Question about Vehicle Parts & Accessories
I Have A 2010 Lincoln Krystal Limousine 120 In. Where After !0 Min @ Idle the Rear Int. Shuts Down. And I Have Already Replaced a Auxillary Battery
    Problem Solver:
  • 35 Answers
Relay failing.
Posted on Apr 19, 2014
2010 Lincoln Limousine With Digital Rear Components That Shut Down During Idle.
I think there is a problem with your voltage regulator. the voltage being supplied falls below the required threshold when idling. You may have to go to a larger alternator with more out put. A new or larger alternator is the answer. Hope this helps
Apr 14, 2014 | Vehicle Parts & Accessories
HP DV7-3085DX Shut down at 120 degrees C
No solution, but that is really hot. Hot enough to start frying other components. Eventually it will.
Nov 28, 2012 | Computers & Internet
1994 f150 6 cyl engine shuts down every 10 min restart after 5 min
Sounds like the module inside the distributor. Have to be replaced.
Sep 29, 2012 | Cars & Trucks
1996 Lincoln Town Car. A/c will not blow out cool air. All things under the hood seems to be working correctly(sweaty/cold line, a/c compressor comes on, system has been recharged with no sign of leak,...
Control dampner switch okay from looking at the fron of the car on the passenger side youll see a group of vacuum hose plastic connecting to a junction make sure none of the are broken Two of the control the vent control and inside tempurature. Once it disconnect you no longer have mixture control. Do you remember when it was working fine and you turn off the car and you heard that little hissing noise? Well that line is now disconnected
Apr 23, 2011 | 1996 Lincoln Town Car
The car runs then when you get to stop light it shuts down then you can start it just when the rpm is low it shuts off
The most common problem with stalling due to low rpms is the idle air control valve. this valve is what controls the idle and keeps the engine at the correct idle this is the first thing i would check and also make sure the throtlebody is clean, most of these type of problems are due to that valve good luck.
Jan 23, 2011 | 1999 Lincoln Continental
94 chrysler con.3.3 eng.runs for about 15 min. shuts down,engine
suggest change crank sensor-rear of engine pas side
Oct 05, 2009 | 1994 Chrysler LHS
"what is the name on the lights on the outside panel of the 1996 lincoln town car limousine"
limousine lamps. If you are saying on the B post behind driver door.
May 27, 2009 | 1996 Lincoln Town Car
My 1987 Lincoln Town Car runs fine for about 30 min and shuts off
replace fuel filter and (clean or replace) air filter. then pressure test fuel system.
May 14, 2009 | 1987 Lincoln Town Car
Iriver pmp 120 use the wrong charger
try this. the iriver doesn't boot at times ( wrong charger or using the right charger abroad), unlatch the battery and hold down the power button for about 20 seconds. also reset the instrument. hopefully that might work for you.
Dec 30, 2007 | iRiver PMP-120 Digital Media Player
Vehicle Parts & Accessories Logo
32 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
