Question about Radio Shack Pro-2096 Base Scanner
No display no backlight - Radio Shack Pro-2096 Base Scanner
Display and backlight using my battery up how do I fix this?
The display and backlight are the biggest users of power for any computing device. You can lower the display brightness and on some even lower the backlight intensity to conserve power, but this will have an impact on your viewability.
Sep 18, 2016 | Tablets & eReaders
My lcd display is dim on my sony xdr-ds12ip dab radio, you can see the display faintly and it does search and display the time. Also the backlight is working normally.
The backlight allows you to see the display. The LCD display only allows the backlight to shine through and produce the characters. Try looking at the display from a different angle as the light is polarized.
Jan 29, 2015 | Sony Computers & Internet
How do I fix the backlight of my garmin 3205
The LCD display contains both the display and backlight. They are integrated as one piece. Therefore the entire display needs to be replaced. The backlight connections are soldered to the LCD connections. Replace the entire display.
Dec 25, 2014 | Garmin nuvi GPS
My unit back light is not working. the chart is displayed but can only be seen if you hold it to your face.
Backlights are part of the LCD display and consist of LED's. You may have to replace the entire LCD display or find another display that is cracked but has a working backlight. In most cases, you can swap backlights. There may be some soldering involved.
May 28, 2013 | Garmin GPSMAP 235 Sounder GPS Receiver
I have a uniden bc340crs scanner that is 1 yr old. my backlit window does not display any of the info for my scanner. i want to reprogram and the 2-9-hold thing does not work even after trying ronnie...
This is how you control the back light display on your scanner.
SNOOZE/Backlight - Backlight: Tap the snooze button to turn the LCD backlight on for 15 seconds. Press and hold to permanently turn on the backlight. Press and hold again to turn off the backlight.
Here is a link to the users manual as well. http://www.uniden.com/pdf/bc340crsom.pdf
Mar 14, 2011 | Uniden BC340CRS Base Scanner
I changed the batterys in my 1F78-151 thermostat and now the backlite does not work.....
• Display Backlight - (Not available on earlier models.) The display backlight improves display contrast in low lighting conditions. Selecting backlight ON will turn the light on for a short period of time after any button is pressed. Selecting backlight OFF (default) will keep the light off. Turn the display backlight feature ON as follows: 1. Press TIME and RUN buttons at the same time. The display will show "d-L" and "OFF" alternately
Dec 22, 2010 | Heating & Cooling
My sansa clip will play music but the screen will not light up;
There's a timer for the display backlight that can be set and used for
saving power. When leaving the player untouched for a certain time, the backlight switches off. Touching any button will turn on the backlight, restarting the timer.
To set the backlight timer on the Sansa Clip,
execute the following steps:
1. Press Menu button to return to the Main Menu.
2. Move to Settings and select it.
3. Select Display.
4. Select Backlight.
5. Press |<< or >>| button to select desired backlight timer.
Dec 24, 2009 | SanDisk Sansa Clip MP3 Player
Camera turns on fine. I could view picture and all. Just that when I switch to camera mode a video screen is blacked out. Why is that?
Your have a "Display" button that toggles thru different display modes .. one of the modes turns off the LCD backlight .. that useful if you are in bright light and dont need the backlight .. you have a very nice "transflective" display that works great in bright light without the backlight ... you can get more shots with the backlight turned off on each battery charge .(about 25% more) .
so each time you operate the display mode button you will get a different display .. one shows a hystogram .. one turns off the backlight and one puts the camera in a normal mode ..
if everything is working right then even with the backlight turned off you should be able to go outside or any brightly lighted area and see the picture on the screen ..
Sep 04, 2009 | Sony Cyber-Shot DSC-T33 Digital Camera
Backlight wont stay on
The inverter board which provides the backlight power isn't working properly. This is a pretty common problem with LCD screens. The inverter is in the display, mounted under the display panel. It's a fairly simple job to replace the inverter. You have to remove the screws holding the front of the display to the back and separate the pieces. The inverter is held in place by a couple of screws and has a couple of cables connecting it to the main board and display panel. Unplug those, remove the inverter, mount the replacement and plug the cables back in. Then reassemble the display. A search on Google for "acer 5315 inverter" turned up several sources for the replacement part. Here is one. I don't know anything about this seller; I just picked it as an example.
May 19, 2009 | Acer Aspire 5315 Notebook
Beoken backlight
u kant
u will have to get another screen 4 ur psp
Nov 18, 2008 | Sony ACY-BR81/OB
Radio Shack Pro-2096 Base Scanner Logo
35 people viewed this question
Top Radio Shack Radio Communications Experts
Jason
john milligan
Steve
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
