Install posiflex pp6800 on lan - Office Equipment & Supplies
Ntldr missing in my posiflex
Hi alejandra_61,
With your problem, the Operating System wasn't installed completely.
It might have been a problem occured during installation process.
Re-installation of Operating System will fix this problem.
Hope this info helps you a lot.
Thank you so much for using FixYa!
Oct 30, 2011 | Posiflex KS 6315 POS Workstation - P/N...
When i try to install win xp does not find the lan port even if allready have the lan driver. What do i do ?
make sure you have the right driver, posiflex uses 2 different nic chip depending on which motherboard your system uses.
Jun 15, 2010 | Posiflex Jiva 5800 POS Workstation - P/N...
Windows vista and pos (posiflex) compatability
Go back to where you got it and tell then either to provide the driver or take it back. Your windows already told you that it has NOT the driver for that device.
Jan 22, 2009 | Posiflex AURA 7000 Thermal Printer
Add Memory to a Posiflex 5815
remove the frame from the display
remove touchscreen
slide the small cover in center
install memory
Dec 25, 2008 | Posiflex Jiva 5815 PC Desktop
Posiflex 7000 p
driver for pp-700011 for windows xp
Jun 30, 2008 | Posiflex AURA 7000 Matrix Printer
Posiflex CD2860 works for short time
Did a bit more research and it appears that you must have a keyboard attached to the CD2860, even if it is not used.
Mar 14, 2008 | Posiflex Computers & Internet
Need a driver board for a Posiflex terminal.
go to this link http://www.posiflexusa.com/driver.php
Sep 24, 2006 | Posiflex Jiva 5815 Network Terminal
18 people viewed this question
jasbo
jasbo
