Question about HP LaserJet M1522nf Multifunction Printer (CC372A)
Hp 1213 only supply memory error - HP LaserJet M1522nf Multifunction Printer (CC372A)
4 Suggested Answers
  • 489 Answers
SOURCE: HP 4200 10.0000 supply memory error
It appears that the printer is having problems reading the e-label on the print cartridge. Remove and reinstall the print cartridge, then press the Select button. That should clear the problem.
Posted on Apr 07, 2009
Dadofmykids
  • 25 Answers
SOURCE: hp laserjet m1522nf 10.0000 supply memory error
Try another toner. Most likely the chip on this one is bad.
seeker5211
  • 1089 Answers
SOURCE: Hp laserjet m1522nf 10.0000 supply memory error...
Are you using HP toner? Try reseating the cartridge. If it's still getting the error, replace the cartridge.
Posted on Jun 03, 2010
Supply memory error
There is a protective plastic clip over the cartridge chip. Remove the orange plastic and it will quit giving you the supply memory error. Refer to figure 6
Supply Memory Error' Message Displays on the Control Panel
Or Still having Problem Then follow Us For
HP Support
Apr 21, 2014 | HP Laserjet M1522nf All-in-one Laser...
Hp color laserjet cp2025 10.1000 supply memory error
Hp color laser jet cp2025 10.1000 supply memory error solution
May 30, 2012 | HP Office Equipment & Supplies
My HP Laserjet 1536dnf MFP is "10.000 Supply Memory Error" then saying "supply memory warning"?? How do I clear that??
10.0000 Supply Memory Error - A specific print cartridge has an e-label error.
Solution:
1.Reinstall the print cartridge.
2. Turn off and then turn on the product.
3. If the problem is not solved, replace the cartridge.
Hope this helps
Sep 13, 2011 | HP Office Equipment & Supplies
10.1000 memory error
Thank you for contacting FixYa with your printer inquiry.
This error is normally associated with a supplies error. I have extracted information on this error from the HP 6L manual.
Error Codes
Error 10 - Supplies Memory Error 10.XX.YY Exact format is dependent on printer model
    The printer is unable to read the electronic information (elabel) on the print cartridge. This helps track page count and life of consumable.
    XX Description 00 memory error on the cartridge or 01 memory device not found
    10.00.00 Black print cartridge
    10.00.01 Cyan print cartridge
    10.00.02 Magenta print cartridge
    10.00.03 Yellow print cartridge
  1. Supplies used in newer printer models contain a memory chip. The information contained on this chip is dependent on the printer model and the supply. The error 10 indicates a problem with the printer obtaining the information from this chip. The chip may be missing or defective or contain incorrect information. There may be a problem with connection between the memory chip and DC controller. Turn the printer off/on to attempt to clear or reset the message. Remove and reinstall the supply, replace the supply.
  2. Replace the memory chip cable/connector or the DC controller.
    How did we do?
Hope this helps helps. Please keep us updated and remember to rate this answer.
TF
Jun 08, 2011 | HP : HP6L Laserjet Printer
I have HP Laserjet 5200N printer, i am not able to print due to error massege "10.00.00 Supply Memory Error". thanks Mohammad Hittini Director of IT Moevenpick Resort & Spa Dead...
Not sure if you have tried the HP knowledgebase, but there are a few steps they recommended trying.
Here is the direct link, but I copied the relevant information into my reply.
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpl51389&locale=en_US#A3
10.00.00 SUPPLIES MEMORY ERROR alternates with For help press ? Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 00 = memory is defective
yy
  • 00 = black print cartridge
Action
  1. Turn the printer power off, and then turn the printer power on again to clear the message.
  2. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 .
  3. If the printer has a 500-sheet Tray 3 installed, turn the printer off again and replace the print cartridge with a new HP print cartridge.
  4. Turn the printer on again.
  5. If the error does not clear, turn the printer off and remove Tray 3.
  6. Turn the printer on and verify if the error clears.
  7. If the error does not clear, contact HP support.
10.10.00 SUPPLIES MEMORY ERROR alternates with For help press ? Possible printer control panel error message 10.10.00 SUPPLIES MEMORY ERROR Description An error has occurred in one or more of the printer supplies. Values of xx and yy are listed below: xx
  • 10 = memory is missing
yy
Action
  1. Turn the printer power off, and then turn the printer power on to clear the message.
  2. If the message persists, click here to access to the HP support Web site at http://www.hp.com/support/lj2300 .
Jan 01, 2011 | Computers & Internet
May 20, 2010 | HP Hewlett Packard LaserJet 3000dn Printer
I have replaced the printer cartridge (x3) and I am getting a error code 10.10.00 with every one of them on the printer. I have run through the cold start functions and nothing. Any suggestions?
yy
Action
Jan 26, 2010 | HP LaserJet 5550DN Printer
Apr 07, 2009 | HP LaserJet M1522n MultiFunction Printer
Check paper error on HP PSC 1213
check:-1- any small pieces of paer stuck inside the fax.2-check of any foreign object droped inside.3- check for broken lever of paper sensing switch and check it is movement it must move smothly .
Feb 25, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
HP LaserJet M1522nf Multifunction Printer (CC372A) Logo
Seeker5211
Seeker5211
