Question about Belkin (F5D7231UK4) Wireless Router
Wireless g router stops connect after 2 years good sevice local connections only system vista and xp
    Sergeant:
    Champion:
  • 310 Answers
I would suggest to try and upgrade the firmware ( if you havent done that already ). If there is any change in the sequence of the lights on the router, then there isnt anything much you can do about it..One last try would be to reset the router once.
Thanks
Ranjit
Posted on Jun 18, 2009
I have a dlink dir-615. I have a windows xp desktop which is hardwired to the router. I have 2 windows vista computer on wireless and one apple macbook pro. the apple computer and the desktop works fine....
Use the DHCP function in the router administrator web page There you can assign and reserve the IP,s on each Vista PC,s.
If you need more help come back.Post / thumbs / testimonial are welcome!
Dec 10, 2010 | D-Link DIR-615 Wireless Router
D-Link DSL-2640-T. After power outage, I have a good wireless connection BUT no internet access. LAN line does not work either. Please suggest possible solutions.
chack your DSL settings may your not conacted with your sevice provider
chack your locale settings in modem try folowing setups
1. If you have a modem, connect the modem to the router(make sure modem should be connected to the port on which LAN, Internet, WAN is mentioned. It would be a separate one port on the router) and router to the computer.
2. Insert the disk that came with the router, inside the computer.
3. Follow the on screen instructions.
4.No, connect to the wireless
Apr 22, 2010 | D-Link ADSL2/2+ Modem/Wireless Router...
Can not change the wireless channel
A very good question!
I'd love to answer this. Belkin utility at times has some bugs. As you said you have downloaded the latest version of drivers and utility. Latest drivers are good but utility will not be of much use, I, as a technician would highly recommend that you use Wireless Zero Configuration in case of Win XP or WLAN Auto-config in case in case of Win Vista or Win 7. But if you have older versions of Windows, older than Win XP, only then utility has to be used. Enable WZC and WLAN A-C in Microsoft Services(Local) page.
Start > Run > services.msc > Ok > Services (Local) > Start the service.
At worst instances, if you are forced to use the utility, remove all SSID (wireless network names) from My Connections. Note: Remove all of them completely.
Also, i would recommend that you configure your wireless mode to be "802.11g only" on the router as F5D7001 is a 802.11g standard PCI card, and also turn ON the wireless PROTECTED MODE on the router. This will enhance the performance of your wireless devices in cases of heavy wireless traffic.
This is sure to work! Again, thanks for such a question.
Feb 02, 2010 | Belkin (F5D7001) 802.11g/b Wireless...
I have a D-Link AirPlus DI-524 Wireless Router. I have no problem connecting the computers in my home that have windows XP installed. We have replaced two of the computers in the house with laptops that...
I have had exactly this problem and after MUCH work downloading new drivers for the Vista Pcs and updating the operating system in the DI-524 found that the 524 does not operate well with Vista. A new DI-624 integrated well with Vista, and installed with no problems. Good luck!
Feb 22, 2009 | D-Link AirPlus DI-524 Wireless Router
D-LINK Wireless G Router WBR-1310
Try changing the channel on your wireless setting or try downgrading your operating system to windows XP.
Jan 02, 2009 | D-Link 802.11g Wireless Router WBR-1310...
Setting up a lan and internet thru MTNL triband
I suggests you to go for Linksys. It's a good product when it comes to wireless internet. Linksys router must be plugged in to the modem. On the back of the router, you can plug the vista on port number 1 then your win XP machine can go wireless at the same time.
Sep 16, 2008 | NetGear DG834G Router
Lost Wireless Connection DLink G604t
So if your other 2 laptops (WinVista) is working then that means that the wireless on your Dlink is working fine. Its possible that its a problem with the settings on the winxp laptop. does your winxp laptop have a builtin wireless adpater? What does it say on your winxp laptop is you will try to view the available wireless network?
Jul 29, 2008 | D-Link DSL-G604T Wireless Router
Netgear wireless router DG834PN wireless access local only I can get internet on my desktop which is connected to the router via ethernet but I can connect to the router wirelessly on my laptop but only...
With Vista on the Laptop it should be just a matter of double clicking the router in the network settings, vista should automatically configure the connection.
This has happened to me before and this is what I did just to see if it worked, and it did flawlessly.
Mar 01, 2008 | NetGear DG834 Router
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Belkin (F5D7231UK4) Wireless Router Logo
59 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
