Question about Sansui Televison & Video
Fault finding retrace line on screen ?
Sansui tv 21''
    Top Expert:
  • Sansui Master
  • 75,289 Answers
Check the video output supply voltage. If it is less than normal, retrace lines will be visible. If the screen voltage is greater than normal, the retrace lines will be visible. You should check all these. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Check these above said voltages at the CRT base card.
Posted on Apr 14, 2014
Vertical line in my 32 inch Sansui flat screen in my REV motorhome. Left side of TV. Bluish in color
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 17, 2016 | Sansui Televison & Video
White, squiggly lines on TV screen
This fault is technically called 'retraced lines'. There are many reasons for this fault. It will be best to contact any service technician. If the screen voltage to CRT is abnormal [higher than normal]; this kind of fault can occur. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
One among the post have details about this fault "Retrace lines with picture".
Mar 03, 2015 | Televison & Video
Retarce line
Diagonal retrace lines at the top are usually the result of bad electrolytic capacitors in the vertical deflection circuit most vert. deflection circuits derive operating B+ from a horizontal flyback transformer winding rectified & filtered usually around 24 volts the electrolytic capacitor on this supply loses capacity or may totally go open causing the retrace lines,sometimes other electro. caps in the vert circuit can cause this too, depending on the age of the tv you may find multiple substandard electrolytic caps it's best to test all for capacity & esr. Without knowing more details about your tv brand,model and/or chassis i can't help further.
Apr 14, 2014 | Sansui Televison & Video
My tv sony kv-xa21m61 display too bright and many horizontal lines. no picture
Vertical retrace lines is the problem. Thin white lines runs across the entire screen, at about an inch apart to each other. Check its video output supply voltage. Reduce the screen voltage to a little bit down and check. If you still wish to know more about this fault, check this site. Pull up older posts there.
Feb 09, 2013 | Sony KV-XA21M61 21" TV
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
May 11, 2012 | SansuiS3275 TV
Sansui 27 standard Def.White Lines
This fault is calle technically as 'retrace lines'. It is with an adjustment fault. Visit this site to get more details and repair help to this fault. Detailed description are given there. "Electro-help" is the site name. Search for it either by Yahoo or google. It is an electronic entertainement equipments service help site.
May 09, 2012 | Sansui 27" TV
Cross lines ontop of screen my G21 M1 tv.. pls tell me how to solve it
The vertical output section of your TV has the fault. Replace all the electrolytic capacitors there, including smoothing capacitor to supply line to IC. Check for any loose solder termianls too. The lines you are seing across the screen, on it tope side, about 2 inches might be due to this fault, and are technically called [vertical retrace lines].
Apr 26, 2012 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Too much yellow does not adjust with normal drop screen adjustments. can i adjust the light beams.on my philips 50"
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 1. Turn the green screen control on the Focus Block until retrace lines appear and gradually turn it back
Until the point where you can see the retrace line disappears, just before cutoff.
2. Turn the red screen control on the Focus Block until retrace lines appear and gradually turn it back
3. Turn the blue screen control on the Focus Block until retrace lines appear and gradually turn it back
until the point where you can see the retrace line disappears, just before cutoff.
4. If the screen still appears too bright after proper G-2 adjustment, you need to adjust the sub-bright adjustment in the service menu
control down until screen cut-off. (Service data Range is usually 21 to 25 in the Service menu, for Sony sets you first go to category "MCP2", & then adjustment item 01( "SBRT")= subright.
For electrical the focus, put on the screen a clear picture of your choice thru an input of the TV set from a DVD, then pause the playback of the DVD Look into each color and rock that color focus control back and forth (turn the control one way then the other way slowing down as the picture goes into the best focus. till the picture looks sharp do each color till they all look in focus. NOTE: it is best to look into each color tube to achieve the best electrical focus. For optical focus please follow the manual lens adjustment in the sets service manual
By Larry Dillon
Aug 27, 2009 | Philips 50P8341 50" Rear Projection...
Televison & Video Logo
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
