Question about Insignia IS-PDVD10 Portable DVD Player
No power in the player but theres a power in the adapter
No powerbut theres a power in the adapter
    President:
  • 632 Answers
Check adapter terminals if there is voltage or try to use an adapter from a working unit...
Posted on Jun 18, 2009
Where can I buy a iview 700nb charger/adapter?
Look at the point on the case of the player where the adapter would plug into. Voltage and polarity of the center pin is usually found there. Look on the label that has the model and serial number of the unit to see if the power requirements are there. For instance: if you found that the unit needs 1000 Ma of current, you would get an adapter that is capable of supplying more that one amp of power. Never get one that cannot meet the current demands of the player. Once you have that information, you can shop for a power adapter either on line or at a local shop that sells adapters.
Nov 15, 2015 | Iview Televison & Video
Battery drainage iod remove fuse no drainage
You must have done some work recently on vehicle
Lets start with simple back tracing
Ground wires
Starter look at first to see if ground off properly
Brakes
Abs sensors didnt connect right
Radio install
These wires factory set if you spliced into them then undo splices
Wrong tail light bulb
Frozen open or shut relay
Relay panel match relay numbers to other relays there and just do a swap change there positions
On vehicle you have a power transformer for it only holds power
But battery goes to a side terminal its only there to keep memmory
Last but not least simple pedal brake switch these get stuck
Glove box lights trunk lights and door switches these get stuck
When i get out of my s10 my door switch always stayed stuck open it drained my battery replace where needed
Mar 29, 2015 | 2000 Dodge Ram 1500 Truck
Samsung E2130 phone is not powerbut dead
samsung e2130 power solution phone dead
Jul 31, 2012 | Cell Phones
How do you charge it?
I don't have this particular player, but most portable players can be charged by two methods. One is to plug it into your computer via USB, the other is to connect it to an AC adapter.
If you use the first method, be aware that some players need to be plugged into a "high power" USB port in order to charge. Most computers and laptops have a mix of high power and low power USB ports. High power USB ports are typically located on the back panel of the computer.
If you want to connect it to an AC adapter, there are many adapters out there you can use. You might want to Google for "NWZ-E344 charger".
Feb 12, 2010 | Sony Walkman NWZ-E344 Digital Media Player
Lost power adapters
I have a power adapter for the Dual 7 for sale for $29.99 including shipping to lower 48. any interest, email me at 1topwop@comcast.net. warm regards,
Jul 25, 2008 | Durabrand Portable DVD
PDM-0822BD
This is called "audio transfer saturation. Rarely happens but will when there is constant use of player. Drain saturation by removing battery (if attached), With the power adapter still attached, turn off player and unplug adapter from wall for several hours. Saturation should discharge back through you adapter. Disconnect adapter from player before plugging back into wall.You may have to do this periodically when constant music is played.
Feb 29, 2008 | Polaroid PDM-0824 Portable DVD Player
Insignia IS-PDVD10 Portable DVD Player Logo
107 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
