Question about Sony Televison & Video
Standby light is blinking 6 times
We replaced the lamp in our sony grand wega kdf60wf655 and now it will not come on and is blinking the standby light 6 times
There is a board G1 and from that board there is low B which is 6v if missing then it will blink 6 times please check that voltage
Posted on Apr 15, 2014
ctf1800
  • 4402 Answers
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have failed. There are, for example, a few hundred parts and a section of the Jungle IC chip involved. So, repairs could require something as simple as replacing some inexpensive passive components OR as complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
  • 51 Answers
SOURCE: Sony Grand WEGA KDF-55E2000
in this set 3 blinks means lamp cover not set properly but i think that your problem is your 6x red blinks that means you have a problem in the audio section in your set(missing a voltage) or a themal fuse open.
Posted on Jul 10, 2008
mistersony
  • 320 Answers
SOURCE: Sony Grand Wega 60" indicator lamp blinks 5X green then 6 red
It is unusually to see BOTH of these flash codes together. I have never seen them at the same time. A 5 flash is a lamp driver error, which is possibly related to your lamp failure. You may have to replace the lamp driver or "ballast" to correct this problem. The 6 flash is a power supply problem and more serious, as it will likely take a technician to narrow down exactly where the fault lies. It may be a thermal fuse open OR a failure in the power supply itself. What was the original symptom that caused you to replace the lamp? Did you use an original Sony lamp as a replacement?
Posted on Nov 27, 2008
ginko
  • 19396 Answers
SOURCE: Sony Wega stanby light blinks 5 or 6 times
When a Sony TV flashes five times, that means that there is an AKB circuit fault.
Six blinks is also a fault related to video problems, and regards a fault concerning the digital board and the Jungle IC (the main CPU).
This means that there is something wrong with the video.
Try first unplugging power for few hours, if that does not work, call a technician, as several IC and components must be tested and eventually replaced.
Posted on Dec 01, 2008
  • 8457 Answers
SOURCE: how to change the bulb on a sony KDF60wf655 grand
Go website like You tube type in ur tv model and bulb replacement,will have a tutor video how to do the replacement of the projection bulb.
Posted on Jun 21, 2010
Sony Grand WEGA KF-60XBR800 Service Manual
Lamp/Bulb A1601-753A (XL-2000U) .
http://www.shopjimmy.com/dlplamps?tv_brands_select=Sony&tv_models=Sony+KF-60XBR800
Apr 29, 2014 | Sony Grand WEGA KF60XBR800 60" Rear...
Sony grand wega
It may be a power supply fault
May 19, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Hi there, my sony grand wega kdf60wf655 had stopped working and was flashing 5 red lights. I tested the voltage from the power board to the lamp ballast board and got a 272v dc. Just replaced the lamp...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Sep 05, 2017 | Sony Grand WEGA KDF-55XS955 55" Rear...
I have a sony model kdf60wf655. i replaced my lamp nearly a year ago, but now i have black screen, no sound, and the lamp light is constantly flashing red. please advise how to fix.
Lamp light constantly blinking shows that lamp is dead/ broken. If any thing else like ballast supply etc become defective, standby light will start flashing in specific order.
Replace lamp and make sure to get Son original replacement lamp to solve the issue.
Thanks.
Oct 28, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony grand wega kdf 60wf655 will not start up. red light blinks three times. lamp replaced a year ago.
If the POWER/STANDBY indicator flashes three times, the lamp cover may not be attached securely. Review the lamp-changing instructions in your owner's manual, and make sure that the lamp cover is securely attached.
Jul 20, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Sony grand wega model kdf60wf655 cycles on and off.
My kdf55wf655 did this for about a week until I put in a new Lamp. Working fine since then. Got it through Amazon from www.vanns.com.
Dec 15, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Buzzing/screaching noise when turned on, standby light blinks and then lamp light blinks
It sounds like a bad lamp. Replae the lamp firts, but there is a chance you have a bad lamp driver also.
Oct 21, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
SONY GRAND WEGA KDF55WF655
tv turned off black screen and red light flashes 6 times over and over again
Feb 28, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
116 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
