Question about Samsung CLP 300 Laser Printer
The ink light stays on
We refell the ink toner and put it in its place the ink light stays on what should we do to put it off??
  • 37 Answers
You need to either reset or replace the chip on the toner cartridge. I would not recommend refilling toners carts, in particular if the machine is still under warranty.
Posted on Jun 18, 2009
SHARP M455N PRINTING LIGHT
The ink toner is is now infected by foriegn matters by effecting the printer laser head.Tries air compressor machine blow out the ink toner print head ink injector and laser printer print head.Wait about and hour reinstall the the ink toner to the printer,the toner should work find again.Not the ink toner is not saveable,must have be replace for normal operation again.
Mar 18, 2014 | Sharp AR-M455N Copier
Related t my Lexmark E232, I'm using a compatible toner but it put excess of ink in the papers. Then I bough a new original Lexmark toner, and when I put in the printer on two lights, from top the second...
Inspect the overall paper path for signs of spilled toner.Gently clean the contaminated areas with a soft cloth or compressed air.
If you need further assistance please contact Lexmark Technical Support Center.
Jan 24, 2011 | Lexmark E232 Laser Printer
Kyocera eroor code c-6 400
This could be a fuser housing error, usually associated with dirty AC power. This could be due to a faulty PWB.
You could try running this self reset though:
  • Switch off
  • Open Toner Cover
  • Switch on, holding System Menu
  • Go to Secure Setting
  • Enter
  • Hold Start # Enter
  • Scroll down to Maintenance Mode
  • Enter
  • Scroll down to U163
  • Scroll down to Execute
  • Enter
  • Close Toner Cover
  • Leave run for a few seconds
  • Switch off
  • Switch on
Hope this helps,
Regards
Mike
Oct 12, 2010 | Kyocera KM-1505 Copier
Printer will not work after paper jam fixed
  1. Turn off the printer.
  2. Remove any paper trays. Inspect them for wrinkled or damaged paper.
  3. Also open the back cover of the printer if this model has one.
  4. Open any other doors that give access to the printer's paper path and to the toner or ink cartridge.
  5. If necessary, remove the toner or ink cartridge. Place it away from light/ sun light to avoid damaging it.
  6. If you find a piece of jammed paper, remove it by holding it with both hands and pulling firmly. The goal is to keep the paper from tearing. If several pieces are jammed together, try pulling out the middle piece first to loosen the jam.
  7. If the paper does tear, try rotating the roller gears manually to free the paper. Don't force anything, though. Do this step especially if the jam message comes up repeatedly without any obvious paper jam, there may be a small tear of paper inside.
  8. Ones the printer is free of paper Replace the toner or ink cartridge and paper trays, close any doors you opened and turn the printer back on.
  9. If the printer paper jam message still appears, then there is still some paper in the printer. Reinspect the paper path.
  10. see alternative if the problem is still not solved.
alternative :
Load a piece of thick paper, for example photo paper and press the resume button (may be diffrent button on diffrent models) a few times to the printer picks up the paper and puts it through the machine.
Jul 09, 2009 | Canon iP4500 Photo Printer
Red light on suggesting replacement of parts
get geniune toners and replace waste toner bin.
Jul 05, 2009 | Samsung CLP 300 Laser Printer
I have samsung scx4300 and It error like toner exhesusted i wnt to refill it pls help
the 4300 printer contains chiplevel refeling inside of it . it contains a chip fed for only one refil. by repalcing another chip the printer will work.
Mar 21, 2009 | Samsung SCX-4300 Monochrome Laser...
I refilled ink cartridge but printer will still not work on screen message says low ink lexmark 2600
it will not appear int he screen because it is just a refell try to use it and if it print good then it ok
Nov 27, 2008 | Office Equipment & Supplies
Hl 2040
You must have refilled the first (starter) cartridge or didn't reset the toner reset lever. There is a reset lever on the left side edge of the cartridge. Look at the left end of the cartidge (not the fill cap end) for a round white gear end and a white lever in a hal moon shaped slot. If you can see only the round white gear and the hlf moon is emty of a white lever, it's a non-restting starter. If you have two white spots we will be addressing the one in the half moon slot. The used cartidge will have the lever at the "3 O'clock" position. To reset the cartridge as new you must remove the two screws on that end cap and move the lever to the "11 O'clock" position. Put the scews back in and reinstall in the printer. The sweeper lever will turn in the machine and reset the toner count.
***Important For Brothers**
Make sure when refilling that ALL WASTE TONER is completely cleaned out of the cartridge before adding new toner to it. Brother re-uses its old waste toner and over time the toner hopper gets contaminated with paper dust and too much old toner inside causing them to fail. It you just add toner to the cartridge without thoughly cleaning out, you will soon have a bad cartridge again. You'll see it when dumping out the old as white specks in the toner. That's actually contamination from paper dust and talc from the paper.
Hope that helps you.
Jul 27, 2008 | Brother HL-2040 Laser Printer
Lexmark C500 Error light showing,with New ink cartrige inserted showing toner low replace cartrige on machines display? Help!! thanks
Remove the cartridge, take a flashlight and check the right side inside the printer for a RED LED (in the place where the cartidge stays). Take a tape and patch that LED. That's all ! Enjoy
Jul 02, 2008 | Lexmark Office Equipment & Supplies
New toners and drums, but flashing amber error light - won't print now
Have you replaced the printer drums? The status monitor will tell you what percent they are at (similar to the toner cartridge status). This fixed my problem before.
Jun 07, 2008 | OKI C3400n Laser Printer
Samsung CLP 300 Laser Printer Logo
108 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Victorman
Victorman
jasbo
jasbo
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
