Question about Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital Music/video Player & Voice
Will not turn on
Plugged the player in for the 1st time & recv'd the message "to charge the player turn switch to the on position" it is in the on position. Can this be fixed? or do I need to return it?
I charge the MP3 player and it still shows "low battery" message.
There is a trick to charging the battery in these small mp3 players. It won't charge if it is turned on, and it won't charges if it's turned off. Here's what to do...
1. plug the player into your USB port. or wall charger
2. switch the player on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
That is if the battery is still chargeable after all this time. The battery may well require replacing.
Apr 19, 2010 | Creative Labs ZEN V Plus MP3 Player
I just bought a Jensen smpv-2gbub player. How do
How to charge the Jensen MP3 player - Model smpg-v2bub
Ignore instructions that came with it - they don't work.
Here's how to charge - I discovered this with mine:
1. When computer is on and at windows screen, attach cable from computer to mp3player with mp3 turned player off. It will immediately show you a connect screen on the mp3 player.
2. pressed the left side middle button twice - this will turn it on and go into music like you're playing a song.
3. Now turn the mp3 player on by switching the button on the right side of the device to the on position. It will suddenly show you it's charging - the battery on the front of the mp3 player will have a signal pulsing through it.
4. It will turn off after one minute. It's literally half charged now. Strange I know. Repeat from step 1 and it will fully charged.
If it doesn't fully charge after it turns itself off after 1 minute the 2nd time, then repeat steps from 1, one more time, but this time when it turns itself off after a minute, still leave it connected to the computer for 10 mins even though it looks like it's off. Then disconnect it physically from computer, turn it on with the on button on the right side, press the left side middle button twice and look at the battery on the screen - it should be fully charged now.
Apr 07, 2010 | Jensen Audio Players & Recorders
My Mambo- Mano MP4-MP3 does no charge
it does not seems to charge / or turn ON either from the computer or when plugged to an electrical outlet to the wall. Red light is still ON after the whole night . What's wrong ?? Can you please HELP - CODY STELLER MINE IS A 4 GIGA BITE MP4 PLEASE HELP ONLY
Sep 01, 2008 | Kaser Corporation Mambo Mano Digital Media...
Power source.
Well I am not a technical person, but i imagine it should be possible to use all such products while they are charging.
Aug 12, 2008 | Philips PET702 Portable DVD Player
Mp3 player won't turn on/won't charge
make sure the hold switch is in the unlocked position. otherwise the player will not charge or be recognized w/ the USB port plugged in.
Jul 10, 2008 | SanDisk Sansa e260 MP3 Player
Same Problem Again - Mega Raid.... Unknown Error
Hi
The title of your post suggests that you have "Maga RAID" errors. Maga RAID messages would be in line with issues on the LSI PERC sub-system.
However, the extract posted in your suggests network problems.
Any number of physical to driver and configuration issues can result in network problems.
Try the basic checks;
1. Change or try a known patch cable
2. Run "ping" test to a known good system connected to same network switch or direct connect with a "cross-over" cable and check for dropped connections.
3. Is the NIC and switch set to Auto-Negotiation or static at 10, 100 or 1000Mbps speed
4. Can you try another switch
5. Check and load correct or latest manufacture's drivers
Reply with more info.
Mike
Jan 23, 2008 | Dell PowerEdge 1800 Server
Player is not turning on
Sometimes I must hold the play button down for over 7 seconds on my unit to get it to turn on. See also the answer to the question on properly charging the unit; i.e, have the slide switch in the "off" position.
If you are using a USB hub to charge the mp3 player then the hub must be powered.
Jan 02, 2008 | Coby MP-C582 MP3 Player
Audiophase KZ111 MP3 players won't charge
One thing that I have found that works is that you slide the switch to the "ON" position, but don't press play to turn it on all the way. Do this BEFORE plugging it into your computer. I have had the mp3 player fro a year or two and I have charged it about 15-20 times.
Nov 01, 2007 | Audiophase MDP-1 Personal MiniDisc Player
My Mustex MP-100
my mp100 mustek player will not switch on or charge up also it will not switch on when the mains charger is plugged in. the light on the charger went out and will not come on anymore.
Aug 12, 2007 | Mustek MP100 Portable DVD Player
Polaroid Pmp120-4 4gb Usb 2.0 Mp3 Digital Music/video Player & Voice Logo
Top Polaroid Audio Players & Recorders Experts
Owen Barnes
Are you a Polaroid Audio Player and Recorder Expert? Answer questions, earn points and help others
