Question about Aspyr Kelly Slater's Pro Surfer for Mac
Encrypted password where wo found
Set usb password protection
1. Check the "Password protect my data" option and enter a password as well as the password confirmation and a password reminder, then click the "Apply" button.2. You can use "manage secret-zip data" only after selecting encryption item "My Folders & My Docs", the upper right window is the list of encrypted data, the lower window is the list of decrypted data. Please click "Refresh View" to update data list if you save or delete any files.3. Please select the data in decrypted area, and encrypt it by clicking "Secret-Zip Selected". You can also encrypt all data in Docs and Folders by clicking "Secret-Zip All".4. Please select the data in the encrypted area, and decrypt it by clicking "UnSecret-Zip Selected" or "UnSecret-Zip & Open".5. If you don't want to use the secret-zip function, select "No password protection required" in "Encryption Settings", and enter your password.6. If you want to change the password, select "Change password" and enter old and new passwords.
Jul 30, 2013 | Transcend Electronics - Others
I forget my apple act email and password
Click this link to recover your apple ID and fill in your details
https://iforgot.apple.com/cgi-bin/WebObjects/DSiForgot.woa/369/wo/cSTSnPyzNODJgfYCblcH5M/2.5.4.5.1.0.3
Now to get your password, click this link and enter your apple ID https://iforgot.apple.com/cgi-bin/WebObjects/DSiForgot.woa/369/wo/cSTSnPyzNODJgfYCblcH5M/5.5.4.3.1.5
Hope this helps.
Oct 02, 2011 | Apple iPad (16 GB) WiFi Tablet PC
The computer will not be able to pick up the D-link network I have set up if I switch the modem and router off. Even when I leave it running it will sometimes not get picked up.
try changing the encryption type. This sounds like the computer your using does not support the encryption type being used by the router.
1. Go to the setup screen of your router. For a D-Link router, you typically fireup your browser, go to http://192.168.1.1, and type in your username and password, my default username and password is admin, admin.
2. Click on the Wireless link. It will open Wireless settings.
3. There are options to let you set your Encryption Preferences. You can provide an encryption key that will be used by the router and any PC that wants to use the network.
4. select none. (if your wifi now works then you have found your problem and you can try the alternate encryption type, either WPA or WEP)
Mar 01, 2011 | D-Link AirPlus Xtreme G DI-624 Wireless...
Encrypting TI-84 programs I've seen this with other programs, but even as an experienced programmer i can't quite encrypt programs. By that I mean: if i see a list of my programs under the 'execute' menu...
The program is protected with a password, or it is archived. Unarchive the program. Under [2nd][CATalog] Press [2nd][ALPHA] U to jump to the first command in catalog that starts with U. Scroll down to Unarchive [ENTER]. Command is echoed on main screen, Feed it the name of the program and close parebthesis then press [ENTER]
Unarchive( program_name ) [ENTER].
I found out that reistalling the OS got rid of passwords on programs.
Hope it helps.
Sep 23, 2009 | Texas Instruments TI-84 Plus Calculator
Reposting my sign in.
This will help, rate me fixya. thanks. Passwords
  • Remember passwords for sites: Firefox can securely save passwords you enter in web forms to make it easier to log on to websites. Clear this checkbox to prevent Firefox from remembering your passwords.
    • Even with this optionpreference checked, however, you'll still be asked whether to save passwords for a site when you first visit it. If you select Never for This Site, that site will be added to an exceptions list. To access that list or to remove sites from it, click the Exceptions... button.
  • Use a master password: Firefox can protect sensitive information such as saved passwords and certificates by encrypting them using a master password. If you create a master password, each time you start Firefox, it will ask you to enter the password the first time it needs to access a certificate or stored password. You can set, change, or remove the master password by checking or unchecking this optionpreference or by clicking the Change Master Password... button. If a master password is already set, you will need to enter it in order to change or remove the master password.
2.0:
  • Show Passwords...: You can manage saved passwords and delete individual passwords by clicking the Show Passwords... button.
2.0 3:
  • Saved Passwords...: You can manage saved passwords and delete individual passwords by clicking the Saved Passwords... button.
Warning Messages Click the Settings… button to configure the security warnings Firefox displays while you browse the web.
Security Warnings Dialog
  • I am about to view an encrypted page: When this optionpreference is enabled, Firefox will notify you every time you are about to view an encrypted page.
  • I am about to view a page that uses low-grade encryption: With this optionpreference enabled, Firefox will warn you when you visit a page which uses low-grade encryption.
  • I leave an encrypted page for one that isn't encrypted: With this optionpreference enabled, Firefox will warn you every time you move from an encrypted page to an unencrypted page either by selecting a link on the page, selecting a bookmark or typing a new address into the location bar.
  • I submit information that's not encrypted: When this optionpreference is enabled, Firefox will warn you when you submit data via a form that's not encrypted.
  • I'm about to view an encrypted page that contains some unencrypted information: With this optionpreference enabled, Firefox will warn you when the page you're viewing contains a mixture of encrypted and unencrypted content. If an encrypted page contains unencrypted data, you should verify the identity of the page you're viewing prior to entering sensitive data.
Mar 26, 2009 | Mozilla Firefox
Encrypted password re-set
i have helped someone with this before and i found a website that you can crack your own codes (www.pcdoctor-utilities.com) i hope it works if not here is another (www.passwordchanger.com)
ihope it works and please rate me i would appreciate it.
Mar 18, 2009 | Acer Aspire 6920 Notebook PC
Seagate Free Agent 1.5TB doesn't encrypt
I was fumbling around with this as well. I found a manual on my external drive itself. I had to read through it carefully before i saw a small note.
Note: After you open your Encryption folder on the first computer and user account with which
you use Seagate Manager, it will be saved on that computer so that will never need to
enter it again. When opening your Encryption folder from another computer or user
account, however, you will need to enter your password.
I have yet to test it by creating another user account, then attempting to access the files. I am confident that this is the answer.
Mar 01, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Have lost the key to my belkin FSD7633-4
Okay, follow these instructions for locating your wireless encryption key. If for some reason the instructions do not solve your problem, call Belkin Technical Support for assistance in resetting the Wireless Encryption Key.
You will need to gain access to your router's control panel. To do this wego to Start>Programs>Accessories>Command Prompt. From heretype in:ipconfig
Press ENTER to execute the command. A listshould be returned listing some IP Address. Look for the oneassociated with,"Default Gateway."
Here is a picture.
Afterward open your Internet Browser(Internet Explorer, Firefox, etc...) and type the IP Address associatedwith the default gateway into the address field of the browser. DO NOTadd www. or .com. Afterward press ENTER or click GO as if you wanted tovisit a website.
Here is a picture.
Once you're atthe control panel you will probably be asked to log in. If you donot know your login details you can always try the default. Tofind these you can either search your router's user manual or head tothe online search engines entering your router's manufacturer's name,the router's model #, and the words, "default password" into the samesearch request to bring up the default login credentials. For example:
Linksys WRT54G default password
Here is a picture.
If you still can't manage to log in to your router's control panel you will have to contact the technical support department of your router's manufacturer (In this case Belkin) asking them for assistance in resetting the login user ID and password of the router.
Onceyou manage to log in to your router's control panel. Look for anythinghinting Wireless security or Wireless settings. Once found, look for theregion which controls settings on wireless encryption. Once found look around in the region for Wireless Encryption settings. Once you find them you should also locate your Wireless Encryption Key or a passphrase which can be used in place of the Wireless Encryption Key. Make sure to writedown the pass-phrase and/or the password for future reference.
Just make sure to try out the passphrase/password before exiting the control panel. Otherwise you'll have to follow these directions all back over again.
Let me know how it turns out and if I can help you out any further.
Feb 19, 2009 | Belkin (F5D7230-4) Router (587009)
IPod connection to Zoom ADSL X65590 router
you have to log in http://10.0.0.2 at the button/under of your router tells you the generic name and password you need to enter, just follow the instructions, you'll be able to change your settings
Dec 26, 2008 | Zoom X6 (5590) DSL Modem (55900003)
Aspyr Kelly Slater's Pro Surfer for Mac Logo
Top Aspyr Video Game Consoles & Games Experts
James Wishart
Are you an Aspyr Video Game Console and Game Expert? Answer questions, earn points and help others
