Question about Technics SL-1200MK2 Turntable
I need to replace a fuse in my record player - Technics SL-1200MK2 Turntable
    Sergeant:
  • 357 Answers
You have not given much information, however if you're not sure how to go abvout changing a fuse I would suggesst you take it to a professional\electrician to do this for you. It would be irresponsible of anyone to advise you to do otherwise and potentionaly put your life and equipment in danger. Fuses blow for a reason, so an electrician\specialist will be able to test the item for you to ensure it is safe.
Posted on Jul 08, 2014
Dvd recorder
fuse immediately burns? Replace Power supply check link: avsystemparts.com
Sep 28, 2013 | Panasonic DMR-EZ485VK DVD Recorder/VCR
AMI Jukebox Lifter Arm Problem
Dave - I have the same problem, how do you replace the trip switch? I got the part, but it appears it needs to be soldered?
Aug 27, 2012 | Audio Players & Recorders
Does The Magnavox Dvd Recorder / VCR zv427MG9 Have An In Line Fuse
There is a replacable glass cartridge type fuse inside it. It can be located at its mains power supply regulator board.
Jun 09, 2012 | Magnavox ZV427MG9 DVD Recorder VCR
Panasonic DMR-EZ48V keeps blowing fuses.
I don';t like to replace fuses with the power on. the fuse is meant to protect valuable parts; this error mode indicates a probable fault internnaly. NEEDS to be serviced.
Apr 07, 2012 | Panasonic DMR-E55 DVD Recorder
I have a JVC DR-MX1SEK dvd combi recorder. It was working well when I was searching for another problem when I removed the plug from the mains socket and a blue flash came out of the recorder. I removed...
Not sure if you have resolved this but that fuse is widely available. It is a 20mm x 5mm 2 amp slow blow glass fuse. It is perfectly possible that your replacement was correct but that a separate fault in the machine is causing the fuse to blow. Remember, fuses are designed to protect things (either the machine or you) and to blow if a fault causes more current than is safe.
Jan 05, 2011 | JVC Televison & Video
My unit 3576 H was working properly. I purchased it about 16 months ago. I was watching TV and not using the hard drive or DVD when the power went out, then shortly came back on. It was connected to a...
Take the unit aparts,check the power fuse on the board,replaced the power fuse,that is near the a/c power cord.Replug it back like 48 hours later,the recoder should reset it self and work,if not ur right it a paperweight,not worth repairing.
Oct 02, 2010 | Philips DVDR3576H DVD Recorder
I can not get my recorder to work when I plug it in it dose not come on. I lost power a couple of times when I was at work now it will not come on. where can I get it fixed
Check the in line fuse...If you remove the unit cover the inline fuse sits right behind the plug socket...If the fuse is okay, then you will need to replace these two capacitors on the same power circuit board...One is at location C19, 3300uf, 10 volt, and c23, 1000uf, 10volt...
Aug 08, 2010 | Pioneer DVR-220 DVD Recorder
No Power after an electical storm
It is very likely that a fuse has blown inside the unit. If you have warranty on the device you should get the manufacturer to replace it. However if it's out of warranty and your not afraid to open up the case of a DVD player you should be able to unplug the unit. Remove the screws and then look for a small glass type fuse located on the main board of the DVD player. It will have two tin ends and a glass tube in the middle. Remove it with a small pair of pliers being careful not crush the glass tube. Replace it with the same type of fuse with the correct voltage and amperage.
Jul 13, 2009 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Need PANASONIC DMR-EZ485V remote control codes for vizio VA220E. Have tried 0178 and it works the on/off but what will also work the channel and volume? Thanks for any help. Fran
I connected my Panasonic DMR EZ485V DVD Recorder in 240 VA, and after to broke (burned) the safety fuse. Do you know what is the value of the fuse??? I need replace this, but I don´t know the specification. I know my Panasonic DMR EZ485V DVD Recorder work 120 VA. Best regard
Jun 29, 2009 | Panasonic DMR-EZ485VK DVD Recorder/VCR
Technics SL-1200MK2 Turntable Logo
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
