Question about JBL ES250P Subwoofer Speaker
Sub started to crackle and now is not working
I got this subwoofer around 3 years ago I think and absolutely loved the large, wide sound that they create. They could be enjoyed at low volumes for increased clarity and really be cranked up for parties. This is where my sub also started to take a beating, at parties. From angry parents unplugging the entire system live, to using it at 75% volume for hours on end. I usually never cranked the knob to full volume as I know that this leaves little room for the sub to breathe and its incredibly difficult to tell the slight difference in sound increase from 75% to 100% on this system anyways. I liked this speaker so much that I bought a second, but shortly after getting the second, the first one started to show signs of wear. It would crackle and make this popping like noise at any volume really, but got worse as the volume increased and as the crossover was set higher. 150Hz cut sounded way worse then the lowest 50Hz cut-off. However, it still sounded just as loud as it did after it finally broke in. It was just the added popping and crackling noise that could be heard clearly at extreme bass moments in songs when there wasn't much highs or mids playing at the time. I tried to combat this crackling and popping to the best of my abilities by tuning the crossover so the sub only played 25Hz to 50Hz and only put it at 50% power max. This helped for sometime as with my entire system playing you almost had to "hear for" the crackling if you didn't know it was already there. So of course, to replace my busted sub when it was still working, I got another JBL ES250p because for the price I'm not sure what compares and I've checked out tons of subs $300 or less. So I took a risk and got a third sub, I read that mixing and matching subs isn't ideal either. And wow... Once all three subs were hooked up and placed evenly across my back wall I could barely hear the crackle-pop and I could actually feel the bass in my chest all the way across my entire basement, wherever I stood, walls and corners being ridiculous bass-traps. Which I love as it gets people out of the corners and off the walls into the party because the bass is immensely overpowering leaning against the wall or standing in the opposite corner. With a 22 foot by 30 foot basement, just measured, the subs for the first time made me feel the music while being out "in the crowd" so to speak. It was a beautiful experience but short lived as I noticed one day the busted crackly speaker wasn't working. I think I switched the phase of the speaker when it was playing, but I wouldn't think that this could break it. It was a bad move on my part because it broke that day, but I think the problem may be a worn, faltering amp that just took a hell of a beating as understood by me from the very first crackles. I shouldn't have pushed it once the first problem arose but now there's another. The speaker isn't necessarily broken because it turns on, LED turns green, I hear the internal "Click" a few seconds after powering up before the speaker is actually active. All this happens but the speaker just doesn't play anything anymore. No white-noise, no fuzz, no music, or anything. I did open up the back to take a peek and saw no burn marks, anything broken, fallen, out of place, at least to my knowledge. None of circuits really, but there wasn't any glaring issue. However there are some more advanced tests that I can do owning three of these monsters, very heavy to. The things I haven't tried are - Switching out a working amp for the "broken one" - Same switch but with the woofer cone itself I don't if this would be a smart move to make since I could risk damaging more components doubling the problem. It would be nice to just replace the amp from Dayton Audio, where people say to get spare parts from. Instead of buying a whole new speaker, though I've done that before, and its a hell of a lot easier haha. Side note- the busted sub was placed directly behind my desk which is centered perfectly on the left/right and on the shorter end of the my basement not wide. The other subs are no less than 5 feet on either side of the middle sub, so last thing I need to check is the cables that connect directly to the woofer in the back as the extreme rattling from subs on all sides. Funny note, the broken sub actually felt like it was playing with the 2 other subs on either side of it because of how loud it gets back there. Like the sub actually had visible excursion and moved like it was playing haha. Although I turned the others off and silence. I'll check the connections on the speaker cable clips on the +.- behind the woofer tomorrow and update this. Also will update any other news and share any information found. Holding off on swapping out parts though. Thanks! sorry tried not to make a word wall, but its hard when I can only see two lines of what I type, will fix later.
    Scholar:
    New Friend:
  • 82 Answers
Sounds like you may have a blown (open) speaker. Remove the speaker and measure the DC resistance if you have a ohmmeter. Should read a little under the rated impedance (4 ohms). No ohmmeter handy? Touch a 9V battery across the speaker terminals, and you should hear a pop from the speaker. No pop then you have a bad speaker. Also the speaker should move freely when you push on it. Don't push the dust cover (the dome in the center) unless you like that dented look! If the speaker is indeed bad and you can't get an OEM (P/N: 363389-001) then an aftermarket speaker should (in most cases) work fine. Just make sure it is a 12", 4 ohms and rated at 250W RMS or greater. May actually be lower than 250W but better higher than lower. Good luck!
Posted on Apr 17, 2014
SOURCE: subwoofer makes loud popping crackle intermittently
im having the exact same problem thinking it was the amp i rigged up a different driver,the amp was fine.i knew the driver wasnt gone and after some looking and testing i got it down to wire mesh(i think a dust sheild,something)inside which was slightly rubbing on the coil,it worked fine loud when it was warm but cold there was bursts of bad feed back noises.
Posted on Mar 14, 2008
  • 92 Answers
SOURCE: I purchased a JBL PB12 (120v) subwoofer from a
It sounds like something on your main board of your amp is going out. It is most likely the finals, or as you said a capacitor. Test the port with another speaker, if al is well then the wooferis bad. if not you will have to go inside the amp for repair. Depending on the brand it can be a little complicated. Try and narror it down to the proper componet, post back the results and we will go from there. Also is this sound comming from all channels or just the woofer?
Posted on Sep 28, 2009
SOURCE: Subwoofer not powering enough (Sounds like under powered 8inch)
get a nice monster subwoofer cable and a Subwoofer PowerCenter™ SW 200 with Clean Power™ Stage 1 get it from like amazon and you'll definately see a difference and also put the sub in like a corner
Posted on Jan 23, 2010
  • 175 Answers
SOURCE: Powered Sub Woofer emitting lound crackling noise
i would say so sounds like woofer is dying unless u pull it apart and replace the woofer it doesnt have to be same brand just same size and watts and ohms then u can keep it
Posted on May 28, 2010
Testimonial: "Thanks for such a quick response. Good to get a second opinion. Much appreciated!"
  • 5 Answers
SOURCE: In turning up volume on
This model has very cheap pots. What really happens is the center pin on the pot breaks leaving the wiper that rides on the carbon track to lift, causing this problem. Use caution as this condition continues the pot will go bad enough to send max volume to the system causing severe damage to the speaker, and maybe the listener. THE GREAT OZ.
Posted on Aug 16, 2011
May 28, 2010 | JBL 5.1-Channel Home Theater Speaker...
Well I also have a S112PS AR Sub Woofer Problem...
Are you sure it is receiving an audio signal to make it wake up? You don't mention what's upstream in the audio chain.
To eliminate mis-settings or lack of sub-related signal upstream, plug an RCA cable from a CD player directly into it and start a CD that fades in slowly because you won't have any way to lower the volume except to pause the CD. If the sub works you'll hear a muffled version of the program.
Apr 09, 2010 | Acoustic Research S112PS Subwoofer
I have a wharfedale svp15 passive loudspeaker. The subwoofer has started crackling and popping at low volumes and has no deep bass. At high volumes it sounds great as usual and can't tell if the crackling...
Information I find online says it an Active Subwoofer, so that introduces its own amp as a possible source of the symptom. If there is another version of this model that's passive, all the more reason to believe the amp is the problem because passive speakers don't spontaneously emit sounds.
If there was a physical reason for the crackling I would think more power would make it worse or blow it up.
A poor sub signal cable connection might explain low current anomalies if random noises are entering the signal path.
Make sure the signal, speaker and power cables are not aligned parallel and close to each other.
Feb 26, 2010 | Audio Players & Recorders
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Boston BA790 Subwoofer Making Strange Noises
I just took my sub apart and found that the surround on the driver speaker inside the sub was totally crumbled and lying in pieces throughout the sub box.
I'm looking around now for specs on the sub speaker so I can find a replacement.
Feb 03, 2010 | Boston Acoustics BA790 Computer Speakers
Crackling coming from Velodyne DD-10 subwoofer
One of 2 things is going on.
First, the servo mounted in the driver may be going bad or is picking up some noise.
Second, Something in the amp section is going bad, hard to pinpoint the exact problem.
you say that it plays, so I tend to think it is the driver mounted servo unit.
If it is within the warranty time, take the unit back to the retailer you purchased it from, if not contact Velodyne for repair.
Mar 18, 2009 | Velodyne HGS-10 Subwoofer
Crackling
Yeah, I've had two of these go out on me in exactly that failure mode. The first time, C-V bounced me around to two repair shops (a three-month process) before telling me to send it to them in Florida. This time, I went directly back to C-V with it, and they've had it two months now, and every time I call for a status update, I'm told "We'll let you know," or "We're working on the paperwork." Their service and support staff are not helpful - friendly, but not helpful - and the failure rate I've experienced is absolutely unforgivable.
So, my best solution I can give you is send it back for a warranty adjustment, and then sell it. As soon as mine comes back this 2nd time, it's going on the market, and I'm going out to buy a Sony.
Aug 28, 2008 | Cerwin Vega VE-28S Subwoofer
Velodyne is known for good service, i think in this case it is best to contact your vendor and have it solved.
I think internally there somethign wrong with the electronics, most likely the amplifier.
Aug 08, 2008 | Velodyne DD-10 Subwoofer
Bose 123 Home Theater speakers started crackle sound?
If the wires are bare on some parts and touch eachother that will most likely be the cause.
Aug 08, 2008 | Audio Players & Recorders
Polk subwoofer making crackling noises
Yea, now its time to replace it! the magnetic effect is weaken which makes the very bass low frequency sound to be distorted! You should re engergise the magnet of the subwoofer or should buy the new!
Dec 08, 2007 | Infinity BU-120 Subwoofer
JBL ES250P Subwoofer Speaker Logo
320 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
