Question about Vehicle Parts & Accessories
2010 Lincoln Limousine With Digital Rear Components That Shut Down During Idle.
Ive Replaced A Auxillary Batt . and Its Very Confusing while I'm trying To Run A Business With The Car.
    Problem Solver:
  • 7 Answers
I think there is a problem with your voltage regulator. the voltage being supplied falls below the required threshold when idling. You may have to go to a larger alternator with more out put. A new or larger alternator is the answer. Hope this helps
Posted on Apr 14, 2014
05 taurus code p1633 stalls at idle or when slowing down
The KAM circuit for the PCM and the a/c is on the same circuit.
If the PCM does not have memory voltage it will loose the settings every time you turn the key off.
You might want to check the fuses in the engine compartment for a blown fuse for this circuit.
Of course it could have another problem too, such as a faulty idle air control valve.
Jun 29, 2012 | Ford Taurus Cars & Trucks
When my lincoln town car 1993 dies when i stop do i have a serious problem?
No read the fix below.
Engine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Jun 08, 2012 | 1993 Lincoln Town Car
Water pump failed. Car overheated. Engine lost power. Car smoke out from back of engine and from rear of car. I replaced water pump. Car still smokes when I drive it. Still has no power.
Notorious for intake leaks, the composite plastic intakes crack and leak coolant-as to the lack of power, you mght have overheated it and done some damage to the engine. There was a recall (information below) for the 4.6 for the intake-the overheating and lack of power means you should at least have compression checked and go from there-you may have bad head gaskets or worse. Do a compression test before you do anything else.
Ford Motor Company will extend the recall (01M02) on 4.6L V8 equipped vehicles with plastic intake manifolds. Some of the composite intake manifolds used on 4.6L SOHC engines may develop fatigue cracks at the coolant crossover duct. This condition could result in engine coolant leakage which, if not serviced, may cause engine overheating. Complete loss of coolant may result in engine damage or engine failure.
The updated recall now includes:
• Certain 1996 through 2001 Model Year Crown Victoria Police Interceptor
• Certain 1998 through 2001 Model Year Crown Victoria with Taxi
• Certain 1998 through 2001 Lincoln Town Car Limousine and Livery Prep Package
• Certain 1996-2001 Crown Victoria Taxis, Police cars and Lincoln Town Car Limousine and Livery cars.
• Certain 1996 through 1997 Crown Victoria Police Interceptor Vehicles with 4.6L SOHC engines built at the St. Thomas Assembly Plant from the beginning of production for the 1996 Model Year through January 28, 1997.
• Certain 1998 through 2001 Crown Victoria Police Interceptor Vehicles with 4.6L SOHC engines built at the St. Thomas Assembly Plant from November 22, 1997 through December 15, 2000.
• Certain 1998 through 2001 Crown Victoria Taxi Vehicles with 4.6L SOHC engines built at the St. Thomas Assembly Plant from November 22, 1997 through December 15, 2000.
• Certain 1998 through 2001 Lincoln Town Car Limousine Prep Package and Livery Vehicles with 4.6L SOHC engines built at the Wixom Assembly Plant from November 22, 1997 through December 15, 2000.
Sep 23, 2011 | 2001 Ford Crown Victoria
Won't start..new batt. Starts to turn over then just kinda rumbles. Fuel pump shutoff switch is stuck in the down position.
Shut off switch should be down if it was up there would be no fuel to engine,Sounds like the starter needs to be checked, Or the wires to it need checked,clean and tight.
Dec 11, 2010 | 1998 Lincoln Town Car
"what is the name on the lights on the outside panel of the 1996 lincoln town car limousine"
limousine lamps. If you are saying on the B post behind driver door.
May 27, 2009 | 1996 Lincoln Town Car
Alternator not charging batt.
inspect cables, they break down over time, corrode and turn green inside
Nov 25, 2008 | 1988 Lincoln Continental
IHAVE A 2000 TOWNCAR
YES ,I DID , SOME ONE ELSE THERE HAVE THE SAME PROBLEM ,SO I READ HIS POSIBLE SOLUTION ,AND WORK FOR ME TOO., THANK YOU GUYS.......................
Nov 16, 2008 | 2005 Lincoln Town Car
Vehicle Parts & Accessories Logo
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
