain with out. You will have to set it so that the keyboard is the slave device. Try setting it to Omni receive. It has to be able to listen for all midi channels at once. You have to write a sequence on your computer and hook it to your keyboard by using midi out on the computer to midi in on the keyboard in order for you to use the computer as a controller. If you need the keyboard to create the sequences then you have to hook the midi send on the keyboard to the midi in on the computer play/enter your notes into individual tracks in your software then assign channels, voices etc to each track and save the sequence. Then when you hook it up the other way the sequence will play just like an audio recording except the sound w2on't be there. What you have recorded by creating a sequence is a series of midi messages that the keyboard will receive if you have it set properly and hooked up ptroperly which it will translate into sound. This is a minimalist explanation at best. You will have to have a better understanding of not only your keyboard but also your software and midi in general. There are some pretty amazing things you can do with midi. For instance if you have a lighting controller that is midi capable you can i,mbed all the lighting scene changes for your song in order on one track. You can also control your guitar effects pedal to change effects automatically while your playing. Once you get a handle on it you are only limited by your imagination and your budget. Hope this helps in some way.
Jun 01, 2009 | Music
Casio ctk-496 claims to be midi keyboard controller
Try downloading MidiOx and troubleshooting with it. It will show you if you have any midi activity and which channel your Casio is transmitting on etc.
Apr 04, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
Sharper Image Play N Roll Piano Logo
18 people viewed this question
Top Sharper Image Music Experts
Michial Gueffroy
Are you a Sharper Image Music Expert? Answer questions, earn points and help others
