Question about Arris 3347 DSL 4-Port Wireless Modem - Router (612572157275)
My Motorola 3347 modem, when plugged in, only lights up the 4 Ethernet lights. They are solid lights, not blinking. Nothing else comes up. The modem is ONLY plugged into the power, there is no phone l
I recently got a Motorola 3347 modem from craigslist, and when I plug it into the power, all that happens is the 4 Ethernet lights come on and stay solid. No phone line is connected, the power light doesn't come on. Is this normal?
  • 9 Answers
SOURCE: motorola router
first check your computers internet connection settings.and also check for any updates that could pretain to your modem/or computer.the problem is with your main computer,and not with the router.second check your firewall,make sure the correct port is open to let the traffic in.
Posted on Dec 31, 2007
dhruv765
  • 53 Answers
Modem light goes RED if No external Ethernet device has been attached and detected OR The Ethernet link is down.
in your case it is going to be the DSL MODEM ....
Second cause could be The WAN interface has been disabled by the firmware.
TO enable it log on to your router's address http://192.168.10.1.
and look for WAN options.
http://broadband.custhelp.com/cgi-bin/broadband.cfg/php/enduser/std_adp.php?p_faqid=17058&p_sid=rTOCxT5j&p_lva=17178&p_accessibility=&p_redirect=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODAsODAmcF9wcm9kcz02MzAsNjQ0JnBfY2F0cz0mcF9wdj0yLjY0NCZwX2N2PSZwX3BhZ2U9MQ%2A%2A&p_li=
Thanks ,, please let me now it worked or not
Posted on Jun 09, 2008
  • 31 Answers
SOURCE: Wi-Fi isn't working
This could be a duplex issue. When you log into the belkin does is assign you an IP address? Have you used a ballpoint pen to reset the EMTA since you have connected the router?
Posted on Apr 09, 2009
kakee
  • 1269 Answers
SOURCE: modem light is red won't stay green.
Make sure to configure the router according to your ISP settings. I believe you have a DSL connection. That means you need to configure the router using PPPoE
Posted on Apr 26, 2009
zazonker
  • 68 Answers
SOURCE: Unable to set up wireless router
Shut down your computer, unplug the cable modem and the switch. Connect all three - computer to switch, switch to modem. Make sure that the ethernet cable between the router and the modem is in the router uplink port and that the computer is plugged into one of the four ports that look alike. Wait 30 seconds - plug in the modem. Wait another 30 seconds, plug in the router, wait another 30 seconds and boot the computer. Open a browser and see if you have internet access. If you still don't, then try to check the browser by typing 192.168.1.1 into the address bar of the browser. That should give you the browser sign in screen. The Linksys default is to leave the user name blank and type admin for the password. That should give you access to the router so you can check the settings. If this doesn't work, document carefully what happens and post again with your results and we'll try to go from there.
Posted on Jun 08, 2009
My at&t Motorola 3360 has every light blinking but is still working. The Power and DSL are continuously blinking red and the ethernet, internet and activity are all blinking green.
Here's the thing...if the modem is unplugged, and you press the "Reset" button, or any button, nothing will happen because the modem is UNPLUGGED.
When you plug it in again, there is usually a few minutes or so during which time the lights will blink. Eventually, when the DSL connection is established, the blinking should decrease. But, there will always be some blinking going on to indicate that data is being transmitted.
If the "Ethernet" light is blinking, then a computer that is plugged into the router is transmitting/receiving data. If the "Wireless" light is blinking, then a computer that using a wireless connection to the router is transmitting/receiving data.
If a red light blinks, then that usually means the DSL connection has been broken. When that happens, for whatever reason, the modem will automatically begin its initialization routine and will continue to do so until connection has been established. During that time, LEAVE IT ALONE.
If you uplug the device, or if you press ANY button while the device is attempting to correct itself, you can cause permanent damage.
So, you are correct. It's not a problem. I'm sure you've heard the phrase "If it's not broken, then don't fix it." There's a lot of truth to that.
I hope this helps.
Randy
Dec 01, 2012 | Arris 3360 AT&T DSL Modem - -
I have AT&T DSL service with a Motorola 3347 modem. The wireless function was working just fine when I set it up yesterday, but now it's decided that I only get limited access (i.e. nothing) on the...
power down the modem . Check ADSL filters match the ADSL service eg ADSL 2 service has ADSL 2 filters.
Power on Modem wait 5 minutes for it to resync with DSL and see if internet is back up.
Aug 02, 2017 | Arris 3347 DSL 4-Port Wireless Modem -...
How to get ethernet
ethernet which is 10/100 mbs is LAN provided out of the four ports. The wireless is not ethernet it is WI FI. Router will give IP addresses in DHCP format automatically to 190 peripherals. There is no getting ethernet, it is supplied.
Feb 04, 2011 | Arris 3347 DSL 4-Port Wireless Modem -...
Need to connect Linsys to motorola modem for wi fi usage
  1. simply unplug the router and the modem from their power source
  2. plug the power cable into the modem
  3. wait for the lights to stop coming on, until you see solid power and internet connectivity LED and an intermittently blinking activity light.
  4. now plug the power to the router and allow it to boot all the way up as well.
  5. no your internet should be workin. (the ethernet cable should go from the LAN port on the modem to the Internet port on the rear of the router, and any desktops should be connected beginning with the LAN 1 port and advancing as required)
Jan 08, 2011 | Linksys Wireless-G WRT54G Router
Motorola MSTATEA takes long time to "reconnect"
Check the speed and call ISP tech support to run the line test
Before calling them do a complete power cycle
Turn the modem off and the computer off and router if any
Wait for 30 seconds and turn the modem on and wait for the lights to turn solid
Once ready turn router if you have else computer
Delete the temporary internet files browsing cookies,cache memory.
If the modem turns too hot after running for an hour please replace the modem
DSL light blinking green indicates that there s no proper signal to the modem
Check the wall jack for any loose contacts
If you have any filter check them too
Isolate them and try with it
Change them if possible
Feb 06, 2010 | AT&T High Speed DSL Modem
2wire ethernet and wireless lights blinking
They shouldn't become solid. Most lights blink when there is a communication between the devices. It's never a solid connection light.
Oct 04, 2009 | 2wire Computers & Internet
Installing My New Motorola dsl modem
hello!
-- what is the model and brand of your modem?
-- who is your internet service provider?
-- is your account activated?
-- do you have a username and password from your ISP?
-- have you tried changing cables? what about the phone port?
May 08, 2008 | Computers & Internet
Arris 3347 DSL 4-Port Wireless Modem - Router (612572157275) Logo
Top Arris Computers & Internet Experts
bobkoure
Level 1 Expert
Jerry
Jerry
Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
