Question about LG Washing Machines
My Lg 7kg wd 8026c front loader won't open - LG Washing Machines
barkencoa
  • 3463 Answers
SOURCE: front loader noisey
Hi.
If you remove the belt and turn drum by hand, it should revolve freely and without any noise.
If it is noisy or feels stiff, then you proabably have main drum bearing failure.
Could be expensive to put right
Posted on Nov 22, 2008
SOURCE: 7KG WD-8050FH LG Clean Master
I had same problem and i have opened the the water pump and found some tissues blocked the fan from spining , i remove it and immediatly worked .
Posted on Aug 14, 2010
sonicboomele
  • 1557 Answers
SOURCE: i have a lg intellowasher 7kg wd-8015c (front
the water pump is sending a signal to the pcb telling it there is a fault clean the filters and wheel on the water pump
let me know how you went
sonic boom electronics
Posted on Dec 28, 2010
ginko
  • 19396 Answers
SOURCE: LG Intellowasher 7kg WD-8026C. This
Hi.
As you probably know, OE means that the machine does not drain.
To open the door you need to empty water first.
To empty water:
  1. Disconnect power.
  2. Prepare a container to collect water and clothes to dry.
  3. Open the drain filter access door (see picture).
  4. Rotate drain cap.
  5. Collect water.
  6. Remove any blockage from filter.
  7. Re-apply power, wait thirty more minutes or so if door still does not open.
Here the filter access:
If 0E comes back, check the drain hose at the back of the machine.
Regards.
Ginko
Posted on May 31, 2011
werven283
  • 29 Answers
SOURCE: LG front Loader Intellowasher 7kg WD-8015c has
I have the EXACT same problem wit the LG 8015C. After numerous attempts, I finally found the problem. A set of wires attached to the drum body vibrates against th erear panel, wears off the plastic insulation, shorts and blows the circuit board. All because of sloppy workmanship ! It took 4 years of easy work for this to occur. Will NEVER buy an LG or Front Loader again
Posted on Jun 21, 2012
Lg problem
problem with door switch bi metal,,,kindly replace door swich,
Apr 19, 2014 | LG Washing Machines
I have a lg intellowasher 7kg wd-8015c (front loader), and its not spinning and the clothes come out wet. whats wrong and what parts will i need please
If the washer is not spinning you need to check on the motor, motor capacitor and the power from the program controller unit. If there is no power to the motor then the controller is a suspect.
Please check this link for tips: removing the motor:
Jun 23, 2012 | Washing Machines
My 7kg LG front loader WD-80134T showed a UE error. Please can you tell me what this means and where can I get the manuel?
This is an imbalance error code. Too small of a load will cause this error code.
-Check and rebalance the load
-Make sure Washing Machine is level
-Redistribute the load evenly
May 15, 2012 | Washing Machines
The door is jammed on my LG Intellowasher WD-1023C-Washing Machine - Front loader. It has finished it's wash cycle, but the door won't open
Slide a paint scraper or similar between the machine and the latch side and push it quite hard and it should open. Mine does and I found the fix on this site!
Jul 13, 2011 | LG WD-1041WFH Front Load Washer
LG front Loader Intellowasher 7kg WD-8015c has been on a quick 30 mins cyle and is still going after 1 hours just keeps spinning and won't turn off
Sep 18, 2009 | Washing Machines
Front loader noisey
Hi.
Nov 21, 2008 | Hotpoint Ultima WF860 Front Load Washer
7KG WD-8050FH LG Clean Master Front Loader (5 stars) No Drain ....won't drain or spin
Jul 14, 2008 | Washing Machines
Washing Machines Logo
12 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
