Question about Baby Lock Ellure
Wheel that makes needle move is stuck
It wont turn
  • Baby Lock Master
  • 1,388 Answers
Check thread caught in take up arm crank
Posted on Apr 22, 2014
Hand piece is very tight to turn and unable to use the machine
Make sure to clean/remove all the lint, thread, dust, etc. that may have built up in the bobbin area, around the feed dogs, and under the needle plate. Sometimes gunk build-up will prevent the hand wheel from turning. Remove the bobbin & bobbin case from the machine and the needle and see if the hand wheel will turn. If not, then it may be time for service.
My hand wheel is hard to move and will not make complete turn unless...
https://answers.yahoo.com/question/index?qid=20100518074139AAeeykz
Help My Needle Hand Wheel are Stuck Sewing Machine Jammed
Apr 20, 2016 | Sewing Machines
Needle bar stuck singer 1120 wont move with pedal or manually turning the dial
Very likely there is a thread or two stuck in the bobbin area. Open up the bobbin door, remove bobbin and bobbin case. Now try to turn it with the handwheel. If still no action, then look closely at the socket where the bobbin case fit into. There are 2 black plastic levers -one on each side. Move each one outward. This will allow the center to easily fall out.
Now move the hand wheel. If it is still stuck, then remove the needle plate. Remove two screws to allow the plate to come off. Now you have a clear view of all the mechanism around the needle and bobbin area. Remove stray dusty bunnies, thread etc.
If that does not do it, then you may have an issue with the belt or motor -but not too likely.
Reply if you are still having problems.
Moses
Mar 02, 2015 | Singer 1120 Mechanical Sewing Machine
Hand wheel wont turn to raise needle.
If handwheel does not turn, you may have thread jammed in the hook. First try to force the handwheel BACKWARDS to try to force thread back out of hook. If handwheel turns, look around hook area and you will probably see a small piece of thread. Remove it with tweezers. To help eliminate this from happening, be sure to hold the needle thread when starting off.
Jan 18, 2015 | Brother Computerized Sewing/Quilting...
The needle is stuck,not moving.its very hard and the motor makes a sound but needle does not move.
Refer to your manual and make sure the bobbin winding feature is disengaged.
Turn off the power and remove the needle and if there is fabric, remove it also.
Open the needle plate look for thread tangles.
After cleaning, turn the hand-wheel by hand to see if it moves the needle up and down.
If it does, press on the foot pedal to see if it is working.
Any of the above could be the problem.
Mar 01, 2010 | Kenmore Sewing Machines
The machine froze as I was using it. The wheel cannot be turned and the needle will not move. It is like the motor froze on it. Can it be reset?
You might try other solutions; however, this works for me:
The needle is bent or stuck.
1. Loosen the needle thumb screw
2. If the needle is stuck then that was the problem, the turn wheel should work ok.
3. The bobbin may be damaged as well.
If this doesn't work, then I'm afraid you will have to "force" the wheel. It is not the motor.
Does the motor make a noise like it is trying to work?
Hope this helps!
Sep 03, 2009 | Sewing Machines
Needle doesn't move
the problem is some fabric, dust or thread is stuck behide the plate that holds the sewing needle and foot.
Mar 10, 2009 | Kenmore 15208 Mechanical Sewing Machine
Needle jam
stuck the whole machine the needle did not move .needle and wheel handle both are stuck
Feb 27, 2008 | Brother CS-6000
Wheel won't turn
The same thing happend to me with an older model (Singer XL 10). I have been sewing a decorating stitch and the machine stopped suddenly. Now I am not able to turn the hand wheel anymore like I should (I can move it a little bit, but the needle does not move up and down and the wheel is getting stuck). When I try to use the pedal the motor makes a horrible noise and stops. The needle is not moving up and down.
Is there a solution for that problem? I moved from Europe to Australia and have not used my machine since. Today is the first day, I was cleaning and oiling it and it first sewed perfectly. In case that there would be thread stuck somewhere, how could I possibly clean that? I already took off the plastic from the head, but I can not see where the problem is.
Any help is appreciated. Thank you!
Best regards,
Nelly
Jan 12, 2008 | Singer Quantum XL-1000 Computerized Sewing...
Sewing Machines Logo
69 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
SewTechWayne
SewTechWayne
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
