Question about Konica Minolta bizhub Office Equipment & Supplies
No power cord and power point ok but machine wont turn on
  • Konica Minolta Master
  • 6,161 Answers
Check the fuser and or circuit breaker inside machine
Posted on Mar 12, 2017
How do you get it to wash
plug power cord into power point and turn on power point
turn dial round to cycle
then make sure door is closed
A model number and make of washing machine would enable a more specific answer
Aug 15, 2016 | Washing Machines
My Simpson toploader Eziset 750 will not start, the power point is ok.
Maybe the lid inhibitor switch is faulty,or not being pushed in when lid closed
Sep 20, 2014 | Washing Machines
Why is my eureka super broom not turning on?
When machine does not work, first check wall outlet ( plug in an hair dryer or table lamp to check wall outlet. ) and it that is OK than check your power cord for break ( if wire's are broken inside outer coating the cord will be very weak at that point )
May 15, 2014 | Eureka Super Broom 286 Vacuum
Samsung j843 wont turn on
Check your breaker box... If not there I would check the cord to see if a powersurge damaged the cord or worse the machine utself.
Jul 15, 2012 | Samsung Washing Machines
Fisher and Paykel smartdrive excellence 7.5
The pump has a thermal cut out fitted,
Pump must have over heated and cut power to machine.
Replace the pump to fix this problem.
Feb 04, 2012 | Fisher Washing Machines
My bosch maxx laundry machine wont turn on
If you dont have power to the machine, your electric cord from machine to power point is broken. To check this turn on at power point and at machine hold cord in hand and shake if machine makes any noise you have a broken lead which can be cut at break and fixed,but better replacing with new cord Hope this helps
May 25, 2010 | Washing Machines
Optiplex gx620 USFF. no power to the machine
HELLO THERE:
THE FIRST THING YOU WILL NEED TO DO IS TO DOUBLE CHECK ALL THE CABLES AND POWER CORDS ARE FIRMLY INSTALLED NORMALLY REMOVE AND REINSTALL THE CORDS AND CABLES TO MAKE SURE THEY DID NOT COME LOOSE IF IT WONT BOOT THAN TRY TO REMOVE THE CD ROM AND THE HARDDRIVE CORDS AND CABLES FROM THE DEVICES AND TRY TO BOOT IF THE MACHINE IS NOW STARTING INSTALL THE CABLE AND CORDS 1 AT A TIME FOR EACH DEVICE AND BOOT UP THE MACHINE EACH TIME THIS WILL HELP YOU FIND OUT WHERE YOUR PROBLEM IS OK.
BEST REGARDS MIKE
Aug 02, 2009 | Dell OptiPlex GX620 PC Desktop
Saeco Incarto No Power problem
Check the capacitor which is under the pump and behind the power switch.
Jun 14, 2009 | Saeco Incanto Classic Espresso Machine
Simpson washing machine not turning on
check outlet with multimeter for 120 volts .If voltage found check cord for 120 volts .If cord has 120 volts turn on timer jumper lid switch . did this help?
May 30, 2009 | Washing Machines
LAVAZZA ESPRESSO POINT CAPSULE MACHINE WON'T GO ON
There are two ten amp small bus fuses in the back of the machine directly next to the iec power cord. Should you need service you can call 781-393-2929. We are an authorized lavazza distributor and repair center.
Jun 19, 2008 | Lavazza Espresso Point Capsule Machine
22 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
David Burkhart
David Burkhart
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
