Question about Canon LASER SHOT LBP-2900 Printer
Brother hl 1110 print on glossy paper? - Canon LASER SHOT LBP-2900 Printer
  • 66 Answers
SOURCE: Canon Pixma mp510
The top-loading sheet feeder accommodates approximately 150 sheets (depending on weight), and the front feeder is good for around 100 sheets. Actual media sizes supported by the main feeder (top-loading) include A4, B5, A5, Letter, Legal, Envelopes (DL size or Commercial 10), 10x15cm(4" x 6"), 10x18cm, 13x18cm, 20x25cm, and Credit Card (54x86mm), while the front feeder is less accommodating with just A4, Letter, and B5.
Posted on Jan 30, 2008
IrishDruid
  • 2712 Answers
SOURCE: Colour on glossy paper
First thing, use original Canon cartridges. that could be the source of your issue, as these days, printer companies resort to these kinda tricks to ensure that the customer only buys their products.
Next, make sure that you have selected the proper paper type and output quality under printer properties.
Should this not work, please post back so that we can assist you further. But remember, try with the original inks first, and not refilled or generic cartridges.
Posted on Jul 02, 2008
spinal
  • 287 Answers
SOURCE: Imagerunner 1023if printing on glossy paper
Hello boriquajake,
We are looking at inherent limitations of the copier. The reason the paper appears "glossy" is that it is coated with a type of plastic that does not like going Thru whats called the fuser. This fuser does what its name implies as it "fuses" the toner to the paper by way of extreme heat and pressure. Thru decades of trial and error copier manufactures have found a way to make carbon black and plastique( like the EURO NAME?) along with other confidential compounds into a mixture (called toner) that can survive the extreme heat (370' F and above) and pressure (the sky is the limit here) bond to the paper and successfully exit. However, the nifty glossy paper was designed for an inkjet printer which uses sprayed ink and neither heat or pressure. My final most helpful statement would be that glossy paper was never designed for a copier. And I can promise you that at some point the glossy paper will cause a paper jam in the fusing area that will be very expensive . Since the "gloss " is merely a plastic shine that was never meant to be "re-melted" by the rubber coated rollers......... need I say more. One day you will have a paper jam from hell that will destroy the fuser. I wish I had better news but if you think about it I just saved you a service call, and a significant bill. You are are the working guys/ gals like me that I like to help before you get screwed. Take care.
Posted on Jul 23, 2008
  • 153 Answers
SOURCE: Canon Pixma MP830 printing red/orange hue on glossy photo paper
are you using geniune canon glossy paper??? it is designed for the printers and really is the best for the machines
Posted on Apr 14, 2009
  • 77 Answers
SOURCE: Printer does not print on plain paper. It works on
Please try to change the paper type :
Please follow the steps given below:
1. Click on "Start," "Control Panel," "Printers and Other Hardware" and "Printers and Faxes."
2. Right click on the Canon printer icon and select "Properties."
3. Under "General" tab click on "Printing Preferences."
4. Go to "Quality/Copies" and under the "Paper Type" and select the right option under "Use my choice"
5. Select on "OK."
your's tech expert
Jeeth
Posted on Apr 27, 2009
Faded color prints
* If your are printing color photos on a Glossy paper you must chose the paper type from Media Type in the Printing Properties while giving Print command. If you don't know what is the type of your glossy paper then just select other glossy paper from the given options. f91a3a39-5f37-45c6-9bca-21ac453f79ef.gif
May 06, 2014 | Brother MFC Office Equipment & Supplies
I have a Brother DCP 195c and it wouldn't take in other photo papers! I tried to print using the free brother photo paper and it's fine but when I use other inkjet glossy photo, it wouldn't take in the...
Your glossy paper is too smooth for the rubber rollers to grab it.
You need to wet the rubber rollers. Ever licked your finger in order to turn a page in a book? Same concept solution here.
Remove the paper tray. Take a look inside the space created where the tray was, and locate the rubber rollers. Lick your fingers, and use them to moisten the rubber rollers.
Reset printer and print again. Or try "un-smooth" the paper where the rollers grab it.
Oct 11, 2010 | Brother DCP 165C Compact Color Inkjet...
Can the Brothers HL 2040 handle printing 65lb
It probably can but only from the front slot, the paper tray has to bend the paper around the roller in the front when feeding.
Aug 28, 2009 | Brother HL-2040 Laser Printer
Brother DCP 185C cannot print to a glossy paper
in brother printer there. we can choose many types paper. we are pinting now photo in same. choose paper option while giving print command
Jul 11, 2009 | Office Equipment & Supplies
My MFC 5890 cn Brothers printer paper keeps getting jamed and won
What kind of paper are you using?
Normal paper or Photo Glossy paper?
If you use Photo Glossy Paper, you have to put at least two sheets of paper. If you read the photo glossy paper instructions that came in the package you will see it.
The package brings one sheet more than mentioned because of this specification.
Mar 23, 2009 | Brother MFC-5890cn Color Flatbed...
Glossy paper jams
hello! most printers will only print on regular , you can not use glossy paper. the paper pick up rollers will not grab the paper, they tend to skid on the paper, good luck. brother tech
Jan 13, 2009 | Brother MFC 240C All-In-One InkJet Printer
Difference between Brother HL-4040CN and HL-4050CDN printer
The D stands for duplex printing (both sides of paper)
Dec 16, 2008 | Brother HL-4040CN Laser Printer
Black ink won't print,just the color ink prints. It's a Brother MFC-3240C thanks in advance
You must run a clean cycle after installing a new cartridge.
Try running a clean cycle and see if that relieves the problem. I just had the same problem on a MFC 210C and called Brother. That is what they had me do and now it is working fine.
Oct 28, 2007 | Brother MFC 210C All-In-One InkJet Printer
Canon LASER SHOT LBP-2900 Printer Logo
44 people viewed this question
old marine
old marine
