Question about Malber WD1000 Front Load Washer/Dryer
Malber wd1000 wiring diagram - Malber WD1000 Front Load Washer/Dryer
  • 13 Answers
SOURCE: where do i put detergent
Contact Malber USA (info@malberusa.com) to order a new Manual.
Posted on Jan 07, 2008
  • 29 Answers
SOURCE: leaking
Hi. Mike here. Two "most likely" causes. (1) You simply have a leak at the lower right "cleanout trap". Remove the little white plastic "pull-out" assy. Check the black seal that looks like a little "tire". Is anything caught in it, or wrapped around it, or has it become deformed? Also, check that white plastic (2") washer, in front of it, is not warped (due to overtightening). Unscrew the "knob" (handle) part, all the way out, and separate all 4 parts. Clean knob, washer, tire (seal), and trap assy. Slip washer, then tire, onto knob's threaded "shaft". Flat side of washer goes against knob. Screw knob, washer and tire into trap assy, but only one or two turns. Then, slip entire assy back into machine's recess - and turn Clockwise to tighten. Only tighten hand tight (and I don't mean Macho tight!)
(2) If that doesn't fix, you may very well be using WAY too much detergent. These machines use only 2 or 3 (Max!) Tablespoons of HE liquid detergent. I've seen cases where folks were using 1/2 cup of liquid (or powder) and even more. That causes so much foaming that there have been overflows, from the lower right corner, even though nothing was wrong with the machine. To remedy, run a load empty, with NO detergent.
Good luck, and God bless.
Posted on Mar 11, 2009
SOURCE: Malber WD1000
door handle broke at plastic insert. Looking for replacement parts.
Posted on Aug 01, 2009
SOURCE: Is there any place i can get instructions for a
http://www.absak.com/pdf/manuals/Malber/WDman.pdf
Posted on Oct 08, 2009
  • 3741 Answers
SOURCE: Hi my Malber WD1000 will not spin. How can I fix
If your washer won't spin, check these:
It doesn't pump or spin
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin
If your washer pumps out the water but doesn't spin, check these:
The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Nov 27, 2009
Malber WD1000
Jul 05, 2009 | Malber WD1000 Front Load Washer/Dryer
Malber wd1000
Two of the dials are dryer settings. There is only one washer dial, which basically controls the length of the wash and rinses, etc.
Apr 22, 2008 | Malber WD1000 Front Load Washer/Dryer
Malber WD1000 Dryer wont heat
I have a bit of experience with Malbers. When the dryer won't heat the most likely cause is the heating element wearing out. See my other posts to the same problem by saerching Malbers problems here. If you need more help, contact me.
Mar 16, 2008 | Malber WD1000 Front Load Washer/Dryer
Where do i put detergent
Dec 11, 2007 | Malber WD1000 Front Load Washer/Dryer
Gasket for Cleanout at bottom of Malber WD1000
WD1000 gaskets are in stock and available for immediate delivery from Malber USA. (info@malberusa.com)
Dec 09, 2007 | Malber WD1000 Front Load Washer/Dryer
Where do you gets parts and schematic?
check two places. repair clinic dot com and parts select dot com
Sep 06, 2007 | Malber WD1000 Front Load Washer/Dryer
Open Questions:
See all Malber WD1000 Front Load Washer/Dryer Questions
Malber WD1000 Front Load Washer/Dryer Logo
46 people viewed this question
Top Malber Washing Machines Experts
Gerry Harvey
Gerry Harvey
ashburton
Dan Webster
Dan Webster
Are you a Malber Washing Machine Expert? Answer questions, earn points and help others
