Question about Vehicle Parts & Accessories
I cant find cabine air filter in my proton wira 2004 ,i open the dashboard in the lower of passenger side but nothing inside cover please help me with pictures
    Problem Solver:
  • 30 Answers
I don't know if this model has one but check owners manual should show you where it is
Posted on Apr 14, 2014
3 Suggested Answers
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
  • 2692 Answers
SOURCE: SPARK PLUG GAP NGK BPR5E PLUG
Fix Ya?
Posted on Jan 12, 2009
  • 64 Answers
SOURCE: cabin air filter 2004 Audi
I am no sure of your question but I hope this helps:
You can find the filter at rockauto.com for $7.20
Also any parts store should have them.
Here is a diagram of the locations and steps to replace the filter.
Posted on Apr 06, 2011
Air con not working
the carbon filter is under the dashboard,on passengers side behind the center console. By removing the plastic cover can get out the old carbon filter and replace it.
Apr 02, 2014 | 2006 Peugeot 407 1.6
WHERE IS THE INSIDE CABIN AIR FILTER ON 2008 FORD EDGE LIMITED
The cabin air filter is located behind the glove box. Open it then empty all contents. Grab both sides inside the box and push them inward. The glove box will then drop out further. On the left side is a catch cable. Slide that down and pull it out. The box should then just pull out. The cover for the filter is rectangular and gray or black color. On the left side push the tab toward the passenger door and pull toward you. You will either find nothing or a screen. Discard the screen and insert the new filter.
2011 Ford Edge cabin air filter removal and replacement
Feb 02, 2013 | 2008 Ford Edge SEL
How to replace " cabin
The 2001 model Aztex has 2 cabin filters, they usually come 2 to a box when you buy them.
The charcoal carbon filters are the best.
Removal:
•Open the IP compartment door.
•Remove the rear inside IP compartment door.
•Open the HVAC module assembly access door
•Remove the RH passenger compartment air filter from the HVAC module.
•Slide the LH passenger compartment air filter to the HVAC module opening.
Remove the LH passenger compartment air filter from the HVAC module.
Installation Procedure:
•Install the LH passenger compartment air filter into the HVAC module opening.
Slide the LH passenger compartment air filter toward the left side of the HVAC module.
•Install the RH passenger compartment air filter into the HVAC module opening.
•Close the HVAC module assembly access door.
•Install the rear inside IP compartment door.
•Close the IP compartment door.
I Hope this information is helpful.
Sep 03, 2011 | 2001 Pontiac Aztek
2004 dodge 1500 cabin air filter
the cabin air filter is located on the passenger side of the cowl. after opening the hood, remove the windshield wipers and the black covering ( 2 small T-30 screws, and a few body grommets). after you remove the cowl there will be a grey accordion looking filter in the cowl, remove that and replace with the new filter.
Apr 18, 2011 | 2004 Dodge Ram 1500
Replace cabin filter f150 lariat 2006
This is one of those topics that I have seen both ways.
1. The 2004 was the only MY to include an airfilter.
2. The late build 2004 to 2008 could have a dealer installed cabin air filter kit installed.
So don't be shocked if you go fishing for it, and it is not there. On to the directions :
Open the passenger-side glove compartment box. Remove all of the items currently stored in the glove box
Notice two screws on the inside ceiling of the glove box securing the glove box to the dashboard. Use a flat-head screwdriver to remove these screws. The glove box will now be loose. Wiggle the box off the dashboard and allow it to hang.
Locate the rectangular plastic housing; this is where the cabin air filter is stored. Remove the housing cover by pulling it out of place. Remove the dirty cabin air filter by sliding it out of the clips securing it in place. Discard the dirty filter.
Slide the replacement cabin air filter into the retainer clips. Push the filter housing cover back into place until you hear it lock. Place the glove compartment back into place. Replace the two screws that secure the glove box in place and tighten with the screwdriver. Place the items back into the glove box and close the box.
Apr 10, 2011 | 2006 Ford F-150
Where isthe cabin air filter located on the 2004 lincoln ls
Passenger side,open hood,remove most of the push pins, holding wiper cowl grill to cross brace.
Under the plastic cover is a box with another cover, and inside the cabin filter.
They are expensive and last about 3 years
Get real dirty after two
You will break a few push pins and the dealers don't stock and they are too expensive,like $3.20 ea
Use wire ties until I find a source at auto body supply houses
Aug 09, 2010 | 2004 Lincoln LS
Where is the cabin air filter located on a 2004 jeep liberty?
The cabin filter is right beneath the glove box on the passenger side of the car under the dashboard. open the glove box and remove a few screws and the filter wil be visible. Remove and replace.
Jul 26, 2010 | 2004 Jeep Liberty
Where is the cabin air filter located on a 2005 toyota sienna
The cabin air filter is located behind lower (larger) glove box.
Open the glove box, detach lever (right side). After unhooking both sides of the box (press towards inside) it will come out.
The filter element easily comes out (as drawer).
Slide in the new element, put back the glove box and attach the lever.
Hope this helps.
Mar 06, 2010 | 2008 Toyota Sienna
Pleaase advise how to install the Cabin Filter on a Hyundai 2003
Open glove compartment. Press inward at both sides of the glove compartment, then lower the glove compartment.Remove the lower side instrument panel and crash trim pad. Remove the four glove compartment upper cover retaining screws, then the cover. Remove the two glove compartment retaining bolts, then the glove compartment. Press on the cabin air filter cover tab, then remove the cove
Remove the cabin air filter from the blower unit opening. Install a new cabin filter, ensuring the air flow marking is facing in the proper direction. Install the cabin air filter cover, ensuring the cover is properly installed.
Position the glove compartment to the instrument panel, then install the two retaining bolts. Install the glove compartment upper cover. Install the lower side instrument panel crash pad. Lift the glove compartment into position. Close the glove compartment.
Oct 30, 2009 | Hyundai Motor 2003 Sonata
I have 2006 Acura TL V6. How do I change the cabin air filter?
To change cabin air filter on Acura TL firs time you need to open the glove box and then remove the arm that holds the glovebox. Press the 2 sides of the glovebox to take this out like in picture bellow.
acura-tl-2004-2010-cabin-air-filter-location.jpgAcura TL 2004-2010 cabin air filter location
After do this you can see and locate the cabin air filter housing cover.
acura-tl-2004-2010-cabin-air-filter-housing-cover.jpgAcura TL 2004-2010 cabin air filter housing cover
Push the 2 tabs from the filter frame to unhooking from the housing cover. Take the frame out and replace the old cabin air filter with the new one with the air flow indicating arrow pointing down.
acura-tl-2004-2010-reinstal-the-air-cabin-filter.jpgAcura TL 2004-2010 reinstal the air cabin filter
Nov 26, 2008 | 2006 Honda Accord
Vehicle Parts & Accessories Logo
71 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
