Question about Dymo Pocket InkJet Printer
My dymo pocket is flashing a 4 in the display
I cannot clear a flashing "4" in the display
Windows vista and dymo labelwriter 450
Here is how to upgrade the software:
1. disconnect the printer and make sure you log in as an administrator. If you need to, back up your contacts: Address Book > Export;
2. uninstall everything that says DYMO (Start > Control Panel > Uninstall) and re-start the computer (back up whatever should be saved);
3. install the latest Windows updates;
4. install DYMO Label 8.5.0: see the download link below(I suggest right-clicking the downloaded file and running it as administrator);
5. connect the printer directly to the computer only when prompted;
7. only use DYMO-made rolls - black stripes on the back, the logo and article number should be there.
tinyurl.com/dymolabel850pc
Also, please go to Start > Devices and printers > right-click the printer > Printer properties > Ports > clear Enable bidirectional support > OK.
^CM
Jan 07, 2013 | Dymo ® LabelWriter® 450 Series PC...
How do you change the time on a dymo datemark
Hi there!
Here's what you can do"
1. To set the current date and time, press and hold down the SET/EDIT button for a few seconds. Release the SET/EDIT button when the Month (M) and Day (D) indicators start flashing.
Note: The unit will revert back to normal display if no other key is pressed for 10 seconds
2. While the Month (M) and Day (D) indicators are flashing press the LOCK button to cycle through the 3 available date formats.
3. Once you have chosen an appropriate date format press the SHIFT button to switch between each of the different DATE, MONTH, YEAR, HOUR, and MINUTE fields. The field that is currently active will start flashing. To change the field's value press the LOCK button. Each stroke of the LOCK button moves one value up.
Note: If you go past the current year, you will need to press the LOCK button to cycle through the year 2189 and back up to the current year.
4. Once you are finished setting the Date and Time press the Set/Edit button to return to the normal display. The Date/Time Stamper is now ready to print..
Hope this helps!
Vikroks
Mar 29, 2011 | Dymo DateMark Date/Time Stamper
I lost the intruction booklet - how do i change font size? and can make it BOLD?
You have not mentioned the DYMO Model #.
Click on the link below to open the DYMO Page to download the manual and use it.
Choose the DYMO model and choose the manual option to download.
Download Link
Thank you for contacting FixYa
*Please rate this solution with thumbs up
Nov 18, 2010 | Dymo Pocket InkJet Printer
Dymo letratag 2000
Dymo don't do spare parts for their machines - because most of them are so cheap now that it's much cheaper to buy a new one than it is to repair them.
This is especially so for the LetraTAG machines which are the cheapest in the Dymo label maker range.
For that price it's a no-brainer - if the display is unreadable just buy a new one!
Apr 26, 2010 | Dymo LetraTAG Thermal Label Printer
Hi I'm wondering if the Dymo pocket will take a tape, so that I can iron labels on to clothing or even be stitched on. If so what would the cassette be called. Thanks
The Dymo label printer capable of printing iron on tape is the Dymo Letratag. There are a couple of model printers
Dymo Letratag - handheld model
Dymo Letratag - desktop model with qwerty keyboard
and the Dymo 18771 Letratag iron on tape is the tape cartridge available.
Jan 21, 2010 | Dymo LabelPOINT 100 Thermal Printer
Printing error print system exception error
I had this problem with the LabelWriter 450 Turbo and it was a .Net Framework problem.
1. Uninstall the Dymo Label software
2. Click this link to download .Net Framework 4.0 http://www.microsoft.com/downloads/details.aspx?FamilyID=9cfb2d51-5ff4-4491-b0e5-b386f32c0992&displaylang=en
3. Reinstall latest version of your Dymo Label software (w/o printer connected to PC)
4. Reconnect label printer when prompted by installer
This should fix the problem
Dec 24, 2009 | Dymo LabelWriter Thermal Printer
I need a manual for the dymo letra tag. I keep getting error 1
Hello, Please find the link to your letra tag manual: https://global.dymo.com:443/enUS/RNW/RNW.html?pg=std_adp.php&p_faqid=68
Jun 11, 2009 | Dymo LetraTAG Thermal Label Printer
Reducing the size of the font
Yes. Do the following:
1. Press "Format"
2. "Size" will appear in display.
3. Press "OK"
4. Rock center button with 4 arrows on it, Up or Down to change size.
5. Press "OK" when desired size appears.
6. Bingo!
Jan 30, 2009 | Dymo LetraTAG Thermal Label Printer
DYMO THINKS ITS OUT OF PAPER ....
New versions of the Labelwriter 400 (original and Turbo) do not take Generic Labels. It is an issue with the firmware Dymo have installed - it will only relabelwriter400.jpgad the genuine labels made by Dymo. currently there appears to be no work around to solve this isses.
The Dymo OEM labels have lines print on the back, if you use labels without these lines, the printer gives an "out of paper" error
The only printers in the Dymo Range that will take our generic labels are the Dymo Twin Turbo and the Dymo Duo (both the more expensive from the range).
Dymo have only made this change in the last 6-8 months, old 400's will work with cheaper generic labels
Aug 09, 2008 | Dymo LabelWriter 400 Thermal Printer
Dymo Pocket InkJet Printer Logo
16 people viewed this question
Top Dymo Office Equipment & Supplies Experts
Ed Mac
Jax Planet
Jax Planet
Are you a Dymo Office Equipment and Supply Expert? Answer questions, earn points and help others
